loading
Step 5: Don't stop now...
With the bezel removed the rest is pretty easy. First off, there are four(4) more of those black Phillips head screws to remove, an upper and a lower screw on both the right and left sides of the cluster.
Go ahead and remove the screws and set them aside with the others, don't worry, if it's like mine, all eight(8) screws are the same.
NOTE: do not remove the two(2) small silver Torqs screws located just below the lower Phillips screws on either side of the instrument cluster. They can stay in place for this procedure.
Now here's where I deviated a little from the forum instructions. I didn't have to disconnect the cluster from the cable harness. Just tip the cluster forward slightly and you'll see the cable connector at the top rear of the cluster, just behind the Tach gauge. I was able to get enough slack in the cable harness that I could pull the cluster out and get access to the back, where the bulbs are located.
This is handy for another reason, since the LEDs are polarized, I was able to check them with the ignition on, to make sure that I got each new LED in correctly while I was installing them.
I did this just yesterday. FYI, most automotive (if not all) LED PC74 bulbs have resistors integrated otherwise it would be too much of a hassle to purchase. All the bulbs worked fine until today. The socket with thw previously burnt out bulb stopped functioning. And now the gauges are not functioning. Either the circuit board under the main fuse box is corroded or the plug was loose behind the gauges.
<p>Just a heads up...</p><p>You may want to look into adding resisters to those LED's since these circuits weren't designed for those components as OEM. There are sites that will give you the R values needed when you plugin the diode spec and circuit nomenclature (which you should be able to follow through each trace). </p>
<p>Great instructions, I have tried superbrightleds but they made some parts of the dash brighter than others. I came across a place called EnlightenOz, the bulbs they use have much more even light, they even had a kit for my car with the correct number of bulbs and everything! Here is there facebook page: <a href="http://www.facebook.com/enlightenoz" rel="nofollow"> www.facebook.com/enlightenoz</a><br><br>I ended up getting some more colours for my dash too</p>
Not mentioned in these instruction, but something I encountered on my 2002 Voyager is a second cable connected to the back of the instrument cluster. The wire harness mentioned in step 5 has plenty of slack, but the other cable (speedometer cable?) which was connected to the lower right corner (backside) of the assembly had little or no slack. So it was difficult to get to the bulb on the right side (temperature gauge), but I did manage to get to it. I also removed the plastic steering column cover which made it easier to pull out the cluster. It is held in place by 3 screws on the underside.
hey, great instructable, but just as a caution, I noticed that you said to put the gear shift in the lowest position. It is probably safe to say, either you were on fairly flat ground, you were on jack stands, or you put the parking brake on. The last one I mentioned is probably the safest idea to add to this or any automotive instructable, especially in case your or anyone else's vehicle is like mine. As they say, better safe than sorry right?
Yes, you're absolutely right, if fact I changed this step today (10/13/2012) to add the note about applying the parking brake. <br> <br>Thanks
Well, I guess I was wrong, something has started to happen to the LEDs that I installed. I'll update this project (or possible start a new one) to replace the LEDs. The first symptom that we noticed was that some of the LEDs are intermittently going on/off.
Did you find out why the LEDs were going off and on? Was there a problem with the LEDs or some other issue you can help me avoid? <br>Thanks! Ed
Right, here's what I found: of the 8 original LED &quot;bulbs&quot; that I installed, two had gone bad (one didn't light at all on the test bench and the other was very weak). I had pre-tested these LEDs before I installed them, and I had even ordered a couple extra, just in case. I suspect that a third bulb just wasn't seated properly or had worked itself loose. The way these &quot;bulbs&quot; are constructed (see the third picture in this Instructable - in the Parts and Tools step) could make for a loose connections if the + or (-) connections don't make good contact. Make sure the little +/(-) tabs are flexed up toward the tip of the &quot;bulb&quot; prior to installation. When you install them, give them a little back and forth twist to scratch the contact surface of the circuit board (instrument panel) to make a good connection. Hope that helps, and good luck with your project.
