DIY Single Sheet of Plywood Rocking Chair
5,352
47
8
Published
Introduction: DIY Single Sheet of Plywood Rocking Chair
About: My name is Aaron Massey and I'm the DIY guy/ handyman behind mrfixitdiy.com. I focus on making fun DIY project and Home Improvement videos for a digital audience.
In this project I'll show you how I turned a single sheet of 3/4" plywood from the local lumber store into this beautiful and functional DIY rocking chair using minimal tools.
Step 1: Materials and Tools
This project really only consists of a single sheet of 4’x8’ ¾” plywood. There are many options out there for plywood and you can spend as much or as little as you like on the plywood. I chose a simple exterior rated sheet of plywood but you could also use marine plywood or something cleaner for finishing like Baltic Birch or finish grade plywood. It’s up to you!
Tools Required:
· Tablesaw (optional)
· Circular saw & jigsaw
· Compass or something to mark radius cuts
· Tape measure
· 4 ft level
· Pencil
· Clamps
· Wood glue
· Drill/ driver and bits
· Wood screws (2” or 2.5” inch)
· Orbital or belt sander
· Router and roundover bit (optional)
· Wood filler (Optional)
· Paint, stain, or weather sealant
Step 2: Making the Cuts for the Legs
To get started you’ll need to rip the plywood into the necessary pieces to make the cuts more manageable. You could use a table saw, circular saw, or track saw for this if you have one. Rip the sheet slightly off-center lengthwise so you have 1 piece that is 28” x 96” and the other 20” x 96 inches. (See the image above for exact measurements)
Once you have your two pieces, cross cut the larger of the 2 pieces in half creating 2 – 28” x 48” pieces. I recommend clamping the 2 pieces together from here so that you can cut through both pieces to create matching legs.
For the arched cut on the bottom of the legs I recommend using a piece of flexible material to mark your cut lines. The ends of the arc should be 2.5” from the edge of the plywood and the bottom should just touch the edge of the plywood to create the arc. (See video for reference)
Lay out and cut the legs out as shown using a circular saw and jigsaw and then sand them down using an orbital or belt sander. Once you have one set of legs cut, use a piece as a template to mark the next cuts.
Step 3: Prep and Glue Up
With the legs cut out, stack them all together and sand them to make sure they are all uniform.
Use wood glue and clamps to glue the legs together. Each leg consists of 2 identical cuts. Apply plenty of clamps and extra weight to glue the legs together.
Step 4: Prepping the Seat and Seat Back
While the glue sets up on the legs, cross cut the remaining 20” x 96” piece of plywood into (4) pieces. (2) @ 30”x 20” for the seat back, and (2) @ 18” x 20” for the seat.
Once you have those cuts made, glue and clamp them together into their components.
Once the glue is dry on the seat back you can cut out the opening (optional) if you want to. The opening is a decorative feature so it’s up to you if you want to include it or not. The opening in the back is 12” long total and 2” wide in the center of the seat back. If you choose to include it, mark and cut it out with the jigsaw.
Step 5: Assembling the Legs and Seat
For assembling the chair, I recommend putting it on nice flat surface and attaching the seat bottom first. Turn the chair on it’s side and layout the seat. The seat pitches backward which you can lay out by measuring 18” at the seat top to the front of the seat, and 16” to the top of the seat in the back. Make sure your legs stay aligned when mocking up the seat so that it is even.
Once you have the seat in position. Pre-drill some pilot holes and attach the seat with 2”-2.5” wood screws & wood glue.
Step 6: Adding the Seat Back
To add the seat back, slide it between the legs and tilt it back so that the backs of the arm rests intersect with the middle of the seat back. You should have somewhere in the realm of 105 degrees between seat back and tops of arm rest. Once in position, drill pilot holes, glue, & screw the seat back in place.
Step 7: Finishing
And here’s the finished product! Because I used relatively inexpensive plywood I chose to paint the chair with some exterior grade paint after filling the screw holes and imperfections in the plywood with wood filler. It’s your choice how you choose to seal and finish the plywood but I’d recommend several coats of whatever finish you choose so as to make sure you have ample protection from the elements!
I’m really pleased with the way this chair came out for using a single sheet of plywood and very minimal tools. It’s a fun project to tackle and you can really toy with the design and finish to get the look you want!
If you liked this project, check out some of these other outdoor projects:
DIY Vertical Pallet Garden
DIY Paver Walkway Installation
I hope you enjoyed this project and see that you don’t have to have fancy materials or tools to knock out a unique project! If you enjoyed this project, please consider subscribing to my YouTube Channel.
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    8 Comments
    - Pretty neat - makes me curious - on the sheet cut diagram ... why were the 'trapezoid' pieces -NOT- butted against one another to reduce the number of cuts by - three (substantial reduction). - I see the 'decorative' cuts as optional (and any number of shapes one likes). - I always like seeing these single sheet projects.
    Not sure. Just the way I laid it out at the time.
    Nice! But I can't stop thinking you will rock over and end up on your back.
    I tried to and it's never happened.
    I was thinking the same but I think it's because of the angle of the photos... but if you watch the video it looks that would be hard to do.
    really I have built rocking and the dinamics with the rokers don't add up/
