3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Softbox from an umbrella
Step 3Mark and cut the internal braces
The reason for this step is that you need to shorten the internal bracing, in order to re-use the original locking mechanism that holds the umbrella open. Recall that we are going to be using this in a 3/4 open position, compared to the original umbrella, and we need to adjust the internal bracing length. This is probably the hardest step in the whole process (in particular the drilling of the new holes).
Position the center slider about 5 inches below the position where it normally rests, tape it in place. Now use thread or string to tie the opposite corners together, while slightly bowing the umbrella legs. We will need to shorten the internal braces, so measure the length that they will have to be cut to. On this umbrella for a 28" x 28" softbox, my leg braces needed to be about 10-10.5 inches.
Now cut the wire that holds the internal braces to the center slider.
Shorten the internal braces by cutting them with a wire cutter, flattening the ends with pliers, then re-drilling the tiny hole in the tips (to replicate the original hole).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:sdhigbee
