3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Rat Clone Distortion Guitar Effect Pedal - The Dead RAT
Step 3I love the smell of solder in the morning.......
This is always my favorite part. Following the layout on the PDF I always start with Resistors first. If you don't know how to read a resistor I recommend printing a chart off the web for reference so you can keep the values straight and not mix them up during the build. You can also set your Digital Multimeter to Ohms and measure them individually, if your resistors are 5% tolerance then the resistance for a 100 ohm resistor could be 95 to 105 Ohms and still be in spec.
Next I move to the Diodes and the Capacitors. Current only flows one way through a Diode so watch the direction so you don't install it backwards. Ceramic and Film Capacitors aren't polarized so they can be soldered in any direction but the Electrolytic Caps (round can looking ones) are polarized so make sure that are placed correctly or they could explode. (There is usually a stripe running down the side of the can with a "-" sign that corresponds to the Negative leg of the capacitor. The circuit board layout diagram always has a "+" sign on it where the Positive leg goes.)
Although not on the parts list, I bought an 8-Pin IC Socket for the LM308 so I could swap it out with other Op-Amp chips later if I wanted to do any mods without having to unsolder anything. You can get a set of 2 at the RatShack for .69 cents... part # 276-1995. After the components are soldered then precede to the wires. I bought a three pack of 22 gauge wire at RadioShack that comes in Black, Red, and Green so I could keep the similar paths color coded for a fool proof assembly.
Solder the Pots to the wires next, paying attention to the order (this is where different color wires helps out. I like to twist similar wire bundles together to keep things organized and keep them out of the way. Remember that in the wiring diagram the pots are shown face down so keep that in mind when soldering.
Alrighty, lets lay out the case and stuff in all together!
13 comments
Jul 1, 2011. 12:27 PMstreetcrab_helmut says:
Could you plaase tell me how you got the top of the PCB printed (with the shapes of the components to be fitted)?
Dec 1, 2010. 7:52 AMnellie18 says:
nice project!
anyway, if you mind, may i ask if how many watts you used on your resistors?
and how many volts for the capacitors.
thanks.
Feb 8, 2010. 5:59 PMoelefante says:
is there anyway i can make this work with a simple 2 pin switch? The 3pdt alone costs as much as all the other components together.
Oct 29, 2009. 5:29 PMbero2 says:
sorry for bombing you with questions but is that 8 pin ic socket one i could just pick up at the store or is it made especially for the lm308 chip
Oct 29, 2009. 11:03 PMbero2 says:
so it would be a good investment for the future right??
Oct 30, 2009. 10:09 AMbero2 says:
they have 1 for 48 cents at radio shack i think thats a good price for the option of experimenting...but for he future would i need to make any changes to the circuit  or does it not matter?and is their any chips you would recommend in the future? again sorry if they are not intellectual questions...thanks for all the help
Oct 28, 2009. 11:37 PMbero2 says:
are you sure those are 1/8 watt and not 1/4 watt they look a litte big
Oct 29, 2009. 5:23 PMbero2 says:
that makes my life easier i have alot of 1/4 resistors
Oct 29, 2009. 1:52 AMbero2 says:
could this project be done with only ceramic disk capacitors or do i need to get film ones too???
Oct 29, 2009. 5:22 PMbero2 says:
ok thank you for the input ill get some film one today this is great btw...
Oct 28, 2009. 5:39 AMwowannoying says:
how did you cut this from the others without breaking??
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:silverHalo
Jack of all trades, master of none, Sigh...... how does one get good at something when there are so many things in this world to learn?
