Introduction: DIY Robot Arm Robotic 3D Printer Plotter Draw Homemade Frame With 2 Stepper Motor
2 pcs Stepper Motor Mounting L Bracket Mount for 57 Stepper Motor
1 pcs aluminium alloy 90 mm x 12 mm 250 mm
2 pcs 57 mm Stepper motor 1.8 degrees4
pcs FL08 2 Bolt 8mm Bore Self-aligning Flange Ball Bearing
2 pcs aluminium alloy 22 mm x 12 mm 150 mm
2 pcs Ball Bearing 12mm x 24 mm x 7 mm with 2 cover aluminium
More Homemade Mini Laser Engraving Cutter‎ DIY 3D Printer Machine Frame here:
About This Instructable
1,520views
23favorites
License:
More by joulethief669:DIY Axi Draw Bot 4xiDraw Robotic Pen AxiDraw Homemade Robot 3D Printer Plotter CNC Laser ArduinoHomemade Laser Engraving Plotter DIY Pen Draw Mini Machine CD RW DVD Drives Mechanism CNC ArduinoHomemade Wood Mini Lathe Collet ER11 Drill DIY Headstock Chuck Spindle Tailstock Slide Mill CNC
Add instructable to:
