Introduction: DIY Replacement AIR Filters
Own one of those room sized plug in air purifiers? Sick of paying $10-$100 per filter? We were too, so we decided that we could save money and get a better filter.
HEPA Filters are made for clean rooms and easily clog up in a home environment. After reading many studies done on filters, we've concluded that getting a furnace filter is the best choice. Today there are plenty of sub-micron grade furnace filters, and luckilly for us, they are all priced based on micron size (so get the biggest one you can with the highest filtration rating possible.)
Also doing this seems to create a better air path (blocks off any cracks that air can bypass the filters with, as they are usually designed to do - as HEPA plugs up and that'd wear the motor out.
SAVE MONEY!
Step 1: Materials List
You'll need:
-A "flat" filter based air cleaner, technically any of them work that I've tried (all of them were holmes brand but others seem like they'd work)
-Allergen grade furnace filter (all of them are priced by how small of particles they filter, not by size. GET THE BIGGEST ONE of the rated filtration you desire to use)
-Scissors
-Duct tape
-marker
-Tape Measure
-Card Board
Optional:
-Gloves (to keep your hands from getting cut on the mesh)
Step 2: Make a Template for Future Use
We'll be making a cardboard template (not totally necessary, but we think its best so you can lay out the best way to cut up your jumbo filter and so you have it for the future and don't need to measure it again.
Take your old filter out of the machine, and put it on the cardboard. Trace, and cut out. You can make more for each of your filters to make sure you get enough for everything, or just use one.
Cut this out when you're done.
Step 3: Known Filter Sizes
Here are the filters that I know of, and their sizes:
Holmes G Filter (HAPF21)
5x8"
Holmes E Filter (AOR115, AOR118, HAP115)
6" Square
Holmes "625" (replaces the mutliple filters in the unit with one) (HAP625)
11.5x14
If anyone knows more, feel free to comment and I'll add them.
Step 4: Layout and Cutout
Lay the templates around your furnace filter and cut them out. Dont worry about being perfect, close enough is fine as we'll be taping them in.
Mark with a marker and cut out. Be careful about the sharp electrostatic mesh on the back, and try to not crush the folds as this would hamper the surface area per square inch of the filter.
It helps to cut down the fold of filter, and to mark or make note of what side goes down (esp for the filtrete 1250's as they are similar on both sides)
Step 5: Install the Filter!
Install the filter by placing it in, usually the mesh side down (note the arrows on the side of the original filter)
Tape around the edges of the filter with duct tape, and push the cover back on the filter unit. Note that it may become harder to remove the top...
NOTE (The pictured is a 1250 that has mesh on both sides, but the wording on the side of the filter is readable - right side up)
ENJOY!
