DIY Scratch Awl - 2 Ways
1,224
24
Published
Introduction: DIY Scratch Awl - 2 Ways
This Instructable coincides with my entry into Mitch Peacock's ToolMake16. Originally I intended to make a an icepick. However I went with a 7 mm 01 Tool Steel rod and i think it's just a little too thick. These turned into more of an scratch awl/center punch, still a useful tool. I choose to make one out a acrylic and another inspired by David Waelder's icepick, using a bullet casing from a 30-30.
What you will need:
-- 4-12"s - High Carbon Steel Rod (i used 01 Tool Steel)
-- Handle material - you can use your imagination here - I used an acrylic pen blank and 2 spent 30-30 bullet casings
-- 2 Part 5-minute epoxy
-- Solder / flux
-- Torch
-- Sandpaper
-- Metal or Plastic polish
-- Lathe - I used to shape the acrylic handle but you could easily use other tools to achieve the desired shape
-- Drill - Not 100 % necessarily but it'll make your life easier
-- Bench Grinder - You could also use a belt sander or another method of shaping the metal.
-- Reciprocating Saw
Step 1: Get the Handles Ready.
Acrylic Handle:
Step 1 - Drill out the center of your blank, i find drilling on the lathe always hits dead center.
Step 2 - Mount on the Lathe. I mounted it on my pen mandrel, if you prefer to turn between centers that's fine.
Step 3 - Turn down the material to your desired shape. I mostly used a roughing gouge, and a carbide tool for finishing
Step 4 - Sanding. Everyone's favorite step. For acrylic pieces, I wet sand with 600 grit paper and then move to micromesh sanding pads which go up to 12,000 grit.
Step 5 - Polishing. I use a friction polish to bring out the final shine.
Bullet Casing
Step 1 - Sort through spent rounds to find a couple casings that are in good condition.
Step 2 - Set aside for future use.
Disclaimer: Always exercise caution when using firearms or any materials related to firearms. When using casings ensure that they are from spent rounds and the primer has already been fired.
Step 2: Getting to the Point
Step 1 - Cut your round stock to your desired length. I used a reciprocating saw but you can use whatever you want. Your length will depend on the handle you are planning on using.
Step 2 - Mount the stock into a drill. You could turn it by hand but I've found the spinning helps keep everything even.
Step 3 - Use your bench grinder to create a point in your round stock.
Ensure you quench often to avoid overheating (which could weaken the steel)
Step 3: Attaching the Handles
Acrylic:
Step 1 - Test fit your work. Make any adjustments necessary
Step 2 - Mix your two-part epoxy throughly
Step 3 - Apply the epoxy to the tang
Step 4 - Slide the spike into the handle
Bullet:
Step 1 - Ensure your torch is fueled up and ready to go.
Step 2 - Position the solder over the bullet casing you wish to use for a base, heat it up letting about 8-10 drops (use your judgement) fall into the casings.
Step 3 - Prepare your metal by applying flux
Step 4 - Use your torch to heat the outside of the casing; this will cause the solder inside to melt again.
Step 5 - Quickly slide the metal into the casing allowing it to cool.
Step 6 - Clean up overflow (if any) - you can reheat until it falls off or use a file.
Step 7 - Slightly pinch the top of the second casing; this will cause a tight fit for the lid.
Step 7.5 - I haven't done this but am exploring the option of pressing a magnet down into the lid casing to make it more secure
Step 8 - Optional - Clean up the casing. Use some brass polish to bring the shine out. Leaving it more natural is always a solid option as well.
Step 4: All Done
With that you are finished with two different scratch awls / center punches. There are a ton of other ways to get this done. I'd love to see how others have done it and where I can make improvements. I don't work a lot with metal but am always looking to learn more. I hope you've enjoyed this Instructable and look forward to doing more in the future. If anyone has any questions or if I can make anything clearer please let me know.
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
