Introduction: DIY Shuriken Throwing Stars
Make functional Shuriken throwing stars out of cheap tin disks from a hardware store.
Step 1: Materials
First off, I assume NO Responsibility for injuries you inflict on yourself or others in the making of/use of this item.
Materials You'll Need:
1.Grip-Right Fasteners tin disks ( I don't have the box to them anymore, but they're about 2-3" in diameter and you can get them at Home Depot ect for a few dollars a box(of 100ish))
2.Hammer
3.Scissors
Step 2: First Cut
First, cut 4 slits into the disk at 90 degrees from each other. Make sure not to cut all the way to the center.
Step 3: Second Cut
Next, cut another 4 slits in between the first 4.
Step 4: Bending
Now, bend every other leaf on the star.
Step 5: Third Cut
Now cut points in the extending leaves.
Step 6: Flattening
Now, hammer the star flat to make it easier to throw
Step 7: Final Notes
Now you're done! Try googling for throwing techniques or something.
Since this metal is very thin, it is prone to bending when thrown at a hard surface.
If you have any sharp egdes like these, throw it away! If you're not careful the star will dig into your hand when you try to throw it.
The Instructables Book Contest
