3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Smoker
DIY Smoker
Here's an instructable that will hopefully get some of you out there doing it. This is my first, so please be kind. Anyways, this instructable started when I was sitting in the couch watching the food network. The show was on barbeque smoking. I got the thinking, while I don't want to have the oversized 55 gallon smoker in my backyard, I wanted something that was appealing and can serve other functions. I looked into making a keg smoker, 5 gallon smoker, etc. But the one thing was that I had to get those and they actually didn't have the appeal. Then one day, my wife cleaned out our back patio. She emptied out pots that had dead plants. Well, it sat there for about a week. Though it was empty, it still looked okay to the eyes. So I thought, why not make something out of it and this is where the idea came from. I started looking around the internet for ideas. I found some, even instructables, but they didn't appeal to me so I'm creating one that's both easy to make and manage while it's being used. So here we go....
Step 1Materials needed
Materials needed
Here are the tools and materials needed to get it going. Once you have the materials, it's about a 30-45 minute setup.
Tools:
a drill with a bit (any size will do). This will be used to tap into the top to put the thermometer in. I used a masonry bit.
dremel with a cutter. This will be used to cut the rivet off the handle on the pan.
hammer and tap. To knock out the shaved rivet on the pan
screwdriver. To separate the coil of the burner from the base
needle nose plier. To remove plastic and just in case you need help separating the wires on the burner.
Materials:
1. Clay pot (not glazed). I used what I had, which was a 15 in diameter clay pot. I've seen people use 18 in. Your choice, but remember, you have to look for a cover or top for it.
2. Top. I scoured around the area to find this. It didn't take me long to find it. I went to a nursery and found a base that would serve as the top. When you're doing this, make sure to take the pot with you so you can see if it fits or not. Cost: $5-12 (got mine for $5 because it had a chip and it was dirty)
3. I could not find a burner in any of the stores that I thought would have it. Even Walmart didn't have it, so I ordered a single buffet burner online at walgreens.com. Cost: $10 plus shipping.
4.grill grate. This was easy. Home Depot. Cost: less than $10
5. (Updated) 2 stainless steel pan. This is to hold the wood chunks and water that will do all the smoking. Goodwill cost for both: $3.06
6. Wood chunks. This was again easy. Home Depot. Cost less than $6
7. Thermometer. Again, Home Depot. Cost: about $8
total cost (minus the pot and tools): about $44
102 comments
1-40 of 102next »
Mar 21, 2012. 8:10 PMColima says:
Great instructable! I understand that not all clay is food-grade quality. Did you have any concerns on that regard? Thank you.
Jan 27, 2012. 7:37 AMcookin fool says:
awesome instructible, let me say that whether or not you soak your chips it isn't a bad idea to use a water pan because it will help keep the meat moist. You could actually flavor the water with apple juice or whatever you like. Thanks I love the idea of taking the hot plate apart, I am so glad I read this because I am making a smoker out of a commercial food warmer and this will help tremendously.
Aug 6, 2011. 2:06 PMPacificNWBuckeye says:
I've been thinking about getting a smoker. Thanks to this I think I'm going to make one. Thanks for the great write-up, it appears direct and simple to follow.
May 20, 2011. 4:07 PMCrackersouth says:
Great idea, very well written.
Apr 8, 2010. 11:21 AMCoranu says:
 Yeah, I'd definitely avoid getting the wood you plan on using to smoke food from a general lumber store. There's all sorts of chemicals in it and on it, which when burned, will transfer directly into your food. There IS a reason why they sell wood chips specifically FOR smoking food, apart from capitalist greed and flavor.
May 24, 2011. 3:59 PMblondie7456 says:
Yes, Home Depot sells wood chips made specifically for smoking.....same place in the store where you find the charcoal.
Jun 11, 2011. 10:25 PMSinAmos says:
The 99 cent store sells wood chips. 1 dollar!
