What if there was a way to cool your home, car, or workplace without the need for a big, loud, and energy-hungry machine? What if this device also was entirely solar powered with no moving parts? Sound to good to be true?
This Instructable will cover the method I used to build a prototype Solar Air Conditioning Unit. This unit is a prototype, and was only ever meant as a proof of concept that my idea could work. There is a lot of testing that needs to be done to see how this idea can be used in more practical applications.
Index:
- Introduction
- "Why?"
- Theory of Operation
- Gather Materials
- The Build Pt. 1 - Cutting Wood
- The Build Pt. 2 - Gluing
- The Build Pt. 3 - Metalwork
- The Build Pt. 4 - PVC
- The Build Pt. 5 - Miscellaneous
- Using the Unit
- Going Further and Conclusion
- Videos!
.:| This Instructable was intended to be entered into the Green Technology Contest. However, because this project uses no electronics, it was not accepted. I entered this into the Hurricane Laser Contest instead, and if you like this Instructable, it would be awesome if you would vote for it in the contest! Having a laser cutter would be awesome because it would allow me to build things better and more quickly to be able to share them with the community! |:.
7/17/2012: Thanks so much for the feature!!
Step 1: "Why?"
-I'll take this point to say that if you don't care about specifically why I built this, then move on to the next step, no hard feelings : )
My car sits in the sun all day, and has a black interior. I'm sure you already know that dark colored things tend to get hotter when they sit in the sun than lightly colored things. Additionally, windows do a funny thing when light hit them, and serve as a sort of insulation, so that the air in my car actually gets hotter than the outside air temperature. Both of these factors cause me to start sweating almost immediately upon entering my car, which isn't very attractive when going to work, nor very comfortable.
Therefore, I was thinking of different ways I could cool down my car while it sits in the driveway. Leaving all my windows down isn't very practical for safety reasons and letting bugs in. A foil sun shade that would sit on my windshield would be annoying to put up and take down. I also had a vague idea of how a Solar Air Conditioning Unit could work, and decided that a car would be the perfect test medium for my concept! The car would allow me to attempt to cool a small amount of space, in a fairly controlled setting, and potentially save me from a very uncomfortable commute.
Step 2: Theory of Operation
1. Convection:
But what does that mean!? Hot air rises. As the hotter air rises, it can draw cooler air up with it. Convection cycles can occur when hot air rises, and draws cooler air from lower elevation. When the hot air rises and loses energy it begins to fall. This is the bare bones explanation. There's a ton more information out there from people who know more than I do. I did a lot of reading before starting this project, and I'd encourage you to do likewise. I've listed some sources for more information at the end of this step for your convenience : )
2. Evaporation:
We are using water in this project as our cooling agent. Evaporation is when a substance changes from liquid to gas at it's surface. Links to fun evaporation information down below.
3. Cohesion and Adhesion:
Cohesion and Adhesion are two properties of water, and closely related. Cohesion means that water tends to stick to itself, or try to stick together. You can see this by placing small drops of water onto wax paper. You'll notice that the drops tend to ball up. This is because of the strong polar bonds in the water that attract individual molecules to one another. Adhesion means that water sticks to other stuff. This effect is best seen by dipping part of a paper towel into a small amount of water, and watching as the water makes its way up the paper towel.
(*7/23/2012: shannonlove was nice enough to point out that a more accurate term for this water property is "capillary action". I was going from what I remembered in my chemistry classes, however doing a search for "capillary action" may lead to more helpful information.)
These three principles make the Unit what it is. The sun will shine on the unit and heat the air at the bottom of the shaft. The air will rise, and also draw in more air from the bottom. As the air rises, it will cause water in a small chamber to evaporate. When the water evaporates, it will take energy away from the heated air in order to change from a liquid to a gas. This will cause the surrounding air to get cooler. The water is brought into contact with the moving air by a piece of fabric. The fabric will pull up water from the chamber to increase the surface area of the water with respect to the moving air. As the water evaporates and the fabric gets dry, more water will be drawn up the fabric due to the awesomeness of cohesion and adhesion.
Got it? Awesome. Let's get building!
