DIY Ric Rac Ribbon Rose
1,911
66
4
Posted in CraftJewelry
Introduction: DIY Ric Rac Ribbon Rose
About: A software engineer by profession, and a DIY'er by passion.
This DIY brings you how to make a Ric Rac Ribbon rose earring. In addition, this DIY will show you how to use bead cap as a Filigree!
Step 1: Materials Required
Ric Rac ribbon
Bead caps
Pearls
Headpins
Earring hooks
glue, tools (not pictured)
Step 2: Cut Your Ribbon in Half. Take One Half and Fold It Into Half.
Step 3: Alternate the Waves on to Each Other, Just Rotate Each Half on to the Other, in an Alternate Fashion.
Step 4: This Is How It Should Look Like Now. Seal the Ends Using Lighter, Use the Blue Flame for Clear Sealing
Step 5: Now, Keep Your Needle and Thread Ready. (I Chose a Matching Color)
Step 6: Start Rotating From the Middle Towards End. Just Stitch for Every Once in a While to Make Sure the Flower Stays in Place. (you Can Use Fabric Glue If You Are Allergic to Sewing.
Step 7: In the End, Push the Last Piece on the Back of Rose. This Will Be Your Back. Here Is Your Finished Rose. I Made 2.
Step 8: Now, Use Your Bead Cap As Filigree
Just open the bead cap ends using pliers and it will fan out as a filigree. Paste your flowers on to the filigree.
https://craftornothing.wordpress.com/2014/05/16/bead-cap-as-filigree/ - this shows u how to make bead cap as filigree.
Step 9: Add Your Pearl
Take a filigree and glue your rose back to the filigree.
Take a headpin, and add your pearl. Now bend the wire at 90 degrees. Cut extra and turn into a loop using round nose pliers.
Step 10: Using the Same Technique, Add Your Earring Hook.
Your ric rac ribbon rose earring is ready :)
    • Trash to Treasure
      Trash to Treasure
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    4 Comments
