3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Rat Clone Distortion Guitar Effect Pedal - The Dead RAT
This ain't no Mickey Mouse distortion pedal!
This pedal is a clone of one on my favorite effects pedals from the 80's... ProCo's RAT Distortion. It's a basic OpAmp distortion pedal using the classic LM308N IC chip that is a fairly simple build for those handy with a soldering gun, have a free weekend, and love rock-n-roll.
The layout we are using was designed by Francisco Pena who has done an excellent job with this and other pedal designs on Tonepad.com. (please refrain from editing the circuit board artwork unless you have permission from the author. (sorry Francisco!!))
The schematic and PCB are available in PDF form at TonePad.com following this link , which also has a great library of other effects pedal and guitar related projects to build from beginner to advanced. You will also need the PDF for Off-Board Wiring for wiring the input/output jacks and power for the pedal.
TonePad.com also carries ready-made Printed Circuit Boards to purchase if you don't have the time or effort to make your own. The PCBs on tonepad.com come with a screen printed component side, tinned solder pads and also a solder mask - all for a pretty decent price considering the cost of supplies you have to buy to make your own! I recommend going this direction if you want as close to error free build as possible.
You can buy the majority( if not all) of the parts from Small Bear Electronics which offers pretty reasonable prices and are supporters of TonePad and several other DIY music project sites. (Also recommended!)
I created the graphics in Adobe Illustrator and have made it available below to all that wish to use it. It is a PDF file saved out of Illustrator so it is easily edited with any vector graphic software that can open pdf's..... have fun with it and go wild.
(I'll post some sound clips and maybe some video soon to give you an idea what it can do.)
Now lets get ready to Rat-n-Roll.....
Step 1Getting the Goods....
The PDF file has the parts list along with the circuit board layout. This is not a RatShack project so you will have to order online from Small Bear Electronics or another reputable electronic parts dealer such as Digikey , Mouser , or MCMinone if you are not lucky enough to live in a city with a decent electronic parts store. I use metal film resistors instead of carbon film due to there tighter tolerance range (10% or 5% for carbon vs. 1% metal film margin of error) and if you buy an assortment online you can get them in bulk pretty cheap.
You can cross reference the IC's and transistors online at NTE to find the "generic" NTE version, which are usually easier to find locally. Audiophile types frown upon using NTE parts for high-end projects such as amplifier rebuilds do to inconsistencies in part specs but for projects like this I haven't had any problems so far.
Not stated in the schematic but is assumed knowledge is: All resistors are 1/4 watt , all capacitors need to be rated for 12 volts or higher. (a 12V .01uF capacitor and a 50V .01uF are the same except the 50V can take more voltage and will be bigger in size in case you were curious.)
In addition to the parts listed in the PDF file, you will also need:
- Qty. 3 - 100K-A (Audio or Logarithmic (same thing) Potentiometers - 17mm diameter fit better
(careful not to get Linear taper Pots.... big difference!)
- 3PDT stomp switch (Small Bear Elec, or Ebay)
- 9V battery snap and battery Clip,
- LED and LED holder (if you want a status indicator)
-1/4" Stereo input jack
-1/4" Mono input jack
-22 Gauge stranded hookup wire (preferable 3 different colors)
- 9V "wall wort" power supply (center conductor is " - ")
(this can be a salvaged one rated around 500 milliamps or so)
- power supply connector (female, that matches the connector on the power supply)
-Suitable case (preferable metal for strength and shielding.) Check the web.. Hammond cases are the most popular. I found mine at my local electronics part dealer.
*edit* My last trip back to the store I found out the company and the part # of the case...
The company is: LMB Heeger (they have a website also) and the case is # MDC532
Other Supplies & Tools:
Soldering iron, Solder, Drill/Dremel, Drill Bits, Clothes Iron, Plastic Containers, Rubber Gloves, PCB etchant (Ferric Chloride), Multimeter (for testing/troubleshooting), and cold beer.
145 comments
1-40 of 145next »
May 19, 2012. 3:13 AMbabakkamiyab says:
hii. i cant download pdf file from your site can you help me and send it to my mail? babakkamiyab@google.com
Apr 16, 2012. 1:24 PMbzalavári says:
Hi I would like to ask for the schematic if possible. Thank you in advance
Jan 23, 2012. 5:16 AMmacboy98 says:
hey dude , where is the pdf file for the circuit board , pls reply ASAP
Jun 29, 2011. 3:34 AMLexoo93 says:
how do I have to change scheme #5 if I just want a DC input and no battery?
Nov 20, 2011. 4:13 PMEPIC Kelly says:
Yeah, if anyone out there knows the answer to this one, I'd really like to know too.
Nov 23, 2011. 7:09 AMEPIC Kelly says:
Thanks, that did answer the question. I figured that was the case, and tested it out and lo and behold it worked! Couldn't believe my mess of wires and solder and sweat actually worked. So, thank you for a very satisfactory project!
Aug 8, 2011. 10:35 AMtoxin20 says:
hi silverhalo,
i just finished my rat build, very cool instructions, thank you!
i have a question about the sound though: when you strum some powerchord palm muted, does it have "punch"? because my build sounds a bit weird i think... palm muted it doesnt' have that certain punch its a bit more noisy than i think it should be.
the other question is about the potis: when i set any one of the potis to zero (doesn't matter which) i hear nothing. is that normal or is it an error in my build?
