3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Snowshoes
DIY Snowshoes
This weekend (02/05/2010) we received approximately 2 feet of snow.  For some parts of  the country this isn't alot of snow, but for the Washington DC, metro area this is enough to stop everything.  I needed a way to make sure if something happened (I have three kids and a wife) and I needed to get to the main road I could (since my absent HOA hasn't plowed the street at least once yet) or just an excuse to make something with my son.  I needed some snowshoes, every step I took, I sank into the snow.  I'm sure there are many ways of doing this, however this is what I came up with using the materials in hand.  While researching diy snowshoes, alot of the options out there involved street signs, or twigs.  I needed to be able to make a set of shoes without going to the home center, and using only materials I already had on hand.
For this instructable you will need:
  1. 2 x pieces of 3/4 plywood - cut to a 12" x 24" (I only had 3/4" plywood, you could use something thinner).
  2. Drill & 3/8" bit
  3. Saw: reciprocal, jig, circular, or Dremel
  4. String basic nylon, so long as it is strong (2 x 4' pieces)
  5. Simple knot ability
Step 1Make your template and cut
First, I needed a template, I went with a modified rectangle.  I had a sheet of foam board from one of my sons last projects, but one could easily use a sheet of newspaper or wing it.  I choose a template size of 12" x 24" that seemed large enough for me.  I weight approx 230lbs so I figured this would distribute my weight better than my size 14 boot.  The notches are all 3" from their respective edges.
I traced the template onto the plywood and cut.  I used a reciprocal saw, but a jig, circular saw  or even a Dremel would have been sufficient.
12 comments
Nov 4, 2011. 2:05 PM5STARGBLOOD says:
wat measurements would u suggest for size 14 shoes??
Feb 6, 2011. 8:21 PMgeekqueen2010 says:
i can afford plywood. my materials are a pizza box and yarn, i had seen kids on an episode of Curious George that had snowshoes made of cardboard and string. can u tell me how to make those snowshoes?
Feb 9, 2011. 7:39 PMPersonPwner says:
So should the sizing chart for commercial snowshoes work the same for these?
Feb 1, 2011. 9:54 AMwonderluge says:
I built a pair of these, but I used a bungee cord for the back strap. I also screwed on a couple of 7-inch long strips of wood on the underside for traction.
The snowshoes work great, but the large flat surface led to a significant buildup of snow on the top.
I am not sure how to prevent this except perhaps to drill a few holes in the surface.
Feb 8, 2010. 12:34 PMve2vfd says:
Very nice project!  I hope you made a second pair and you and your son had a chance to try them out in the snow!  Snowshoeing is quite enjoyable, and is a great way to make the most of miserable weather :)
Feb 8, 2010. 3:33 AMkill-a-watt says:
nice.
here's another take from boy's life:
http://sne.tripod.com/snowshoes.pdf
These might be worth looking at for the toe cut-out and the binding used.
Feb 8, 2010. 9:06 AMkill-a-watt says:
yea, they've got wood strips like cleats to keep you from sliding backwards. I'd probably  put them on like a tractor tire / \
Maybe I should have made these first. I'm still digging out from the same storm.
Feb 8, 2010. 4:03 AMcooldog says:
they look good, but you need the toe cut out like is what mentioned by kill-a-watt in the comment above, for climbing hills.
also something you might want to consider is routing horizontal groves down the bottom for traction. as well driling a few holes on top to let air through when you are puting ur foot down would help alot
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:richardw2
