DIY Soda Can Knife
2,788
14
5
Published
Introduction: DIY Soda Can Knife
This instructible will show you how to make a DIY knife out of common household materials
Step 1: What You Need
Scissors
Aluminium Cans (the more the better)
Razor knife
Liquid soap
Bowl
Water
Plyers
Cutting board
Popsicle sticks
Hot glue
Step 2: Let's Get Started
Start by pouring water int a bowl and adding some liquid soap
Next stir the soap into the water (keep in mind that this instructible is about being recourscful)
Then put your cans in the soapy water and rinse them out
Step 3: Preparing Your Cans
For this step you have to be carful!!!
Cut off the tops and bottoms of the cans with your exacto knife
Step 4: Cut the Can
Next you simply cut the can down the middle
Step 5: Start the Knife
For this step you want to start cutting the actual knife shape out.
Start by making a cut like this
Step 6: Support
You have probably noticed that the knife is very flimsy, so what you want to do is hot glue a Popsicle stick to the handle of the knife on each side.
Then cut a Popsicle stick in half and glue it to the top half of the knife and connect the tow with another half Popsicle stick
Step 7: Handle
This handle is made by cutting a piece of leftover can to the same length of the handle and wrapped around then secured with hot glue
Step 8: Finish
Cut a piece of aluminum an long as the blade and glue it around the back of the blade to make the back of the blade dull
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    5 Comments
    Yes, it is dangerous to work with exposed aluminum sheet metal and I will soon post an intractable on how to make a sheath for it.
    Cool. Judt be careful when cutting cans and such. I used to cut cans alot for some reason, I was careful and still got cut alot.
    Thank you for the support. ?
    Looks like a fun little project. Thanks for sharing how you made this!
