3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Rock Band Drum kit 8" Mesh Head Mod
DIY Rock Band Drum kit 8" Mesh Head Mod Tutorial
Step 1
I cut the 4 drum support out of a piece of paneling using the drum controller as a template and painted it black. I made sure each circle was the same size as the 8" mesh drums I'm using.
19 comments
Apr 11, 2011. 9:33 AMTojoReeves says:
(removed by author or community request)
Apr 12, 2011. 6:18 PMTojoReeves says:
I am accusing you of plagiarism. Convince me otherwise.
Apr 12, 2011. 8:10 PMTojoReeves says:
Again...
http://www.edrums.info/rock_band_kit_mod.htm
Same photographs. At least give credit where credit is due.
Apr 13, 2011. 8:56 PMTojoReeves says:
I apologize for my abruptness. Plagiarism is something I cannot stand and have (before this instance) never been wrong.
Apr 13, 2011. 8:58 PMTojoReeves says:
I suggest linking your website on your instructables. Not only to deter further incidents such as this, but to give a better set of instructions along with more projects.
Mar 10, 2009. 6:28 AMblondy28 says:
I noticed you are using a XBox drum set. Will this work on a PS2 drum set as well?
Feb 4, 2009. 3:35 PMjakblak says:
what kind of material is being used?
Jan 15, 2009. 9:08 AMthon says:
This is great! I have RB2 and while the drum kit is ok, I wondered if there was something that provided more of a real 'feel' or 'bounce' when hitting the pads. Two questions: -Does it make the kit quieter than the RB2 kit? I'm sure it's better than RB1, but what about 2? -Is the 'feedback' better? Would I be able to do a drum roll on it without hitting it so hard? Thanks!
Dec 3, 2008. 8:52 PMlucidn says:
Brilliant. Finally a way to fix the horrible Rock Band drumset.
Dec 13, 2008. 9:39 PMLego man says:
what is wrong with the rock band drum set? fyi: i am a drummer and i have never played the rock band drum set, so please excuse my curiosity.
Jan 7, 2009. 11:35 AMlonerayven says:
Well it's even worse for an actual drummer. But this is pertaining to Rock Band 1 drum set. The Rock Band 2 drum set is actually much much better. RB1 set is very low sensitivity registration for hit, thus you have to hit harder, which wouldn't be hard for a real drummer. The problem is, the drums are a layer of thin rubber or vinyl over a plastic shield with the hit sensor below, if you hit too hard you break that plastic shield and the sensor is either broken or disabled, if that doesn't occur before breaking the shield anyways. They are also really loud and clacky, requiring the game to be a very loud volume just so you can actually feel like your playing the drums to an extent, which should be the point of the game. But again, the RB2 set addresses alot of these issues, and the ION Premium drum set for 300$ is tenfold better than that even.
Jan 7, 2009. 4:40 PMLego man says:
well as a follow up on my last comment i just got Rock Band 2 for christmas and it feels nice...but not as good as a real drumset. yeah i have heard complaints about the RB1's drumset so i am happy i have number 2
Jan 1, 2009. 11:58 AMRichuu says:
I got to this instructable looking for info on quietening down the RB kit.. Interesting instructable, but why did you di it? What benefits does it bring? Also, a bit more detail on why you did each stage, why you chose the materials you did etc. Nice job though!!
Dec 4, 2008. 7:45 PMcaitlinsdad says:
Good work but you need to explain why or what the improved changes were. Not nagging but was interested in what you did. I'm not a Rock Band controller fan but I guess you wanted to enlarge the playing area for the controller. Does the mesh screen "pad" work any better for playing and how does it feel? It the response like real drums. How does the sensor work by picking up vibrations or loud sounds? Thanks.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:mikejl47
