DIY Remix: Koi Fish $5 Bucket Stool DIY
867
23
Posted
Introduction: DIY Remix: Koi Fish $5 Bucket Stool DIY
Check out the short video I made of this DIY above.
I was wondering what would embossing and inlaying concrete look like. So I used Homemade Modern's bucket stool DIY as a project to try it out on. I ended up with stool that had a Koi fish inlay design.
For more of my weird DIY's check out my blog: Home Tree Atlas
Step 1: Materials
You'll need:
  • 1 1/4 inch dowels
  • A bucket
  • Cardboard
  • Packing tape
  • Exacto knife
  • Sandpaper
  • And 2 colors of concrete. I used normal concrete and a bag of white concrete. You can also buy concrete dye and use it with white concrete.
  • A print out of a design, I found mine online
Step 2: Cutting Out the Template
Cut out your print out, then trace it onto a sheet of cardboard. I did this twice so I could get a thick mold for the concrete.
Step 3: Save the Leftovers
You can save the scrap pieces of the cut out, and use them to create embossed concrete pieces. Find my DIY for that here.
Step 4: Glueing It Together
After you have your pieces cut out, then you'll need to glue them together. Since the bottom of my bucket wasn't flat, I needed to cut a circle from the cardboard.
Step 5: Waterproofing
Take the packing tape and cover the whole piece. This will protect it from the wet cement.
Step 6: Pouring the Cement
You will want a bit of a wet mix of cement. So that it will nicely cover the design.
Before you pour in the cement, make a mark 3 inches from the bottom of the bucket, so you'll know when to stop pouring. Also make a mark 1 1/2 inches from the bottom of your dowels, so you'll know how far to push them in.
Step 7: The Stool Legs
Push in the dowels, and spread them evenly around the bucket. Since mine wanted to float up, I taped them to the bucket.
Tap and shake the bucket gently to get the air bubbles out.
Step 8: Getting the Stool Out
Let it dry for over 20+ hours.
I had to break my stool out. But you should be able to bend the sides of the bucket to loosen it and pull it out.
Step 9: The Inlay
The next step is pouring the colored/white cement into the inlay. Again you'll want a wet mix. Use a tooth pick to push the cement around making sure it gets in all of the corners of the design.
Step 10: Sanding
Once the new cement is dry, you'll need to sand it to bring out the design.
Step 11:
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
Great idea! If you want to save the bucket, just let the concrete dry until it's hard to the touch, then gently shake\slide it out and let it finish curing.