Jun 12, 2011. 6:55 AMmatt_and_nick says:
i get mine for free! all you need is a bit os elbow grease. headlight fluid helps too.
Jun 11, 2011. 6:46 PMthoying1 says:
http://www.youtube.com/watch?gl=GB&hl=en-GB&v=_Ka2kpzTAL8
I love this show from the Food Network, (which I deduce is where you found your original inspiration from). Nice instructable.
Mar 19, 2010. 2:39 PMspylock says:
Whats holding the base and the coil onto the pot,it all dont set lose does it?
Mar 20, 2010. 8:20 PMspylock says:
Oh,o.k.,I finished the one I made for my brother yesterday,I  cut a strip of copper 1 3/4  inches wide and  long enough to make a circle that fit up under the lip of the coil reflector,I sweated it together.I used a brass rod that I had to thread a little more than what it had on it,and used that,a lock and flat washer and nut on the bottom of the base and a nut and flat washer on top where the coil is,I did have to drill the hole a tad bigger,but its all together and looks nice if I do say so myself, plus my brother was happy with it.Thank you for the info and pitchers as well as the idea,as yours was the first instructable that I saw on this prodject.
Mar 21, 2010. 12:19 PMspylock says:
Thanks,Ill let my brother do the smoking,and Ill do the eating.
Mar 18, 2010. 8:39 AMKryptoTSD says:
What about the grease that is sure to accumulate?
Mar 18, 2010. 10:36 AMKryptoTSD says:
Okay...  Now I've got some more info to go on...
Now I just have to make my head up on which one I want to build...
Mar 19, 2010. 7:58 AMKryptoTSD says:
Thanks!
Mar 1, 2010. 10:50 AMIndigoBlueMan says:
I made one of these last night and am now currently smoking a salmon filet. I was just wondering what setting you set your hotplate to. I had it at medium, but it surpassed the 220degree mark on the thermometer.
Mar 1, 2010. 12:10 PMIndigoBlueMan says:
Also I forgot to add that I bought my pots at Walmart and only got the 12inch ones since that's the biggest they had. Still works pretty well, and I bought one of those table-top charcoal grill they had for six dollars and I'm using the grate on top of the pot. Works pretty well.
Mar 1, 2010. 1:34 PMIndigoBlueMan says:
It actually turned out well. I wasn't able to find the pans, so I ended up using a metal mixing bowl and just soaking the wood chips. Had to change them three times like that, but the salmon turned out excellent.
Feb 23, 2010. 6:39 AMdeathpod says:
this is such a great idea I cant wait to try this! i have limited space for smoking at home and this is perfect!
Jan 21, 2010. 8:30 AMthe rural independent says:
Great instructable!
As a thought...Many smokers use moisture.  I prefer the moisture to a dry smoke.  Experimenting with fruit juices, beers, etc, is fun to boot.
I think one could place a water pan above the coals in your design by either placing it on legs that would straddle the wood chip pan or by drilling some holes (four?) through the sides of the pot and inserting some bolts to rest the grill on.  I think I am going to try one of these and add the water pan.  One pain in the neck is adding more liquid if needed.  I'm going to scheme up a "fill tube" as a permanent part of the pan that will stick up through the grill grate where I can just insert a small funnel when needed and fill without removing the grill.
Thanks for sharing this great idea.
www.theruralindependent.com
Feb 19, 2010. 3:00 PMjamess1805 says:
mount the water pan to the inside of the pot. Drill a hole 1/2 inch above. Use a small animal water bottle nozzle (its metal, no melting) through hole and fill pan from outside. Use bolt with wingnut to make removal of water pan easy.
Jan 22, 2010. 7:55 AMthe rural independent says:
That is exactly the sort of thing I was referring to.  It may be so close to the heat source that all the fluid will boil off pretty rapidly so I'd fill it very full.
You're right about the re-stocking of the wood.  That's why the store bought smokers have an access door to make that chore easier.
