3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Sheetrock Hoist for about $100
  • last photo ←
When I was building the house I had decided to hang all the sheetrock myself and sub-out the taping and texture because that would be just too big of a job to take on by myself.
The house has ten foot ceilings and the time before I had rented a sheet rock hoist it wasn't until I got home and realized it was meant for eight foot ceilings and I had to make piles of pallets with a sheet of plywood on top to reach the front garage ceiling and I tend to drag projects out forever so I try and avoid renting things if I can buy it or make it for the estimated cost of a rental. I've always loved to weld things since I was a teenager so I made a trip to the local salvage yard and got some scrap pipe and tube steel which ended up being about $40 since you pay by the pound. I then went and bought a cable hoist like would be on a boat trailer to put the thing in and out at the dock and 4 heavy casters and pulley with a bracket included for about $50.
Step 1The Lifting Jack
The Lifting Jack
The basic working component is a two inch pipe about five feet long and a piece of square tube steel, thick walled and I think is about an inch and a half across that fit loosely inside the two inch pipe but not so loose it would just float free since you want it to stay inline as you extend it. By dumb luck the pulley I chose had a bracket spaced wide enough for the square tube to fit through but snug enough to keep the tube aligned so it couldn't spin and get the cable wrapped up and it held the pulley pretty close but not touching the tube.
I never question dumb luck!
21 comments
Jan 7, 2008. 7:51 AMcharlessenf-gm says:
Nice job. House sounds great, too. I glued OSB (7/1") on the walls of my barn and intend to repeat on the interior surfaces of the walls as well (good nailing surface or a shop) and structurally - its becoming like a rock. They sell teflon tape in 2" widths that is thicker than used for threading pipe fittings nd could be glued on the surface holding teh sheets so as to avoid rough welds and even some movement of the sheet once "up." I use it on some woodworking jigs that have to slide along the table saw top and such. Good job ad good instructions//pictures.
Jun 15, 2008. 2:32 PMEsmagamus says:
Well, my house is like a rock! And made of stone too! The walls are about 70 cm (over 3 ft.) thick and stand for over a century. Taking into consideration the contractor's bad skills when we added a living room, I trust the old part better than the one he built. As for building with wood, do it like you were building a ship. As strong as that.
Dec 9, 2007. 9:52 PMleebryuk says:
I always wondered how this was done. I'm impressed. I need to take a welding class soon. Excellent Job.
Jun 15, 2008. 2:36 PMEsmagamus says:
Maybe not. If you are considering MIG welding, that should be pretty easy. I've learned SMAW (shielded metal arc-welding) by myself, just with the help of some books and guitar playing (you'll understand this part when you start welding). Hell, I once asked a blacksmith to weld a stainless steel pipe to a beer keg and he melted two holes in the metal in three seconds! I decided to take it home and weld it myself. You know what? I didn't need more than a dozen welds worth of experience to weld better than that... pro!
Jun 15, 2008. 10:03 PMleebryuk says:
I've had friends who have done that. My stuff would be structural repairs and modifications on high stress areas of cars. There's nothing fun about a sub-standard weld on a car coming loose at a critical moment. On a side note, I've been watching the developments on structural expoxy for cars. It's good for large surface area bonds. Pretty neat stuff. Thanks for the encouragement
Jun 16, 2008. 11:44 AMEsmagamus says:
There is nothing funny about welds failing, but there should be nothing stopping you from learning how to make welds of lesser importance before taking those classes. A person that tries to learn by itself is better prepared to evaluate problems when they come up, so I advise everyone to try to learn things alone. Besides, it's always good to have a proper knowledge base before taking any classes. Sometimes, the people that are supposed to teach know less than their students.
Jun 16, 2008. 1:28 PMEsmagamus says:
Certainly there are a lot of motor skills to be mastered and that can't be learned by reading, but I was lucky to have found some manuals before I learned how to weld that gave me an insight on what skills I had to learn and even before I got that old SMAW welder in working order, I had already trained those skills. And remember that stick welding is the most demanding process on motor skills, especially when inverter machines ar not used.
Sep 17, 2008. 10:02 AMwildwaters says:
Sheetrocking is fun o new construction :) I did it for awhile and used a lift sometimes. what was teh costing on this if I may inquire? You can get a lift for what 600 bucks? Btw rock on brother :) Sheetrocking is a thrill sport lol. -anthony
Sep 17, 2008. 10:04 AMwildwaters says:
Oh, why'd yah put that strip on the wall at the top? Wasn't it wide enough to put in the center and double flat it?
Sep 22, 2008. 1:50 PMwildwaters says:
>.< Hehe professional drywalling can be a monster :) we would put the joints the middle because with the new tools you can easily make it look smooth with a butt - seam joint. just means a wider joint. 100 dollars would be quite a deal for a lift. Nice job :)
Sep 12, 2009. 9:29 AMmagickaldan says:
Looks great, I might have to build one for the house I'm building. 2 story 3 bedroom 1 bath.
Dec 9, 2007. 10:33 AMGorillazMiko says:
very very awesome instructable! super cool! pretty pricey, but its worth it!
Dec 8, 2007. 9:15 PMdarkmuskrat says:
Im happy for this instructable...But sad I might be doing this because of a leak in the ceiling :(
Dec 8, 2007. 8:09 PMshooby says:
Great instructable, thanks.
Dec 8, 2007. 6:07 PMtheRIAA says:
pretty impressive... sheetrocking doesn't sound very fun...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
81
Author:Senseless
http://senseless.livejournal.com/ I've been attempting to build a house mostly by myself for the last five years... I finally more or less finished it before the bunker project and after recover...
more »
