DIY Samsung SmartCam HD Birdhouse Enclosure
1,306
21
4
Published
Introduction: DIY Samsung SmartCam HD Birdhouse Enclosure
I have a few Samsung security cameras on and in my house. However, I wanted one at my front door and one at my back door. From a wiring perspective, there wasn't a good way to achieve this, so I decided to use the old "camera in a birdhouse" trick. From a distance, it just looks like a decorative birdhouse, but tucking a refurbished Samsung wireless camera was a cheap way to get video to my smartphone with motion alerts.
Please note that this is not a tutorial on how to build a birdhouse, only showcases how I integrated my security cameras into the birdhouse on a pedestal.
Step 1: What You Need:
For the birdhouse that was not as protected to the elements, I used a camera UV filter to cover the opening
For the custom pedestal, I used threaded pipe:
  • 48" X 3/4" Threaded Pipe
  • 3" x 3/4" Threaded Pipe
  • 2" x 3/4" Threaded Pipe
  • 3/4" T-Connector
  • 2 X 3/4" Pipe Flange
  • 3/4" Stainless Steel Screws
Step 2: Build the Birdhouse
The birdhouse kit that I used had an opening for the camera that was slightly smaller than necessary. I used a dremel tool to widen the gap slightly, but it's almost a perfect fit. I may end up using silicon to permanently attach the camera, but for now, it fits tight enough not to fall out.
Step 3: Build the Pedestal
This is optional, but a pretty cheap method for getting the birdhouse mounted off the ground.
I originally looked for decorative pedestals to mount the birdhouse to, but didn't find anything that I liked. I decided to build my own using 3/4" pipe, mainly so that I could hide the USB cable inside the pipe. Using a T-Connector, I was able to provide an exit for the USB cable at the bottom of the pedestal. Once of the birdhouse security cameras was sitting under a porch, and protected mostly from the elements. However, the second one was not as protected, and I used primer and paint to cover the threaded pipe.
Step 4: Plug It in and Magic Occurs
I built 2 of these. One for my front door and one for my back door. I did have power near each of these locations in a weatherproof socket. I have motion detection for my front door enabled, so I know when someone is at my door and I can look at them using the Samsung SmartCam app. I'm happy with the results!
*** For the camera that I used the filter, I had to disable night vision. The Filter basically just reflected the Infrared LED's, and you couldn't see anything. I have a motion detection on the outside lights, so for me, disabling the night vision was acceptable while using the UV filter to protect the camera from the weather.
    • Clocks Contest
      Clocks Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    4 Comments
    Where's the bird drone?
    Nice project but why not build the bird house and install the camera on the top like a dormer and then you can see anybody approaching the house and birds using the bird house all in one. Just an idea.
    Nice idea ... but please let us know the first time you get a "motion detection" event from a confused bird trying to climb through the lens :)
