DIY Room Temperature Detector
2,418
77
Posted
Introduction: DIY Room Temperature Detector
Now you can build your own room temperature monitor using an Arduino board. The circuit is a combination of an Arduino UNO board, LM35 temperature sensor, and 7 segment display. It will display the temperature on the 7 segment in degree C. It can be powered from any standard Arduino AC mains adaptor (9VDC), or from a suitable battery. First of all note that this circuit can not measure the temperature of the whole city or province.It can only measure the temperature of the surroundings!
Step 1: Things You Will Need
you will need arduino starter kit
you can buy kit from here
Discount coupon code:GBDADD
following things will required from the kit:
arduino uno.
7 segment .
LM35(temperature) sensor.
A buzzer
RGB LED module.
connecting wires.
A battery.
A registor.
A bread board
A laptop or pc having arduino IDE installed.
etc.
Step 2:
Now make the circuit according to given picture above.
connect 2nd pin to 9th pin to seven segment display.
arduino pin 7segment pin
2nd => e
3rd => d
4th => c
5th => dp
6th => b
7th => a
8th => f
9th => g
now coonect A0 pin arduino to 2nd pin of LM35.
now connect RGB led and buzzer to arduino uno pin no.0,1,13 and 12.
Step 3: Programming.....
Just copy and paste following code into Arduino IDE and burn the code into Arduino UNO///
inti=0;
intval;
int temp=0;
void setup()
Serial.begin(9600);
pinMode(2,OUTPUT);
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(7,OUTPUT);
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
pinMode(13,OUTPUT);
pinMode(12,OUTPUT);
pinMode(1,OUTPUT);
pinMode(0,OUTPUT);
digitalWrite(0,LOW);
digitalWrite(12,LOW);
digitalWrite(1,LOW);
digitalWrite(13,LOW);
digitalWrite(10,LOW);
digitalWrite(11,LOW);
void loop()
val = analogRead(A0);
float mv = ( val/1024.0)*5000;
intcel = mv/10;
if(cel<=30)
digitalWrite(0,HIGH);
delay(10);
//Serial.println("lower 30");
if(cel>30 &&cel<40)
digitalWrite(1,HIGH);
delay(10);
//Serial.println("Higher 30");
if(cel>=40)
digitalWrite(13,HIGH);
digitalWrite(12,HIGH);
delay(10);
//Serial.println("Higher 40");
else{
temp=cel/10;
digitalWrite(11,HIGH);
SevenSegament(temp);
i=cel%10;
digitalWrite(10,HIGH);
SevenSegament(i);
voidSevenSegament(int j)
if(j==0){
digitalWrite(2,LOW);
digitalWrite(3,LOW);
digitalWrite(4,LOW);
digitalWrite(5,HIGH);
digitalWrite(6,LOW);
digitalWrite(7,LOW);
digitalWrite(8,LOW);
digitalWrite(9,HIGH);
digitalWrite(2,HIGH);
digitalWrite(3,HIGH);
digitalWrite(4,HIGH);
digitalWrite(6,HIGH);
digitalWrite(7,HIGH);
digitalWrite(8,HIGH);
if(j==1){
if(j==2){
digitalWrite(9,LOW);
if(j==3)
{digitalWrite(2,HIGH);
if(j==4){
digitalWrite(9,HIGH);}
if(j==5){
if(j==6){
if(j==7){
if(j==8)
if(j==9){
Step 4: Power...
Now just give power from electric cell pack which is provided in kit.you will see temperature reading on seven-segment.
That's it.Enjoy.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
