DIY: Simple, Efficient Wind Turbine Rotor
23,816
36
10
Published
Introduction: DIY: Simple, Efficient Wind Turbine Rotor
About: "The Mak3rs (Pvt.) Limited". A leading company Solar Energy systems and in 3D designing, scanning, prototyping and printing services in Pakistan. A company established in 1999 by three brothers and three fri...
in this instructalbe i'm gonna show u how to make a Simple & efficient wind turbine rotor here is the video of it:
For more updates visit my blog at: http://engineerlhr.blogspot.com/
Step 1: The Selection of Materials
i used a 8.5" dia and 3ft. long PVC pipe to make the blades, i used a washing machine base to mount these blades on it!!...
Step 2: Cutting of the PVC Pipe
i divide the pipe in 6 equal parts as shown and cut out 6 blades out of it....
Step 3: Final Shape of the Blades
this is the final out come:
Step 4: Used Nuts and Bolts to Assemble the Rotor
Final step is Using nuts and bolts to assemble the rotor
    • Casting Contest
      Casting Contest
    • Planter Challenge
      Planter Challenge
    • Clocks Contest
      Clocks Contest
    10 Comments
    might i suggest you angle the blades to have a better pitch.
    that way more energy will be cought!
    Not true, at higher rpm's a lower pitch is more efficient.
    Excellent. I made a rotor almost exactly like yours to drive a stepper motor and it works really great. ( considering that I made it all at almost not cost ). You can see mine here:
    http://infomultiverse.com/diy/electricity/windpower/diy-wind-generators.php
    Well done. I used to make mine from sheet metal. This appears to be cheaper and much better looking.
    How do you know where exactly to cut the pipe for the most efficient blades?
    Great presentation and that convince me to make my own wind turbine. Thank you so much.
    My pleasure!!... Best of luck for ur project!!!
    This is a great Instructable, but you need to add a main image of the final project to the intro step. Please do that and leave me a message when you have so that we can publish your work.
    Thanks!
    hi randofo... I've added the final project images....plz publish it...thanks!!
