Introduction: DIY: Replace Carbon Brushes on an Impact Driver
This time I’ll show you how to choose, where to get and how to replace carbon brushes for Bosch impact driver.
How I did it - you can check by looking DIY video or you can follow up instructions bellow.
For this project you will need:
Materials:
New set of carbon brushes
Tools:
Flat screw driver
Step 1: About Problem
Picture of About Problem
I have to take a look at this old Bosch 18V impact driver, because it started to make strange things. For example: motor losing power, it stops working suddenly, sparks coming from motor and motor running poorly.
All those signs indicate, that your power tool needs attention and probably new carbon brushes. The brushes rubs against the commutator on impact driver armature. They are responsible to transfer electricity to the spinning armature. They made from carbon and because of that they will wear down with normal use and eventually you’ll need to replace them.
To replace brushes is super easy to do, so let get started. Before start disassembling - remove battery.
Step 2: Disassemble
Picture of Disassemble
Brushes are located in two opposite tool sides under plastic covers.
Step 3: The State of First Brushe
Picture of The State of First Brushe
This brush is totally destroyed and probably that’s why tool won't work properly any more.
Step 4: The State of Second Brushe
Picture of The State of Second Brushe
Another brush is still in one piece and looks a little bit better, but also it must be replaced.
Step 5: How to Choose and Where to Get New Brushes
Picture of How to Choose and Where to Get New Brushes
The new carbon brush set I got from local power tools repair company. To get right set, it was needed to provide power tool product number, which is written on a impact driver.
If you don’t have such store at your location, you could type your power tools product number in google and try to find his manual. There will be written all tool components with individual part numbers. Take that brush part number, paste in ebay, amazon ar other your favorite eshop - and you will get some options where to get new set of brushes.
Step 6: Old Vs New
Picture of Old Vs New
It’s is quite a big difference between old and new carbon brushes.
Step 7: Re-assembling
Picture of Re-assembling
Assembling everything back and lets check, does new brushes solved our problem.
And it performs like it should.
Few bucks for brushes, few minutes of work, and your tool will be back to business.
MartijnD (author)2016-12-05
Nice instrucable, small tip, let the new brushes wear in for so they wear in to the shape of the collector before applying a heavy load, this might burn collector and your motor is ruined. Simply have a full battery, the tool and a ty-wrap or piece of rope and let the tool run no-load untill the battery is empty.
Mjtrinihobby (author)2016-10-29
Very nice!
TheCoffeeDude (author)2016-10-28
Great money saver! Especially if you pick up second hand tools and give them a new life.
About This Instructable
2,587views
43favorites
License:
More by Well Done Tips:How to Make a Mini Bar From Jerry CanHow to Make Cordless Driver Holder From PVC Pipe How To Make Motorized Turntable From Lazy Susan
Add instructable to:
