DIY Rubber Band Pistol (Easy to Build)
Published
Introduction: DIY Rubber Band Pistol (Easy to Build)
About: I have a ton of fun making things... especially things that go BOOM! Whether it's 3D printing, welding, or just building cool stuff, I have a great time doing it.
Hey guys how's it going?!?!?!?!? This is a super simple to make rubber band gun that I have made since I was little! It does not have any moving parts for a trigger mechanism (which makes it so easy to build). It is cheap to make and doesn't require any power tools! This will be a short instructable cause it is very not-complicated to build.
Step 1: Materials and Tools
Materials:
3/4" Plywood (Plywood is the way to do it cause it won't split along a grain)
Boiled Linseed Oil (Easy to apply -- only 10-minute wait period)
#35 Rubber bands
Tools:
A saw of some sort. (power or manual)
Files are handy.
Sandpaper.
Step 2: Sketch, Cut, and Shape.
1: Cut a manageable piece out of your sheet of plywood.
2: Sketch the basic shape of the pistol.
Barrel -- 1" thick. Can be cut to any length you desire but anywhere from 5"-15" works best.
Pistol Grip -- 1.5" thick. 4"- 6" tall depending on the size of your hand.
3/4" Thick (set by the thickness of plywood)
3: Cut out using any tools at your disposal that will get the job done. Don't forget the groove in the front that holds the rubber band in place.
4: Finish shaping and smooth any rough edges with a file.
Step 3: Surface Finishing.
Sand till smooth and wipe down with Boiled Linseed Oil. Let sit for 10 minutes and wipe off excess linseed oil. You can instead use stain, a poly coating, or paint. It's up to you.
Step 4: All Finished!!!
Now you have an accurate and powerful rubber band gun which is easy to load and shoot. Multiple rubber bands can be loaded and shot at once to make semi-auto or shotgun like effect. Enjoy!!!
DISCLAIMER:
This video is purely for entertainment value, any and all replications of any experiments, projects, and creations or similar are the sole legal responsibility of the person(s) involved in replicating them. I can not be liable for any information or misinformation, wrongful use, damage to personal property, death or any circumstances that result from replication of any projects seen.
Woodworking Contest
This is an entry in the
Woodworking Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    2 Comments
    I love the great simple design :) Looks easy to reproduce.
    I also love that table with the green, did you make that too?
    Thanks! It's actually a stool. I did not make it but my Dad did. He owns Keystone Vintage Lumber and made it with recycled 100+ year-old wood. You'd think it would be uncomfortable but it is actually more comfortable than a hard flat surface.
