DIY Smokehouse
49,938
547
6
Published
Introduction: DIY Smokehouse
About: Curiously creative expert mess maker who is not afraid to try anything a couple of times to get it right. who is not afraid to try anything a couple of times to get it right. My specialties are inventing thi...
Yes, with a pile of old pallets, less than $100 and a bit of work, we built this really cool smokehouse. 3' x 3', it is big enough to smoke a whole animal, or at least a few big trays of meat plus some links of sausage.
I love this project - It still amazes me what you can build with repurposed wood and how great it looks. We really wanted to make a big DIY smoker, but most of the plans we looked that showed you how to build a smokehouse were too small and/or they called for using quite a bit of expensive materials. We never found plans that really met our requirements, so we ended up making our own.
Our considerations for DIY smoker plans were:
  • size - it needed to be big enough to a lot of items at once and also smoke large items
  • cost- it needed to be as inexpensive as possible while still allowing you to smoke meat well
  • skill level required - it needed to be something you could do with basic woodworking knowledge
I don't know if you have ever smoked meat before, but it is a rewarding, yet time consuming task. Since your meat will be preserved, and therefore good for a long time, it makes the most sense to be able to smoke a lot at once. After determining how much wood we needed for a decent size smoker, we decided to go with repurposed pallets. For less than $100, we were able to put together this great smokehouse that can hold a ton of meat. Multiple racks for smoking as well as a place to hang sausages, you can even hang a whole deer in it if you like.
Follow me here on instructables. I will be publishing more. Check out my DIY site for more tutorials
Here is a link to the
PROJECT VIDEO on my site
How to Build A Smokehouse
I also have some other instructables here you should check out, and a good tutorial on How to Make a Paracord Belt
Follow me on Facebook
https://www.facebook.com/diyready
Supplies You Need:
  • 20-30 pallets, deconstructed (need pallets? read this post on how to find free pallets and this one on how to find safe pallets)
  • 2 1/2 inch screws *you should choose a good outdoor screw, we used plastic coated decking screws
  • aluminum flashing
  • corrugated tin for roof (4'x3') *this must be raw metal, not galvanized
  • heavyduty tin foil
  • roll of aluminum screen
  • handle (for door)
  • hinges (3)
Tools You Need
  • reciprocal saw with bimetal blade (used to take pallets apart)
  • drill gun, preferably a cordless one
  • drill bits 1/8 bit and countersink bit
  • measuring tape
  • metal/tin snips
  • utility knife
  • Skil saw or table saw
  • Staple Gun
  • Safety Glasses
  • Work Gloves
test
DIY smoker: Supplies and tools you will need for the project
paracord
Deconstructed pallet pieces, cut to size, aluminum mesh screen and corrugated tin for roof. (Only use raw metal, not galvanized.)
diy-paracord
Pictured are the deconstructed pallet pieces, both the pallet panels (shown on left) and the 2x4 pieces of pallet, all cut using the dimensions in our cuts list
Step 1: Take the Pallets Apart
Select Your Pallets and Take Them Apart
There are a few challenges when you use free, repurposed materials. The wood you get is not consistent, often very dry, sometimes warped. It splits easily. It is far from perfect, but it is free. You will need 20-30 pallets for this project. We recommend you spend some time looking for ones without too many broken slats and without wood that is too visibly warped. It is fine if you do not do this or are not able to find perfect pallets (those do not exist) You wood may be a little warped, but that is fine. Your smokehouse will not be perfect, but it will smoke meat. You will want to get a few more pallets than you think you need in order to get the best materials. Pallets usually range from 42"-48" and 3'x3' design should allow you to build this when you use pallets in this size range. The 2x4s in most pallets are typically 4' - 5' long and they have cutouts for a forklift. The cutouts are fine. If you need to, you can sister two boards together, which we explain further in our DIY Smoker Video.
Pallets come in many shapes and sizes. Each one is little bit different, and some are in better shape than others.
Where To Get Pallets? Check out our article: Where To Get Free Pallets
How To Know If Your Pallets Are Safe ? How To Tell If A Pallet Is Safe To Use
Deconstruct your pallets. We recommend you use a reciprocal saw with a bimetal blade that cuts through nails to do this. Trust me, this is the easiest way. View our tutorial and video on The Easy Way To Deconstruct A Pallet for step by step instructions.
A reciprocal saw with a bimetal blade makes pallet disassembly much less work than a pry bar.
You place the blade under each slat and cut, leaving you with the 2x4 planks that are between the slats.
