Introduction: DIY Reclaimed Wood Sign Vintage (Up Inspired)
I have been making wood decorations out of wine staves and old wood around the yard
When the reclaimed wood contest showed up, I immediately went to work think of what I could make
I knew from the beginning I wanted to make a sign that said "antiques" but thought that was too dull
At first I wanted to make a sign with a house at the bottom but one of my kids said that was boring
They suggested adding the bubbles painted
That gave me an idea to make balloons popping out of the house like the movie Up
Step 1: Materials
Any type of wood lying around
I used wood from an old fence and cut it to about 20 " by 5"
Make sure the grain of the wood shows for a vintage look
Plywood for the house
4" be 4" for the square
Thin pieces of wood for the frame to fit around the plywood (optional)
Nails
Hammer
Wood stain
Scissor
String
Super glue
Branches
Table saw
Sponge
Nails
Hammer
Wood stain
Scissor
String
Super glue
Branches
Table saw
Sponge
Step 2: Making the Frame
Cut the plywood to desired length
Cut pieces of thin wood to make the frame around the plywood
Nail the pieces together using two nails on each side for strength
Step 3: Making the House
Cut a piece of plywood into a square
Set aside
Cut another piece of plywood into a triangle to fit the square
Stain if desired
Using a sponge dip into the stain and apply and dab on wood
Let dry
Set aside
Stain if desired
Let dry
Step 4: Cutting the Balloons
Take the branches and start cutting them thinly on the table saw
Start staining them
To stain
Rub one side of the cut branch on the cement and dab stain on the slices
Let dry a day before gluing
Start staining them
To stain
Step 5: Glueing All Together
Using super glue, glue the square at the bottom or where ever you want it to be
Cut the string and attach to the top of the square using glue
Attach the end to the middle of the pink using glue
Glue the triangle to the square tilted
Start arranging the balloons on the string and glue together
Let it dry
Let it dry
Step 6: Results
If you want it to be on the wall add hole for the nail on the wall or use a different piece for hanging it
This was very easy and turned out really well
Enjoy!
Enjoy!