Jul 1, 2011. 12:27 PMstreetcrab_helmut says:
Could you plaase tell me how you got the top of the PCB printed (with the shapes of the components to be fitted)?
May 28, 2011. 5:15 PMdeco97 says:
Hi,
I was just wondering how you tell which side of the jacks is which?
Apr 5, 2011. 3:50 PMicanmunch says:
how should I be connecting the wires to the stomp switch? my switch has 1,2,3 down the left side of it if this helps. its only got 6 lugs on it
Mar 1, 2011. 7:32 PMslapointe says:
I am not building your box but changing one I own. I have a EXH Big Muff Pi with no ac jack. I cut the battery connect off and soldered a power jack to the existing wires then connected a 9v 300mA power adapter. Seemed logical to me until I turn it on to play. Sounds great playing but if it is on and I am not playing I get a lot of humming feedback from the pedal. Any ideas about causes or solutions?
May 1, 2010. 10:41 AMaritoner says:
 so i blew the last one and decided to try again but i noticed that in your picture your true bypass switch looks to almost have a square shape but mine has a rectangular shape the question is how do i know which way is the right  way to start soldering
Dec 1, 2010. 7:52 AMnellie18 says:
nice project!
anyway, if you mind, may i ask if how many watts you used on your resistors?
and how many volts for the capacitors.
thanks.
Feb 1, 2011. 11:25 PMTeburon says:
love the graphics! but how did you get them onto the enclosure? did you use special transparent sticker paper or something?
Jan 21, 2011. 9:02 PMeduardrenz says:
How can I buy an LM308 IC and IN IN914 Diodes? I live at Phillipines.. can u help me for my Project?? Eduard
Feb 24, 2011. 6:01 PMlfebrero says:
Hi man! I was wondering in wich direction I should put the 3PDT switch to make the connections according to the diagram #5 in tonepad.I mean, with the tips horizontaly o verticaly?? thanks
Jan 21, 2011. 8:59 PMeduardrenz says:
Jan 4, 2011. 1:22 PMolivero1 says:
I have just completed this build. Your instructable was perfect and easy to use! This is my first build and I am very happy with the results. I used to own a ProCro Rat in the 80's and I believe that the distortion on this unit is even better than I remember! I used a Hammond 1590BB for the case and purchased the PCB from Tonepad. Now I am ready to make my own PCB's and move onto the Electric Mistress!
Thank you so much for your build notes!
Jan 1, 2011. 2:57 PMoweng4000 says:
What you should have done, would be call it the "deadmau5". Nerveless this was a great instructable, even if you did kill mickey mouse.
Aug 24, 2010. 1:16 AMedgas10 says:
hi im from portugal and knew to this stuff. i´ve order a lm308 but they made a mistake and send me a ca3080e. can you tell me if its possible to use it instead of the lm308? i know that they have not the same pinout. thanks edgar.
Jun 22, 2010. 8:05 AMMetalheadGautham says:
What difference would it make if I use carbon resistors instead of metal film resistors and UA741CN instead of LM308 to cut costs ? And yeah if I use a throw away plastic box and then wrap the whole thing with food grade aluminium foil, would it still work ? I mean the shielding...
Apr 21, 2010. 6:06 PMstevemilo says:
 This looks great! I will be attempting this for a class. Just a question, though, how big is the circuit board? I have to design and cast my own case and I'm trying to get my numbers right.
Mar 18, 2010. 10:03 PMmodernmusician1 says:
This is really awesome! I will attempting this project within the next few weeks, I already ordered the parts from smallbear and it only cost me about 50 bucks for everything, and I actually came across the EXACT same case at my local electronics shop (which is cool, because I dig the color scheme!) Currently I have an original mid-80s proco RAT on loan from a very good friend, and after using it I just had to have my own. So hopefully I will have the original and the clone to test against each other before I have to give it back! This will be my first foray into electronics like this, so hopefully it all turns out alright!
Apr 19, 2010. 9:23 PMhacker3455 says:
 Did your find all the Capacitors on small bear? I can only find two or three at best.
Apr 20, 2010. 10:08 AMmodernmusician1 says:
the capacitors were the only thing i had to buy at a local electronics shop. don't worry though, they're really cheap.
May 12, 2009. 12:20 AMkk0807_leung says:
can you send you Distortion Guitar Effect Circuit to me? this is my e-mail : sam133187@hotmail.com and if you have another Guitar Effect Circuit, can you send to my e-mail?
Apr 19, 2010. 4:11 PM13dwarf says:
where is the file on the site? i got there but i didnt see any thing that said "Distortion Guitar Effect Circuit"
Apr 19, 2010. 4:55 PM13dwarf says:
or can u email me the circuit board at kranku26@gmail.com
Apr 18, 2010. 8:22 PM13dwarf says:
where did u get the custom graphic sticker?
1-40 of 145next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:silverHalo
Jack of all trades, master of none, Sigh...... how does one get good at something when there are so many things in this world to learn?
