DIY Short Circuit (Overcurrent) Protection
24,146
217
23
Published
Introduction: DIY Short Circuit (Overcurrent) Protection
About: Awesome Electronics Tutorials, Projects and How To´s
In this project I will show you how to create a simple circuit that can interrupt the current flow to a load when the adjusted current limit is reached. That means the circuit can act as an overcurrent or short circuit protection. Let's get started!
Step 1: Watch the Video!
The video gives you all the information you need to recreate the protection circuit. In the next steps though I will give you some additional information.
Step 2: Order Your Components!
Here you can find a parts list with example seller:
Amazon.com:
1x Relay (12V one with 2 changeover contacts): http://amzn.to/2v8vHyT
2x PCB Terminal: http://amzn.to/2uKP6VG
1x LM358 OpAmp: http://amzn.to/2v8RfLx
2x BC547 NPN Transistor: http://amzn.to/2u9yW4y
1x 5mm green LED: http://amzn.to/2hdv4OQ
1x 1N4007 Diode: http://amzn.to/2hdAAAU
1x Tactile Switch (NC): http://amzn.to/2uNZBpm
6x 1kΩ, 2x 20kΩ Resistor: http://amzn.to/2eYvgAA
1x 10kΩ Trimmer: http://amzn.to/2eYBArS
1x 0.1Ω Resistor: http://amzn.to/2eYRsdK
Ebay:
1x Relay (12V one with 2 changeover contacts):http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
2x PCB Terminal: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x LM358 OpAmp: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
2x BC547 NPN Transistor:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 5mm green LED:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 1N4007 Diode:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Tactile Switch (NC):http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
6x 1kΩ, 2x 20kΩ Resistor:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 10kΩ Trimmer: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 0.1Ω Resistor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Amazon.de:
1x Relay (12V one with 2 changeover contacts): http://amzn.to/2uK2t8g
2x PCB Terminal: http://amzn.to/2viTnkl
1x LM358 OpAmp: http://amzn.to/2uNMsN6
2x BC547 NPN Transistor: http://amzn.to/2vj6qCy
1x 5mm green LED: http://amzn.to/2vbPfSn
1x 1N4007 Diode:http://amzn.to/2uO2kiL
1x Tactile Switch (NC): -
6x 1kΩ, 2x 20kΩ Resistor: http://amzn.to/2uNJ4BH
1x 10kΩ Trimmer: http://amzn.to/2uKc9j5
1x 0.1Ω Resistor: http://amzn.to/2eY98qa
Step 3: Build the Circuit!
Here you can find the schematic of the circuit along with pictures of my finished perfboard layout. Feel free to use them as a reference for your own circuit.
Step 4: Success!
You did it! You just created your own short circuit (overcurrent) protection circuit!
Feel free to check out my YouTube channel for more awesome projects:
http://www.youtube.com/user/greatscottlab
You can also follow me on Facebook, Twitter and Google+ for news about upcoming projects and behind the scenes information:
https://twitter.com/GreatScottLab
https://www.facebook.com/greatscottlab
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Planter Challenge
      Planter Challenge
    3 Questions
    .can i program it using arduino uno to set a maximum range of current it will trip?
    What actually this project work. As i give 10v supply to it and my microcontroller required only 3.7 volt than what happen . And if i give 2v than what happen
    Hello,
    very nice tutorial. What is required to control reset logic (handling overcurrent error state) with 3.V programmable logic e.g. from an arduino? Is it necessary for the coil VCC to have the same level as load circuitry (12V)? If not, there could be a buffer at the comparator output converting 12V to 5V and driving Q2. Tactile switch could be replaced with just another transistor driven by the GPIO. What do you think?
    23 Comments
    Hello Sir
    Im a electronics engineering student from philippines. I am currently working on AC short circuit and overload protection circuit. Im looking for possible circuits that will suit for my applications.
    can i use this circuit?
    thanks in advance..
    Hello
    If you guys made pcb for this circuit please share with us.
    Thank you
    hello
    I make this circuit but it's didn't work I don't know why Because everthing looks okay so please someone look at pictures and tell me why it's not working.
    thank you
    IMG_20171208_205104.jpgIMG_20171208_205056.jpgIMG_20171208_204948.jpgIMG_20171208_204839.jpg
    Could you upload a higher res schematic or one were it is zoomed in a bit. The one up now is a bit hard to read due to pixelation
    the differential amplifier circuit on the vcc side does not work with the lm358
    hello
    Thanks for sharing your awesome project.
    I didn't find 10 pin relay but I find this 8 pin.
    Could you please tell me how to use it on circuit or send me new schematic with this one?
    Thank you
    hey scott, i want to adapt this circuit into my lm317 variable power supply, how do i keep the value the same while still being able to change the voltage of my supply??
    also how do yo make your circuit's? i tried eagle, fritzing and my head but i can't nice PCB's
    If you design a lab psu then you should add current limit feature which will serve you as short circuit limit as well.
    Hi, I tried to adapt your circuit to 5V. The main problem is that the LM358 requires "head room" of 1.5V to Vcc on its output, which isn't of much concern with 12V but becomes a major issue at 5V.
    I ended up putting the 0R1 sense resistor between the load and GND rather than between Vcc and the load, and used a simple non-inverting amplifying configuration for the first op-amp instead of a differential amplifier. This approach should work equally well at higher Vcc, and it even saves a few parts.
    Have I missed something? What do you think?
    Excellent!! I'm putting this in the To Do list. One question: why do you push the reset button twice? I've been watching the video and still don't understand why you push it twice. Isn't it supposed to be a one-touch reset?
    It's because he is using a switch that acts as a toggle switch but as a button so when he presses it once it breaks the connection and stays that way so he has to hit it again to reset the switch back to the closed state which it will keep until he touches it again.
    Heheh, you're right. I see now it's a push-on/push-off button. Thanks!
    not beyond my capability to make but...
    Is this limited to 12vdc? Is it capable of being scaled for use with a 30vdc LED for example.
    Yes, that is possible. You just need another relay.
    Great video and educational too. Keep up the good work, God bless.
    You make the best videos, and your circuit drawings are text book perfect. Judging from your accent and penmanship, I would say German. I spent 7 years in Germany. Mannheim, Baden Wuerttemberg to be exact. Best time of my life. Whenever I hear the German language or accent, I'm reminded of that beautiful country. Great work as always.
    neat project , coll willbe on my list to do , please some specs for voltage , amps safe ratings
    I've been working on something similar, it uses an NE555 timer and a P-channel MOSFET instead of a relay to break and latch the circuit. Thought it might be another way to solve this circuit breaking problem (other than the fixed solution of using a resettable fuse). What do you think?
    This is a simple circuit the can save many loads from destruction. But sure, if your load can explode within a couple of ms then go for a MOSFET.
