DIY Rain Alarm Using 555 Timer
5,071
96
8
Published
Introduction: DIY Rain Alarm Using 555 Timer
About: I like making new things from trash. For more cool content please subscribe to my YouTube channel @ https://goo.gl/BHxFf7
Building a home made rain alarm.
This circuit beeps for about 40 seconds when it detects rain. This circuit uses a 555 timer.
This circuit can also be used with pressure sensor or with LDR for detecting light
Step 1: Things Required
1. 330 Ohm Resistor
2. 1M Ohm Resistor - 3
3. 330k Ohm Resistor - 3
4. 10k Ohm Resistor
5. 100uF / 25 Volt Capacitor
6. 0.1uF Ceramic Capacitor
7. 0.01uF Ceramic Capacitor
8. LED
9. 555 Timer
10 Buzzer
11. BC177
12. 2 pin connector male & female
13. PCB Board, Wires& Battery
14. Plastic Bottles - 2
15. Soldering Rod, Soldering Wire & Soldering Paste
16. Insulation Tape, Scissor & Hot Glue Gun
Step 2: Making Video
You can watch the making of the DIY Rain alarm or continue reading the post on how to make the DIY rain alarm
You Can Subscribe To My YouTube Channel Here : https://goo.gl/ctc8l9
Step 3: Circuit Diagram
Step 4: Circuit Construction
Mount all the components on the PCB boards and connect the circuit according to the circuit diagram as shown in the previous step.
Step 5: Rain Switch Making
1. To make the rain switch we need two bottles.
2. Cut them as shown in the 1st and 2nd image
3. Make two holes in the sides of the cap to insert the wires
4. Now insert the wires and secure them with hot glue. Note : make sure the ends of the wire are exposed and the two wires does not come in contact with each other
Step 6: Finished Images
To watch the testing video CLICK HERE
Testing begins @ 8:58
If you interested in making this product you can please use my affiliate buying links to buy the components
Do you want to support my videos?
If Yes, Please browse and buy things from my Amazon Store. This way I get a small commission which will help me produce more videos. Please use the link to visit my store : http://goo.gl/gKjns4
You can also contribute to me on Patreon using the link : https://goo.gl/JHoagv
Amazon US:
555 Timer : http://amzn.to/2a3yOwY
Buzzer : http://amzn.to/29WQOLM
Resistors, Capacitors & Others Things : http://amzn.to/2a2CzU8
PCB Board Connectors - http://amzn.to/2a2Cos5
LED - http://amzn.to/2a2CTlP
3.5 mm Jack - http://amzn.to/29Y2Rmb
Soldering Kit : http://amzn.to/29RyXjJ
Wires - http://amzn.to/29Y1kwt
Battery - http://amzn.to/29Y0Shu
PCB Board - http://amzn.to/2abRXw7
Insulation Tape - http://amzn.to/29YNZax
Scissor - http://amzn.to/29Y1K65
Hot Glue Gun - http://amzn.to/29Y2BU8
Amazon India:
555 Timer : http://amzn.to/29DJIum
Buzzer : http://amzn.to/2a2lNTl
Resistors, Capacitors & Others Things : http://amzn.to/29DJCmB
PCB Board Connectors - http://amzn.to/29P6wU4
LED - http://amzn.to/29Gd7nW
3.5 mm Jack - http://amzn.to/2a5dSEL
Soldering Kit - http://amzn.to/29P00wv
Wires - http://amzn.to/29GdPBl
Battery - http://amzn.to/29HEp9E
PCB Board - http://amzn.to/29Ged2O
Insulation Tape - http://amzn.to/29HGzpJ
Scissor - http://amzn.to/29P2ECE
Hot Glue Gun - http://amzn.to/29HEslT
Follow Me On :
You Tube : https://goo.gl/ctc8l9
Twitter : https://twitter.com/MakeStuff_MS
THANK YOU FOR READING !!!
    • Clocks Contest
      Clocks Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    8 Comments
    Thanks. great little project will give this one a try!!
    Enjoy making..For any help just leave a comment...
    Hello, thank you for an interesting idea, I was trying to figure out the circuit, and I still can't seem to understand why the pnp transistor is wired that way... Every tutorial in the web points that emitter (marked with an arrow) should be connected to Vcc, while here it is grounded. Can you please provide some insight on this? Thank you very much :)
    Hello, The emitter is grounded because it is a common emitter circuit, which means the emitter is common for both input & the output & Common emitter has very high gain
    The reason for using common emitter is, to amplify the faint signals received by the rain sensor.
    Hope my answer helps you
    Can you give more details about how the rain sensor part in the bottles works please
    The two wires in the rain sensor are not connected which means the circuit is in open loop state. Since we know water conducts electricity. So, when the water gets collected in the cap the wire gets connected through water as the medium and circuit becomes closed loop and triggers the alarm..
    Hope this answer helps you !!!
    In image 2 have you finished cutting the second bottle? I cannot tell from the photo, but it looks like it is inverted with the threaded portion removed to accept the inverted portion of the first bottle?
    You can use the same bottles top and bottom. I used two different bottles.
