iImage Information
The DIY Radio is designed to be produced and sold as a flat-pack unit, consisting of three parts. An electronics module, the main body, and a cover. All of these components are designed to fit neatly together, using Velcro to attach the cover, which holds the structure together. The DIY Radio is an extremely cheap unit for use in developing countries. Because it is made of card, the tooling costs involved in the manufacturing are very low. Secondly, it comes as a flat pack unit, meaning storage and transportation cost per unit as extremely low compared to regular radio’s. The radio features two simple dials, to avoid clutter. The user could even mark their favourite stations around the dial. Over all, this contributes to a stylish, yet extremely cheap radio that is battery powered a perfect for users in developing countries who want to be entertained.
You will also see my exploded diagram which shows all the individual components of this radio.
Materials List:
-1 sheet of high quality A3 card (red)
-1 sheet of high quality A3 card (grey)
-2 1 cm sticks of 12mm dowel
-2 12 mm diameter dials
-1 Sony ICF-S22 radio
-2 12mm strips of Velcro
-1 6mm x 6mm square of Velcro
-1 AA battery case
Tools Required:
-Scissors/ Craft knife. Or a laser cutter if you have access to one
-Micro Screw Driver
Step 1De constructing the Sony ICF-S22 radio
iImage Information
This step simply requires you to carefully unscrew all the screws in the outer shell and within the battery casing of the radio. Take care when pulling the two halves of the radio apart so you don't pull any wires out, which are hooked onto the casing at certain points. They could quite easily be pulled from the chip board. Once the radio is in two halves, the chip board and speaker can easily be popped out from its mounting points. The battery connections from either end of the batteries also need to be clipped out. The casing is not needed for this radio, just the speaker and the chip board
I guess very hot and dry climates would be good for such a radio if the plastic were to be endangered by the environment. I'd avoid sending a cardboard radio case to any place with humidity and rain though.
Something to consider for a future design which would be cheaper in a developing country would be to design a fully screen printed radio circuit which has no 3-D components. I don't know if we can screen print all different kinds of electronic components yet, but that would allow for a cardboard radio. (It's rumored that in Japan some cellphones were once printed onto the cardboard of cereal boxes. It was a sales gimmick to get people to sign up for cellphone service on a contract.) Maybe someone can veryify or debunk this....
great project.!
