Step 6Cap It All Off...
Pull the top of the tire valve up through the hole with a pair of pliers until it pops snugly into place.
All Steps Viewing
On another note: Cold water absorbs the CO2 faster, but it also releases it faster, thus the need to keep the bottles capped.
I worked in wastewater treatment for a number of years...
that its actual use is to make seltzer water.
Like this one: http://www.amazon.com/iSi-2248-ISI-Soda-Siphons/dp/B0033YU0G4
If so, it's made to make seltzer (soda water) and uses a small CO2 cartridge.
It blew out one of the "feet of the bottle" rocketed it into my ceiling, smashed my lightfixture and then broke a window. All the while hosing down my kitchen.
The biggest problem with those little containers is that they're tiny. you'll be using a $0.50 cartridge to make a bottle of water. Even the store-bought Soda makers are too expensive.
Get a 20lb tank, and It'll last a long time. I've had mine for around a year, and haven't had to fill it yet.
A friend of mine got a 10lb a little while later, and is just running out of gas now.
A refill is about $20. Less than the cost of one of the little refills for one of the storebought ones that only does a couple dozen bottles.
NEVER use copper or brass fittings when carbonating beverages or dealing with carbonic acid (a product of carbonation). Carbonic acid reacts with copper and copper alloys to produce poisonous byproducts. ONLY use stainless steel fittings when setting up a system like this for any kind of carbonation, and never store carbonated beverages in copper or brass containers.
In this system the internals of the bicycle tire valve are the only piece that may come in contact with carbonic acid. Whether they are food safe or not, I can't say. But in general you shouldn't be scared to use brass for your CO2 line.
