DIY Scara Robot Arm Robotic Draw Frame With 2 Stepper Motor
Published
Introduction: DIY Scara Robot Arm Robotic Draw Frame With 2 Stepper Motor
DIY Scara Robot Arm Robotic Draw with 2 Stepper Motor
Materials:
1 pcs 57 mm Stepper motor 1.8 degrees
1 pcs 42 mm Stepper motor 1.8 degrees
1 pcs aluminium alloy 90 mm x 90 mm 20 mm base
1 pcs aluminium alloy 100 mm x 42 mm 6 mm
1 pcs aluminium alloy 60 mm x 20 mm 20 mm
1 pcs aluminium alloy 100 mm x 22 mm 12 mm
Polyvinylclorua 32 mm x 10 mm x 35 mm make hole 9 mm
More Homemade Mini Laser Engraving Cutter‎ DIY 3D Printer Machine Frame here:
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
    • Planter Challenge
      Planter Challenge
    Hi.. Can you please provide the link/information on the code used to run the Robot Arm... or was it your own code?
