3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Rat Clone Distortion Guitar Effect Pedal - The Dead RAT
Step 5Rock-n-Roll!
Rock-n-Roll!
The graphics were designed in Adobe Illustrator and printed on transparent vinyl sticker material at my local FedexKinkos sign shop on their Gerber Edge 2 printer. Fast signs and other chain sign shops can print the same with any Vector graphics. Although not a permanent solution, I don't plan to Gig with this pedal so I didn't need anything of road worthy toughness. There are plenty tutorial on various stomp pedal websites and forums for case painting and labeling design so read up and go crazy.
Now plug it up to your guitar and amp and let the world hear the wrath of the DEAD RAT!!!!!
Check back later this year when I build a combo delay and chorus pedal in one case!!!
Troubleshooting:
If you were careful during the PCB soldering and double checked carefully that no excess solder has bridged any traces, and all the solder joints are shinny and clean then you can rule out any board issues.
Some people have had bad LM308 chips that they bought from questionable sources (hmmm..... ebay maybe??) so if you have issues and didn't buy from Small Bear then this might be a good place to start troubleshooting. (This is another good reason to use a IC socket so you can easily swap out chips to test.)
If you have any hum, make sure the grounds are connected correctly. Using a metal case allows you to ground to the chassis which will help out a lot. Also you might want to buy shielded input and output jacks or make a metal shield out of thin sheet metal that covers the jacks to protect against any other electro-magnetic interference.
5 comments
Feb 1, 2011. 11:25 PMTeburon says:
love the graphics! but how did you get them onto the enclosure? did you use special transparent sticker paper or something?
Jan 4, 2011. 1:22 PMolivero1 says:
I have just completed this build. Your instructable was perfect and easy to use! This is my first build and I am very happy with the results. I used to own a ProCro Rat in the 80's and I believe that the distortion on this unit is even better than I remember! I used a Hammond 1590BB for the case and purchased the PCB from Tonepad. Now I am ready to make my own PCB's and move onto the Electric Mistress!
Thank you so much for your build notes!
Apr 21, 2010. 6:06 PMstevemilo says:
 This looks great! I will be attempting this for a class. Just a question, though, how big is the circuit board? I have to design and cast my own case and I'm trying to get my numbers right.
Nov 6, 2008. 2:38 AMwatchmaker_of_death says:
It's great, but I have a noob question... Where can I find the electronic scheme ?
Oct 5, 2008. 2:11 PMPlinio says:
That rocks! I liked it! very nice! Congratulations!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:silverHalo
Jack of all trades, master of none, Sigh...... how does one get good at something when there are so many things in this world to learn?
