DIY Single Wheel Bicycle Trailer Easy
3,025
31
4
Posted
Introduction: DIY Single Wheel Bicycle Trailer Easy
Here is my easy DIY Single wheel bicycle trailer. It took about 2 hours of work up to this point where the drop out legs were installed.
Step 1: The Wheel Assembly and Cargo Area.
I used the fork from a small childrens bicycle for the wheel assembly. I found the bike on the side of the road. The one good wheel and the fork where used. I used the hole through the Y of the fork (most bikes have this) and bolted it to the cargo frame I used a 3 inch u bolt to hold it and the other end of the fork. this took no time to assemble.
Step 2: Making the Tongue
I used a 2x3 3/4 the length of the cargo frame for a tongue. I screwed it in using appropriate length screws. I cut angle 1x2 pieces to add support for sides from tongue. I drilled a hole for the pin to attach to my custom made pull behind bicycle Reese hitch. Its important to have a strong tongue that has no roll or left to right movement or shift. My hitch has a lip to slide the tongue on and drop the pin in. I made it so it can be tightened to help heavier loads. The 2x3 fits super snug as it should to have good support and balance. I added some small simple sides from salvage wood. The sides are a must to hold cargo in good.
Step 3: Adding Drop Down Support Legs
I simply used 1x2 wood cut to size. I used 1x2 framing brackets and a pin on each side to attach the legs which are just wood blocks. I am thinking about using a long bolt on each side through the bottom to make the legs adjustable in size for rough ground. It stands plenty strong to load and unload. The legs are easily spun up and strapped in place for traveling. This is my progress so far. I plan to paint, add hooks for strapping and a tarping system to keep cargo dry.
  • Sew Warm Contest 2018
  • Gluten Free Challenge
  • Minecraft Challenge 2018
4 Comments
Cool! Got any close up photos that show how this is attached to your bike? I'm curious to see that set-up! :)
Thank you. I am most proud of my hitch system. It wasn't hard at all. It is a two way system that has a seat height over the wheel mount for a high hitch and a Reese style hitch at the bottom that can handle a person standing on it with ease. I have trailers tow differently so I made this.
Cool! Thanks for sharing these pics.
I made a trailer a few years ago to tow around one of my kids. And ever since, I've been curious to see peoples' homemade hitch solutions.
Wow, This is really cool! Good luck ~Momoluv