The only way I can think of to make the re-stock practical in a terra cotta smoker would be to somehow cut the bottom totally off of the pot so that you could lift the whole thing off of the wood chip pan and then place it back over it.  Possibly/Probably darn near impossible to get a true and straight cut without having it crumble away.
Another thought.... on the water pan, drill three holes and place a chain on it, like on a hanging plant.  When you needed to get to the wood chips, you could snag the chain with a hook (cause it is hot) and lift it out that way.
You did a great job rigging up that pan holder - be sure to let us know how it works out.
Thanks for taking the time to share with us!
www.theruralindependent.com/
Jan 28, 2010. 9:01 AMkikkoman7347 says:
I think this is a FANTASTIC idea and instructable.
I gave thought to the water pan/wood-refilling problem.
The chain idea mentioned above could be simplified.
Since you are going to lift the lid, thus losing smoke, and have to lift the grill, with food, and then possibly the water pan prior (if present) to refill the wood chips.  Attach the grill and water pan together via a chain.
Soldiers' dog tag chains are cheap, durable and standardized.  The heat shouldn't be an issue as they are designed to melt at higher heat.  They aren't coated with any chemicals (that I know of).  They all have attachable/dettachable connector links and come with a smaller chain for an extra connector link.
I am not a welder, but I believe that these could be soldered in place with minimum effort/trouble.
The only problem I see if refilling the water, unless you are like me and an excellent bartender and patient, is the distance (chain length) between the grill and water pan so that neither become unbalanced when off-setting on the ground. Again, dog tag chains are very cheap.
Jan 29, 2010. 10:29 AMthe rural independent says:
Let me clarify the chain idea.
First just visualize a plant hanger with three "hangers" spread around the perimeter of the water pan.
Join all three together at their ends with an "S" hook.  Do not fasten the "S" hook to the grill.
Just let the chain lay inside somewhere or if you can hook it somewhere up towards the top where it can be easily accessed do that.  Maybe even a small drilled hole with a bolt through the side of the pot.  You could hook it over the lid of the pot even.  Yes, this will let some heat and smoke escape, but in my experience, most smokers you buy seemed to be built in a manner that actually lets this happen.  Too much smoke is a bad thing.
Remove the grill, then grab the "S" hook with something that will protect you from getting burned and lift the water pan out of the way.
Sorry for not clarifying this better before.
Jan 28, 2010. 4:21 PMwebsherpa says:
[I was going to also mention that "smoking" a teflon pan at the heat required to get wood to smoke is DEFINITELY not a good idea and this should be changed immediately before someone gases themselves.]
Howeve rit's a great instructable and the idea of using a clay pot was interestingly compelling.
About 30 years ago I took a hot plate and did almost exactly the same project for my dad (because we couldn't afford a "Little Chief" smoker) but using a garbage can with hole in the bottom that I attached to the hot plate.  Thereby eliminating the need to disassemble the hot plate.  A little door for the pan at the bottom means you can use smaller chips and "refill" it when needed.  I used cookie cooling racks (easy to cut) cut into circles of different diameter so that they fit down in multiple layers inside the garbage can.  And one stronger one from a grill for "heavier" food.
Well I can say that this diy smoker is still in use by my dad to this day, every year he brings it out to make "Indian Candy" which is smoke cured salmon bits - it's become a bit of a tradition.
Thanks for reminding me of this!
Feb 13, 2010. 7:36 PMsuezq says:
Hi.  I really like the garbage can idea (as well as the terra cotta pot) and am thinking of attempting the garbage can style. Is there a problem with the galvanizing causing any weird taste to the food or health hazard? Also was yours a standard size g-can? When smoking, what should the thermometer read? How do you know when the meat has finished smoking? Is it experience, or do you probe the meat with a thermometer?
Thanks!
1-40 of 102next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:sum4all
built a few things using instructables
