3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Rock Band/Guitar Hero World Tour Microphone Adaptor
If, like me, you purchased the instruments for Rock Band and/or Guitar Hero World Tour, you'll have no doubt realised that using the xbox live headset doesn't compare to a propper microphone. But I wasn't willing to shell out żusb microphone, when I had regular karaoke mics lying around. So I set about making my own adaptor.
You will need the following:
1x 2.5mm (NOT 3.5mm) jack
1x 1/4" line socket*
Either 3 pieces of wire OR 1 piece of triple cored wire at least 6" long
Soildering Iron
Soilder
Volt Meter
An xbox 360 and controller
A microphone and headphones (to test)
I'd like to apologise for the lack of pictures as I forgot to have my camera hand as I was making this.
*You may ask why I've made a 2.5mm to 1/4" adaptor rather than to 3.5mm which is more common. Well, most karaoke mics are 1/4" by default and 1/4" to 3.5mm adaptors are more common than the other way round, so this seemed to make more sense.
Step 1Step 1 - Wire the 2.5mm Jack
This step is kinda easy. Just soilder the wires to each of the terminals on the 2.5mm jack. Once you've wired the terminals, use the volt meter on resistance mode to check that each connection is good and there are no short circuits. Then just slide the sleeve over and screw it on.
1 comment
Sep 10, 2010. 8:11 PMKindhamster says:
while this IS a good Idea, you may wish to specify that this is strictly for xbox 360, not wii or playstation.
Just a thought.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Davedamon
