3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Reversal Lens Macro Rig
Step 6Practical Application
Our finished lens is great fun! I live in Michigan so I have to buy decent subjects. I chose a ripe Starfruit. With this lens the wider the angle the greater the magnification. My test shots were shot at 28mm which is the greatest possible magnification with this lens. The depth of field is extremely shallow with this. I used an automatic lens so I could not change the aperture. If you use a manual lens you would have full aperture functionality. This lens doesn't require a ton of light. My shots were done hand held with a studio light. In normal sunlight outdoors these are very effective.
2 comments
Oct 16, 2009. 11:34 AMDanC922 says:
It is possible to manually set the aperture with an automatic lens.  Set the aperture that you want with the lens on the camera normally, then press and hold the depth of field preview on your camera (usually on the front by the lens).  Pushing the button will put your aperture where you have it set.  While holding the button, remove your lens, and it will stay at that aperture.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
22
Author:jeoncs
I'm a photographer and a father. I've been married almost 7 years and have a 6 year old son and a 3 year old daughter. I like to put stuff where it doesn't belong to create even better stuff. I work f...
more »
