3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Smoker
Step 7Turning it on
Turning it on
Make sure before turning it on that it's in an open area. The last thing you want is a smoked filled garage or overhang. Also, keep in mind, this thing will be hot and on for at least an hour or two, so place in an area that it won't be bothered or mishandled.
Put the cover/top on and turn on the burner. Put on medium heat and work from there to get the right temperature. From my research, I found that around 200 degrees is the ideal temp for smoking. You may need to play around with it, so the way it's made, you don't have to worry about opening the cover and adjusting it, all you need to do is adjust from the outside. That's the cool and easy factor in this instructable!!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:sum4all
built a few things using instructables