Step 2: Cut Clean Ends on Board and Make Cuts Below
Once you have your pallets deconstructed, you need to make your cuts. Start by making clean cuts on the ends of all your pallet boards. You should only need to remove a little bit. We chose our 3' design to accommodate for this loss of wood from your pallets.
CUTS LIST
Cut these from 2x4s
(part 1) 2 top braces front and back @ 33”
(part 2) Door frame 2 pieces @ 70”
(part 3) Door frame 2 pieces @ 29”
(part 4) Wall frame front 2 pieces @ 6’
(part 5) Wall frame back 2 pieces @ 5’ 6”
(part 6) Back frame 2 pieces @ 5’4” 1x1
(part 7) Shelf supports 8 pieces @ 33”
(part 8) Shelf frames 8 pieces @ 32 ¾”
(part 9) And 8 pieces @ 30 ½ “
Cut these from Pallet Panels
(part 10) Left side @ 36 ¼ “
(part 11) Right side @ 34 ½ “
(part 12) Door @ 35 ¾”
(part 13) Back @ 35 ¾”
(part 14) Roof @ 38”
(part 15) Vent covers 2 pieces @ 18” to 24”
(Part 16) Bottom front brace 1 piece @ 36”
Corrugated Metal roof 4’x3’
smoke-candle
You will want to make clean cuts on the ends of your pallet boards. You should not need to cut too much off the ends.
project
When you remove the split ends of the wood, you should have a clean cut that looks like this.
PREDRILL AND COUNTERSINK SCREWS:
Depending on the condition of your wood you may need to pre-drill and counter sink ALL screws to ensure the wood does notcrack. We highly recommend you do this when using repurposed wood.
Step 3: Layout and Secure Racks
You will be making two sides frames here that also have cross pieces that will hold your racks. This smoker utilizes a neat design - the racks make the structure itself, and you can even easily adjust the rack heights in the design. The parts that hold the racks in place end up being the ribbing that holds the frame in place. We marked ours at 24", 36", 44"and 52" so we could place bigger meats close to the fire and smaller meats further away. You can even add hooks at the top for sausage if you allow enough room to hang. The only important consideration is your firebox, which we set at 24" NOTE: Make sure your fire box fits under the 24” bracing. Adjust your shelves as needed. These measurements are not set and can be placed at any useable height as long as you allow ample room for your firebox.
Assemble and secure:
Take one each of (part 4- Wall frame front, 6’)and (part 5 - Wall frame back , 5’ 6”) square the bottoms, and secure 4 pieces of (part 7- Shelf Support, 33") at 24”, 36” 44” and 52” When securing parts 7 to part 5, leave a 1 ½” gap for part 6. You will repeat these same steps for the second side, leaving you with the frame for the right and left side of your smoker.
pic
Measure and mark part 4 and part 5 at 24", 36", 44" and 52" These measurements are adjustable if you wish your shelves to be at different heights than this.
pic
Lay out one each of parts 4 and part 5, then mark your measurements one both at 24", 36", 44" and 52"
pic
You will secure your shelf supports (part 7, 4 pieces, 33" for each side) at the four measurements you marked.
pic
You will want to square up the ends to make sure your racks and your smoker is level.
pic
Your will attach four shelf supports (part 7, 33") to each side
pic
We countersinked our screws before attaching these pieces. We highly recommend you do this so your wood will not split.
Step 4: Build Frame for Door
Take parts 2 and 3 (part 2 - Door frame, 2 pieces @ 70”) and (part 3 - Door frame, 2 pieces @ 29”) and screw them together to create door. We used a homemade jig so we could easily get our screws in at an angle. Use four screws on each corner.
pic
Take two of your 70" pieces (part 2) and two of your 29" pieces (part 3) and screw them together to make your door.
pic
We used a homemade jig to get our screws in at an angle on the frame.pic-candle
The jig allows us to get the screws in at an angle. Use four screws on each side.
pic-candle
Our finished door frame looks like this.
Step 5: Stand Sides and Door Up, Then Secure
Stand the walls and door together and temporarily screw the door to the face of the walls so you can hold them together.
pic-built
Temporarily screw the door to the frame so you can hold it together.
Step 6: Cut Angle for Roof
Using a piece of panel, set against the top of the left and right wall, draw a line to create the angle for the pitch of the roof, and cut off excess to create the pitch of the roof.
pic
Use a piece of panel to draw a line for the angle of the roof. Cut along this line on both sides, making them even.