Thanks for the info. It's very helpful. So in the end, once you got 8 good LEDs, everything worked out fine? Thanks again!
Yes, 8 new, slightly brighter, LEDs are now installed and so far no symptoms of the previous failures.
How does this save $200, is it the price of the other bulbs? or is it something else?
Exactly what I thought! One can save about $200 by replacing old bulbs with new ones, instead of asking car dealer to do it. I don't think replacing bulbs with LEDs instead of bulbs, is much cheaper (little, but not much). So savings come from DIYing the job, not from using LEDs.
You also save with LEDs because once you've got them working, they should never have to be replaced. I think the OP might have gone with a more DIY approach, adapting his sockets to use bare LEDs with dropping resistors, but still a substantial savings over what a dealer would charge.<br><br>If I were rich and could find an honest mechanic, I'd never turn another wrench, but neither condition has yet been met. Firestone 'noticed' that my radiator hoses were 'soft' when they did an oil change. The estimate for replacing the hoses and flushing the cooling system was $300.<br><br>I could do that job--had it really needed doing--for about $30...in less than an hour.<br>
The dealer wanted approx. $240.00 for the parts and labor to do the bulb replacement (and they would have just used the standard bulbs). Others can attest to this pricing on the forum that I got the procedure. The bulbs at the dealer where around $6 ea., the LEDs were only $1.79 ea. (and I paid $5 for shipping). Hope that helps.
ledwholesalers.com
The manufacturer replacement bulbs are PC74 (a #74 bulb with a twist-lock base for mounting). I ordered #T1.5-B LED "bulbs" from superbrightleds.com, described as; "T1.5 instrument LED bulbs consist of a T1-1/2 (#73/74) standard miniature wedge LED bulb installed in a twist lock socket base 12 Volt DC - 100 degree beam pattern". I can't say for sure if the B8.5Ds or NeoWedge LEDs would work or not. PS: If you liked this Instructable, please be sure to give it a rating and vote for it in the Epilog Challenge contest. Thanks.
I got the lights replace in the center console and they really are a lot brighter than the OEM. Now on to the gauges. Thanks
Thanks again, now I've got the bezel off of the center console but I acn't figure out how to get the 3 wireing plugs out of their sockets. Does something have to be squeezed to release them. There is a red clip in each plug that looks movable.
It sounds like yours is a slightly different model, mine only had one wiring harness and I didn't end up disconnecting it, because I had enough slack in the cable to turn the instrument cluster around to replace the bulbs.
anchor887 says: Thanks for the great instructions & pictures. The panel in the picts looks like mine on my 2002 Chrysler T&C. My gauges in the corners, fuel & temp, are hard to see in the daytime. I'm considering using Superbrightleds B8.5Ds for the central console, Are the T1.5D's better? I think I need 4 NeoWedge 4mm for the H&AC switches and a 3mm & 4mm for the mirror & dimmer group. Any suggestions would be appreciated.
The lights in the last picture look uneven. How do they look in person? For the record, red lights at night are easier on your eyes.
It's from the angle that I took the pictures (due to the steering wheel). They look pretty even across all the gauges. Good tip about using red vs blue, maybe next time.
Do you still have the dimming function for the dash lights? (was there one to start with?) When I drive at nite, I turn the dash lites down really low cause I hate the eye strain from the brightness. Thanks for the great link!
I forgot to mention it, but yes the dimmer still works with the LEDs. Also, the company where I ordered the LEDs <a rel="nofollow" href="http://superbrightleds.com">http://superbrightleds.com</a> offers different colors for differed &quot;temperatures&quot; of light; White, Blue, Green, Red &amp; Amber.<br/>
About This Instructable
67,146views
39favorites
License:
Bio: I've always been a maker, mod-er, and tinkerer. I started out by taking things apart and then trying to put them back together. Most ... More »
More by fireballxl5:Calibrate your Garmin Edge 500 battery indicator Black & Decker Mower Wheel Repair Easy cleaning for the Garmin Premium HR Strap
Add instructable to:
