DIY Robot Arm Robotic Draw Homemade Frame With 2 Stepper Motor
Published
Introduction: DIY Robot Arm Robotic Draw Homemade Frame With 2 Stepper Motor
Materials:
2 pcs 57 mm Stepper motor 1.8 degrees
4 pcs FL08 2 Bolt 8mm Bore Self-aligning Flange Ball Bearing
2 pcs aluminium alloy 22 mm x 12 mm 150 mm
1 pcs aluminium alloy 80 mm x 16 mm 260 mm for bed
2 pcs Ball Bearing 12mm x 24 mm x 7 mm with 2 cover aluminium
2 pcs 2020 Aluminum Profile Corner Fitting Angle 20 x 20 x 17 20 x 17 Decorative Brackets Aluminum Profile Accessories
More Homemade Mini Laser Engraving Cutter‎ DIY 3D Printer Machine Frame here:
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    • Clocks Contest
      Clocks Contest