Step 7: Top and Back of Walls
Screw in part 1 (part 1 - two (2) top braces for front and back @ 33”) at the top of the walls front and back.
pic
Attach part 1 (2 top braces for front and back, 33") to the top of the wall, along the angle you cut in step 5.
Step 8: Back of Frame
Add in part 6 (part 6- Back frame 2 pieces @ 5’4” 1x1) to the back of the frame, screw into part 5 (Wall Frame Back).
pic
Place the back frame piece (part 6) next to the back of the wall frame(part 5) like this.pic-candle
Secure back frame piece (part 5 ) to wall frame (part 6 )with screws.
Step 9: Add Paneling
Paneling. Add the back paneling first from the ground up. Repeat for the right and left sides.
Remove door from frame. Screw in hinges and re-hang the door. Leave at least a ½” gap at the base of the door.
Add paneling to door, then add paneling to roof last.
NOTE: Right side is shorter so that hinges have space to rotate. Also, Left side is longer so the door sits inside the paneling.
pic-candle
Starting from the ground up, add your paneling to the sides of the smoker.
dpic
Continue adding paneling until you get to the top.
pic
Repeat and add paneling to other side.
Step 10: Attach Wood for Roof
Screw roofing materials (part 14 Roof @ 38”) onto top to make roof.
candles
Place roofing boards (part 14) on top and secure with screws.candles
Screw the roofing materials onto the roof so they look like this.
Step 11: Finish Door
Put door frame back in place. Attach hinges to one side of door frame. Add pallet panels to door. Attach handle to front of door on opposite side from hinges.
candle
Attach your door frame to the smoker and add hinges on one side.
candle
Starting at the bottom, attach the pallet panels to the door.candle
Continue attaching the pallet panels to the door like this.candle
Attach panels until you get to the top. In this photo, we have already drilled the vent holes.candle
Attach your handle to the door on the side opposite from the hinges.
Step 12: Construct Racks
Screw rack parts together. (part 8 - Shelf frames 8 pieces @ 32 ¾”) Staple screen onto rack. Once you have two sides stapled, be sure to pull the screen tight as you staple the other two sides.
diy-smoker-94
Screw the pieces for the rack frames (part 8,) together to make your smoking racks.
diy-smoker-102
Lay a piece of screen over the rack to get the right size.diy-smoker-100
Cut the aluminum screen to size using your metal snips.diy-smoker-106
Staple the screen onto each rack.diy-smoker-107
After you staple two sides, be sure to pull the screen tight like this as you staple.
Step 13: Cut Vent Holes
Select 2 panels from the door, one at the base and one at the top. Remove the panels, screw part 15 (part 15 - Vent covers 2 pieces @ 18” to 24”) to the face and drill holes using a hole saw. Make sure to leave enough space between the holes that they will be able to be closed off. Remove screws and build a brace to hold part 15 in place.
diy-smoker-86
Using a hole saw, make holes for the vents
diy-smoker-84
Your pieces will look like this
diy-smoker-110
Then attach them like this to the front
diy-smoker-111
And screw them in to secure
Step 14: Line Inside With Foil
Line the interior of the smoke house with heavy duty tin foil. Make the structure as air tight as you can. Expect to use 2 to 3 rolls of foil. Use a staple gun to secure the foil to the walls.
NOTE: do not use any galvanized metal in the smoke house as it is toxic.
candle
Line the entire inside of the smoker with heavy duty tin foil. Secure foil with your staple gun.candle
Insert your racks into the smoker.candle
Just imagine what you can smoke in here.
Step 15: Attach Roof
Attach tin to roof and secure with screws.
diy-candle
Your cut piece of tin should fit nicely on the roof. Secure it with screws.
Step 16: Ready to Smoke Meat
Admire your finished smoker. You are ready to add a fire box and start cooking.
Your smoker is complete and ready to smoke meat!
Like this project?
Check out my website for more projects:
DIY projects
Join my mailing list to be the first to know about latest projects
Follow me on Instructables
Here is the link again to the smoker post with
PROJECT VIDEO here on my original post
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    6 Comments
    fantastic. I think I'll have to build me one of these. in the meantime, if you end up with any extra dear sausage my address is...
    Glad you like it! Learning how to smoke meat well in it. Hope to have another instructable on that soon...
    This is a really lovely thing, and great instructions. Thank you!
    I have written a blog post of 12 smokehouse plans and featured your project in my post.
    Do you have an instructible on fire box?
    pretty groovy cook box on the cheap
    does the bottom have room for the smoke source or does it come from an external source?
