DIY Softbox
141,201
130
28
Posted
Introduction: DIY Softbox
Something a little more professional looking than a bunch of foam board stuck together... Costs about $40 bucks.
Step 1: Get Your Parts
I've been trying to take some headshots of myself and I've been in need of another light. The problem with this is that I'm piss poor broke (the reason I'm not just paying for headshots) so i decided to make my own softbox...
Let me preface this by saying that i know i could have just done this with a few pieces of foamboard and a lamp kit, it probably would have been cheaper, but i didnt want to have to find a place to store something that large. With that in mind, i decided to build something i could break down when i needed to... hence my plans.
Onto the tutorial, kinda.
Materials I used:
Ouside flood light kit - 9.97
Replacement tent pole kit - 5.47
Black Duct tape - .97
White material i found at wal mart - 1.00 (1 yard)
Black wal mart material - 4.00 (2 yards)
5/16 wooden dowl - .39
20 foot extension chord - 5.97
Heavy duty male universal plug - 1.97
Grommet Kit for making tarps and such - 6.97 (included tools)
Note: I didnt use everything in this pic, i thought I'd have to, so there are some extras pictured.
Step 2: Form Bracing
First order of business was to get the tent poles put into the flood light housing... To do this, i just stuck them in in a tic tac toe pattern putting the fiberglass end in and leaving the metal part out. I tried to use conduit holders but they bent. I weaved the poles when i put them into the box (over one, under the back) to give it a little more stability.
Once I had the poles laying in there I bent them to what I deemed an appropriate angle. what do i know though, this is my first time donig this.. .
Step 3: Make the Diffusion Panel
Next, (once i had the measurements) I cut out a square of my white fabric. Actually I cut 2 ssquares simultaneously. I didnt think it was diffused enough. In retrospect, i would have only used one sheet.
Step 4: Trim the Panel With Tape for Stability
After that i taped the edges of the material with duct tape to give it a little strength. I used 1/2 the width of the duct tape on each side so that it kept the 2 sheets together nicely.
Step 5: Trim and Rivet
Once i had all 4 sides done, i went back over it on one side with a full width of duct tape to finish it off and make it look good.
The next step was to put gromments in each corner with my trusty tool kit. The kit includes everything but the hammer
Finished with the front panel. My theory here is that the gromments are going to hold dowels coming out of the tent poles and keep everything square.
Step 6: Secure Front Panel to Frame
Now, i cut a 5/16 dowel into 4 pieces about 5" in length and put them into the metal ends of the tent poles. Generally, this is where you'd put the other pole to extend it through the tent.
Once that was done, i threaded the dowls through each of the gromments and then cut the duct tape off to test my theory on it holding together... It seemed to work great.
**NOTE** you can see in the picture above how the tent poles were arranged in the housing.
Step 7: Status Pics
This is a pic of it at this point with a regular incadecent bulb installed and a horrible white balance setting on my camera...
Step 8: Make a Canopy
This part is easily the hardest part of the whole process.... making the sheath that conceils the rest of the light!
I can't sew for crap, so i elected to use mroe duct tape. You will without a doubt, get a better result with a sewn canopy but like i said.... i can't sew.
Basically what i did was cut 4 trapezoids and taped them together... haha. I know that it's ghetto, and I'm working on a better solution because this one isn't cutting it for me. I think I'll have my grandma sew me a sheath.
To attach the canopy to the frame i extended 4 tabs of duct tape off of each intersection of cloth and put another gromment in. This way i could stretch the gromment over teh frame and thread the forward facing dowl into the gromment and it would be stable.
My craftsmanship on this portion was less than perfect. It was 3:15 AM and I was tired. I'll be redoing this to make it fit better (apparently my forward measurements were off by about an inch). There are currently some light leaks, but that can be fixed with some velcrow for the time being until i get my new sheath.
    • Pocket-Sized Contest
    • Trash to Treasure
      Trash to Treasure
    • Microcontroller Contest
    26 Comments
    **This comment is not written with anger or with any implied attitude**
    i understand numbers just fine, thank you. I am a former pilot, and a current Tractor Trailer Operator...of all things i know its numbers...in aviation, just mistaking INCHES on the height of a communications tower on final approach can mean the difference between walking away safely, or putting multiple lives at un-necessary risk...same with a Tractor Trailor...mis-judging distance while at highway speeds can mean the difference 'tween the child in the back seat of the car ahead living or being pre-wrapped in a metal coffin.
    last i checked the most writing "$40 bucks" will do is make someone think "that aint right"...or make the person go to the nearest price checker...the project your looking at aint an engineering diagram. what your arguing is a mute point. there is not a life at risk, there is no threat of loss of limb, or simple, moderate, or severe injury...so your argument does not stand well...and the .10c thing...thats just common sense...it is rather rediculous to think someone would .10c for .01c/10pc. sorry i dont know how to insert the "cents" sign.
    like i said...you were being rude. this site is about sharing projects that one makes for others to see and be inspired to make things better...its not a spelling-bee contest website, or numerical accuracy forum...STOP treating it as such...i could understand if a measurement was a little off in the writing from what is shown on the picture, and you were POLITELY trying to clear up any descrepencies, but your not.
    Point of the novel is that if its not CONSTRUCTIVE AND POLITE criticism or suggestions and is destructive criticism, than you ought not write it on here. because someone such as myself will come up and correct that.
    Please do not write something on a 'ibler's 'ible if your not going to be constructive, helpful, and corteous (i think i spelt that wrong...sorry).
    I would love to see what ideas YOU have pcooper2. i am not being sarcastic either. i love looking at other 'ibler's 'ibles. it would be nice to see some numbers below your picture.
    Hell yes.....what you said! :-)
    This is really nice. Thanks for sharing this!
    Nice idea. Looks like it came out pretty well. I wonder if the duct tape will come apart over time with stress of the poles though. Thanks for sharing!
    if its good enough to go to space and patch holes in the space station its good enough for me! duct tape is mans greatest invention.
    How do you pronounce "$40 bucks"? Is it "forty dollars-bucks", or is it "forty bucks-bucks"?
    "Dollars forty bucks" obviously. Cut the monster some slack, there are worse things in the world than being part of the department of redundancy department.
    hey , great help with posting this DIY . I have to make a softbox for a school project and i stay in Dubai and was wondering where exactly i can get the flood light kit , it would be really kind of you to post a link . Thanks in advance
    whats the name of the fabric you used?
    Thanks!
    Great idea! Would definitely want to add some heat resistant fabric on the inside. Instead of  the flood light maybe keep the housing and attach a thermoset medium base clete socket - then use a E-27 adapter to use with  g-6.3 or g-5.3 two pin halogen type bulbs. Then you could use Ushio DVY 650 watt Halogen Lamp. Also, instead of the "white fabric" you could use Lee 434 quarter grid or Lee 432 LIght Grid Cloth or Lee 430 Grid cloth. Attach velcro to your filter and your box so you can easily switch out the diffusion. All these items can be purchased online at filmtools or look for a cheaper option else where online. Might be difficult to find cuts of the diffusion but would be well worth it!
