DIY Railroad Anvil Stand
19,550
142
5
Published
Introduction: DIY Railroad Anvil Stand
About: Hello and welcome! My name is Austin. I enjoy creating interesting projects and sharing my projects and ideas with all of you. Please feel free to check out my Youtube channel: https://www.youtube.com/user/a...
In this Instructable I will be showing you step-by-step how to make this rustic looking anvil stand. I decided to make this stand because I recently picked up this cool old anvil that was made from a piece of a railway track and had no place to work on it. I bought this anvil because I have gained some interest in knife making and I want to try it out for some of my future projects.
Before you go through the rest of the steps for this project, you should definitely watch the video that I have posted below. The video will show you plenty of clips of me building the stand from start to finish. Also, if you enjoy the video you should definitely hit the like button or even consider subscribing to my YouTube channel. Most importantly don't forget to follow me here on my Instructables page so that you can see all of my future projects! Let's get started with this project!
https://www.youtube.com/watch?v=VmTQgpH9boc
Step 1: Materials and Tools
Materials:
- 9” x 7” Railway Tie
- Railway Spikes (X4)
- Anvil
- 1/2" x 4" Lag Bolts (X4)
- 1/4" x 4" Lag Bolts (X4)
- 1 1/2" x 2 1/2" Lumber
- Wood Stain
Tools:
- Wood Saw or Chain Saw
- Sledge Hammer
- Drill
- Impact Driver
- Grinder with Wire Wheel
- Chop Saw
Step 2: How to Determine the Height for Your Anvil
Because the anvil is made from a piece of railway track I thought it would be cool to make the stand out of a railway tie. So I picked up a 4’ length of 9” x 7” railway tie. To determine the proper height for your anvil, stand up straight and let your arms rest comfortably by your sides. When making a fist the top of the anvil should just be touching your hand. To measure the proper height for my anvil I stacked up some wood until the anvil was at the desired height. This makes it easier if you are working by yourself.
Before I cut the railway tie in half a drilled a piece of wood on each side. This allowed my to keep the saw nice and straight while I made the cut. Believe it or not I used a hand saw for the entire cut! I definitely regret not using a chainsaw to make it easier on myself because railway ties are EXTREMELY hard to cut!
Step 3: Fastening the Anvil
After I was finished the cut I fastened the anvil on the top with some 1/2" X 4" lag bolts and cleaned off most of the rust with a wire wheel. This anvil had not been used for a long time so it definitely needed some cleaning up!
I also cleaned up four railway spikes. I thought that these would work perfectly to hold my hammers on the sides.
Step 4: Inserting the Railway Spikes
Making the holders for the hammers was very easy. I simply marked out the proper positioning for each railway spike and pre drilled the holes. The drill bit that I used had a slightly smaller diameter than the railway spike. This made it easier for my to fasten them into the railway tie with a sledge hammer.
Step 5: Making the Legs
To finish up the stand I made some legs with my chop saw out of some 1 1/2" x 2 1/2" lumber using 45 degree cuts. I added some dark walnut wood stain to match the color of the railway tie and to keep things looking rustic. I then used a forstner bit to make room for the heads of the lag bolts and then pre drilled the rest of the hole. I then fastened them 1" in from the edges with the 1/4" x 4" lag bolts.
I love how rustic the finished product looks and I can't wait to get some good use out of it! Thanks for reading through this Instructable. I hope you all enjoyed this short and simple project!
  • Woodworking Contest
    Woodworking Contest
  • Casting Contest
    Casting Contest
  • Make it Move Contest
5 Comments
That is just beautiful! (voted). Where did you get the square hammer (not the pinball), I really like it.
FYI you made the right choice using a handsaw. I did some landscaping once with railroad ties and tried cutting them with a chainsaw. Big mistake! The teeth were gone in seconds. Most be something in the creosote that is super abrasive. Or maybe the speed versus the slower handsaw.
Great looking project BTW
How long is your track anvil? How much of it is horn and how much flat? How much does it weigh?
Your stand is a cool idea and well executed. I'm holding out for a piece of elm stump.
Very nice work! I'm considering making one like you did. I've seen used (used up) railway ties for sale at the garden stores, which avoids the legal hassles you CAN get into if you remove railroad equipment or even one lousy spike from a railway.
Remember folks, it's a Federal Felony to remove railroad property from a railway, even an abandoned one. If you are on railroad property ask permission, you have a 50/50 shot they'll give it to you if it's worn out. And get a letter from them describing what they gave you. It'll keep the Railroad Police from locking you up.
Nice video of the process, and looks to be able to handle the beating you'll be giving it. Well done!
