This pedal is a clone of one on my favorite effects pedals from the 80's... ProCo's RAT Distortion. It's a basic OpAmp distortion pedal using the classic LM308N IC chip that is a fairly simple build for those handy with a soldering gun, have a free weekend, and love rock-n-roll.
The layout we are using was designed by Francisco Pena who has done an excellent job with this and other pedal designs on Tonepad.com. (please refrain from editing the circuit board artwork unless you have permission from the author. (sorry Francisco!!))
The schematic and PCB are available in PDF form at TonePad.com following this link , which also has a great library of other effects pedal and guitar related projects to build from beginner to advanced. You will also need the PDF for Off-Board Wiring for wiring the input/output jacks and power for the pedal.
TonePad.com also carries ready-made Printed Circuit Boards to purchase if you don't have the time or effort to make your own. The PCBs on tonepad.com come with a screen printed component side, tinned solder pads and also a solder mask - all for a pretty decent price considering the cost of supplies you have to buy to make your own! I recommend going this direction if you want as close to error free build as possible.
You can buy the majority( if not all) of the parts from Small Bear Electronics which offers pretty reasonable prices and are supporters of TonePad and several other DIY music project sites. (Also recommended!)
I created the graphics in Adobe Illustrator and have made it available below to all that wish to use it. It is a PDF file saved out of Illustrator so it is easily edited with any vector graphic software that can open pdf's..... have fun with it and go wild.
(I'll post some sound clips and maybe some video soon to give you an idea what it can do.)
Now lets get ready to Rat-n-Roll.....
dead_rat_stickers.pdf125 KB
Remove these ads by
Signing UpStep 1Getting the Goods....
You can cross reference the IC's and transistors online at NTE to find the "generic" NTE version, which are usually easier to find locally. Audiophile types frown upon using NTE parts for high-end projects such as amplifier rebuilds do to inconsistencies in part specs but for projects like this I haven't had any problems so far.
Not stated in the schematic but is assumed knowledge is: All resistors are 1/4 watt , all capacitors need to be rated for 12 volts or higher. (a 12V .01uF capacitor and a 50V .01uF are the same except the 50V can take more voltage and will be bigger in size in case you were curious.)
In addition to the parts listed in the PDF file, you will also need:
- Qty. 3 - 100K-A (Audio or Logarithmic (same thing) Potentiometers - 17mm diameter fit better
(careful not to get Linear taper Pots.... big difference!)
- 3PDT stomp switch (Small Bear Elec, or Ebay)
- 9V battery snap and battery Clip,
- LED and LED holder (if you want a status indicator)
-1/4" Stereo input jack
-1/4" Mono input jack
-22 Gauge stranded hookup wire (preferable 3 different colors)
- 9V "wall wort" power supply (center conductor is " - ")
(this can be a salvaged one rated around 500 milliamps or so)
- power supply connector (female, that matches the connector on the power supply)
-Suitable case (preferable metal for strength and shielding.) Check the web.. Hammond cases are the most popular. I found mine at my local electronics part dealer.
*edit* My last trip back to the store I found out the company and the part # of the case...
The company is: LMB Heeger (they have a website also) and the case is # MDC532
Other Supplies & Tools:
Soldering iron, Solder, Drill/Dremel, Drill Bits, Clothes Iron, Plastic Containers, Rubber Gloves, PCB etchant (Ferric Chloride), Multimeter (for testing/troubleshooting), and cold beer.
i just finished my rat build, very cool instructions, thank you!
i have a question about the sound though: when you strum some powerchord palm muted, does it have "punch"? because my build sounds a bit weird i think... palm muted it doesnt' have that certain punch its a bit more noisy than i think it should be.
the other question is about the potis: when i set any one of the potis to zero (doesn't matter which) i hear nothing. is that normal or is it an error in my build?
Good luck.
I was just wondering how you tell which side of the jacks is which?
Secondly, AC voltage is noisy by nature. In order to clean up the noise of AC voltage, engineers design the circuit with filter capacitors and other goodies to clean out the AC ripple. Without these components, you will pick up the oscillations of the AC current and hear the feed back and hum.
Without a schematic of the circuit board it is hard to tell what you would need to do to clean up the hum....
Goodluck!
When the switch is on, the first lead on the top row and the first lead on the second row are connected. So if you tested it with a multi-meter on continuity setting you would get a "beep", stating that current is able to flow from one lead to the other. So the 1st lead of the top row and the 1st lead of the middle row, as well as the 2nd lead of the top row and the 2nd lead of the middle row and same for the 3rd lead. BUT, when the switch is off, then the 1st lead of the middle row connects to the 1st lead of the third row, and the top row is disconnected. Confused yet?
So if your switch is rectangle than the rows should go the long way across.... but you can test with a multi-meter just in case.
anyway, if you mind, may i ask if how many watts you used on your resistors?
and how many volts for the capacitors.
thanks.
The electrolytic capacitors need to be rated at least double the power supply voltage for safety. So for a 12 volt power supply you would use 24v caps or higher. You might get by with 12v caps but its always better to error on the side of caution.
Better safe that sorry.
Pretty much any decent sign shop has the correct equipment to do that. Try your local Fast Signs, Signs-in-a-day, or FedexOffice(one that has a sign shop in it).
You can also also use "waterslide decals".. they make both lazer & inkjet waterslide paper that you can print your own graphics on. It's the same kind of material that they use to put the word "Fender" on the headstock of a Stratocaster. Google it, its a pretty simple process and has great results.
I have just completed this build. Your instructable was perfect and easy to use! This is my first build and I am very happy with the results. I used to own a ProCro Rat in the 80's and I believe that the distortion on this unit is even better than I remember! I used a Hammond 1590BB for the case and purchased the PCB from Tonepad. Now I am ready to make my own PCB's and move onto the Electric Mistress!
Thank you so much for your build notes!
The other option is to find some Waterslide Decal paper and print it out yourself (you can buy it off the web).... Waterslide decals are like the word FENDER on the headstock of a Stratocaster..... they look nice but have to be painted over with a cleancoat to protect them from wearing off....
Good luck.
