loading
Schlieren Flow Visualization is a method to see small differences in air pressure like those around a flame; essentially it allows you to *see* air. It is typically accomplished with super fancy mirrors that can cost upwards of $300. This instructable is about making a Schlieren Flow Visualization really cheaply and pretty easily. If you are curious about my failed attempts before I got it to work then visit my DIR Schlieren Flow page.
Here are all the components you need:
  • A pair of rigid page magnifiers (this $9 pair on amazon was perfect).
  • A cheap LED light, and something to attach it to, like a chair leg.
  • A *DLSR camera and books to set the camera on or a tripod
  • Cardboard+tape to make a stand for the magnifier.
  • Candles, or something hot/cold or otherwise interesting to look at
*other cameras might work too but I couldn't get the effect to work with my point & shoots.
Step 1: How It Works
The basic idea is you need to get something hot like a candle in the middle of some parallel light rays - then focus those rays back to almost a point – knocking out half of the rays that didn't line up exactly parallel. The first page magnifier makes the light from the LED parallel (collaminated) then the other one focuses the light back again. The camera is placed right where the light focuses and angled to the side so that some non-parallel rays are blocked by the aperture.
You need to position the camera carefully, but patience is an ample substitute for fancy equipment :O
Step 2: Mount the Components
All the elements need to be lined up in a row, using a nice long table will make access comfortable, but you could also use any hard floor.
Folding the cardboard into triangles and cutting a slit for the magnifiers was sufficient for holding them up straight, it doesn't need to be that perfect. The LED should point straight towards the magnifier, I taped it in place. With the LED on, moving a piece of paper back and forth in front of the magnifier will help you find when it is parallel (it won't expand or contract).
The camera should be held up so that lens just touches the point that the light rays focus. You could use a tripod, or just some books and a stool or chair like I did at first.
Step 3: Focusing the Rays
The trickiest part is focusing the rays. If you are off by a lot then you won't get any hint of the right direction to move the camera in. If you get close enough to see something though – move the camera to maximize the area of the screen covered while maintaining the camera at about a 45 degree angle. This above video shows what it looks like as the camera is moved around. It can look a little different depending on which direction the magnifiers are facing (they are not symmetrical) but the effect is still there no matter which way they face.
Good luck!!!
<p>Thank you very much, </p><p>this so simple technics has been very useful, </p><p>thanks again!</p><p>Marco (from Italy)</p>
<p>Thanks Marco!</p>
<p>I found an old telescope mirror I have not used for twenty five years and made a Schlieren rig. Although it uses slightly different materials the results are astounding. I will try your instructions, as well. Great write up.</p><p>https://www.youtube.com/watch?v=OvJ5q_gUfwk&amp;list=UUivJid6dvtQ9REao8Th2asg</p>
<p>Amazing! You can get much more super results from a mirror like that since it probably has much greater precision.</p>
<p>What frame rate is needed on the camera?</p>
<p>No special frame rate is needed. The videos you see are real-time and you can watch it unfold on your camera's screen.</p>
<p>Nice music)<br>And cool project)</p>
<p>This is really cool! </p>
About This Instructable
23,360views
127favorites
License:
Bio: I am a data scientist at Whoop, founder of Loud Bicycle an Awesome Foundation trustee, and a LanseyBrothers blogger. See www.Jonathan.Lansey.net to ... More »
More by jlansey:DIY Schlieren Flow Visualization
Add instructable to:
