DIY Simple Wireless Charging Stand
Published
Introduction: DIY Simple Wireless Charging Stand
About: I am a 12th std student,and i like doing creative things it could be electrica, electronics, tech, carpenting, painting etc....
We all have seen wireless chargers which use resonance coupling to charge devices. But here is a phone charger which can be used to charge most of mobile phones. It works due to contact between two terminals........... In this charger a USB b type pin must be connected to the phone and has to be placed on the stand ,due to contact between terminals phone charges! Its not a big deal...
making this instructable is very easy and requirements are easily available.
Step 1: REQUIREMENTS
  • SUN BOARD (PVC FOAM SHEET)
  • MICRO USB PIN (male and female)
  • some thin uninsulated wires ,soldering iron
  • expory putty compound(M-seal)
  • glue, paint,and some tools
Step 2: DRAW YOUR DESIGN
You can make your on design....how ever you want
while sketching make sure that you make it suitable for all phones,by expanding side grips.
Step 3: CUT THEM ALL
Cut all the pieces using a cutter.
be careful while cutting.don't cut them slantly,it would look ugly
Step 4: GLUE ALL THE PIECES
Glue the parts
  • Parts of stand
  • Two grips
Step 5: MAKING THE BASE TERMINALS
Now lets make contact terminals.
I have used soldering lead to do this because is can be bent easily.
  • glue it to a small piece of sun board as in picture.make two pieces
  • And now attach it to previosly made base holder.
  • make a hole at lower base of stand for usb pin or for charger's input
  • And finally glue the holder to stand
Step 6: MAKING THE CONNECTER PIN TO MOBILE
From a old data cable remove the micro usb pin
  • solder the two terminals with a uninsulated wires to make contact terminal
Step 7: COVERING THE PIN
  • Take two equal parts of putty mix them evenly to form a compound
  • Apply it on the pin except the inserting part
  • Give it a good shape...Let it harden.
  • After hardening rub it wit a sandpaper and give nice finishing
Step 8:
Now bend the terminal wire to both sides
Step 9: ATTACHING THE SIDE GRIPPERS
According to your design .
  • place the grippers on stand.
  • take a small piece keep it over and screw it or pin it
Step 10: THE MOST IMPORTANT THING-CHECKING THE TERMINALS
The important thing is the terminals, so it should be rightly aligned.
  • align the terminals at the center of base.
  • connect them correctly.
  • the right side of the terminal should be +ve for usb male pin
  • the most left terminal is GND
  • the other terminals are not necessary for charger
Step 11: PAINT JOB
  • First lightly sand the body with sand paper.
  • apply a coat of primer
  • rub it again with sand paper to give smooth finish
  • Apply paint of your choice.
  • Do the same with usb pin
  • Fix all the parts
Step 12: CHARGE YOUR PHONE
Its finished!!!!!!!!!!.
Enjoy your wireless charger stand....
THANK YOU FOR READING. SURE COMMENT ON THIS
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    2 Comments