Jump over here (step 11) to see my video on how it works: http://www.instructables.com/id/DIY-Solar-Air-Conditioning-Unit/step11/Videos/
More on Convection:
http://en.wikipedia.org/wiki/Convection
http://en.wikipedia.org/wiki/Convective_heat_transfer
http://www.uoguelph.ca/geology/geol2250/glossary/HTML%20files/convection.html
http://www.youtube.com/watch?v=7xWWowXtuvA
More on Evaporation:
http://en.wikipedia.org/wiki/Evaporation
http://www.chem4kids.com/files/matter_evap.html
http://science.howstuffworks.com/evaporation-info.htm
More on Cohesion/Adhesion:
http://www.appstate.edu/~goodmanjm/rcoe/asuscienceed/background/waterdrops/waterdrops.html
http://en.wikipedia.org/wiki/Cohesion_%28chemistry%29
http://ga.water.usgs.gov/edu/adhesion.html
http://science.howstuffworks.com/environmental/earth/geophysics/h2o7.htm
Step 3: Gather Materials
Materials:
- MDF Sheet. | 1/4" thick. 2'x4'. $7 or so.
- Glass sheet. | 11.5"x20.5". $5 At local hardware store
- Sheet Metal. | Recovered from old microwaves.
- 1" PVC Pipe. | A small section. I had this already.
- 1/2" PVC Pipe | A small section. I had this already.
- 1" PVC-1/2" Elbow. | The 1" side was a slip coupling, and the 1/2" side was threaded. $0.80 or so.
- 1/2" PVC Male-thread Coupler. $0.80 or so.
- 1" PVC End Cap. $0.50 or so.
- PVC Primer and Cement. | I had these already.
- Wood Glue. | $3-4.
- Caulk. | This was left over from another project. Outdoor Acrylic-Silicone I believe.
- Matte Black Paint | $6 at craft store.
- Mesh. | A splatter protector from the Dollar Store. $1
- Small wood screws. | $2 at local hardware store.
- Fabric. | From an old t-shirt.
Tools:
- Dremel Rotary Tool.
- Oscillating Cutting Tool.
- Jigsaw.
- Drill.
- Various hand tools: knives, scissors, screwdrivers, etc.
Step 4: Build Pt. 1 - Cutting Wood
(*7/23/2012: tafelice and isaacwilk were nice enough to point out that MDF has the tendency to absorb moisture easily, which I didn't know when I began this build. It's a good idea to make sure you coat the Unit with a clear coat, or paint of some sort once it's built to try to minimize this.)
I began by cutting my largest shape. In this case I had to try to match the shape of my car window. I did this by measuring the general dimensions of the window, and gradually cutting down the edges and adjusting the curve to match as best I could. it's not perfect, but it fit somewhat nicely. I'll refer to this as the "base board".
After knowing how big my window was, I was able to identify how large the outer box of the Unit could be. I marked this on the base board, and measured to cut for sides of my box, and thin strips for the top of the box, where the glass would be mounted later. Notches were cut out of all the pieces so that they would fit together nicely to be glued together.
There's not too much I can do to describe this step. It was a lot of tedious measuring and cutting, as I made it up as I went along.
Step 5: Build Pt. 2 - Gluing
The window was installed at this point. I wanted to use a piece of glass I found in the trash from an old window, but shattered it in the process of trying to cut it to size. Getting a piece from the hardware store was much easier, however it ended up being slightly too small for the box I had just built. It get around this I used the trimming I had taken from the window to add some bulk to the sides so that it could be securely caulked in place. The metal trimming was really dirty, so I cleaned it off with an angle grinder while I was cutting it. Caulk dries very quickly when you place it in the sun in 90+ degree weather.
Step 6: Build Pt. 3 - Metalwork
The ends of the box were bent out with pliers, and holes were drilled along the sides so that it could be attached to the base board. A small amount of caulk was placed along the edges to try to make a good seal with the base board, but the two were not caulked together, so that it could be easily taken apart and repaired if necessary.
It's important to note that I did not attach the metal piece to the base board at this time. We will do that later.
Step 7: Build Pt. 4 - PVC
A small section of 1/2" diameter PVC will go through a hole cut in the top of our metal container to a male adapter coupling and into a 90-degree elbow, which has a 1" slip-coupling on the other side. The section of 1" PVC will have a slit cut in the top (via the oscillating cutter) for the fabric to go into, and be capped off with an end cap. I used PVC primer and cement for the smooth coupling pieces and end cap, but did not glue the threaded piece in case I need to take it apart for repairs. I used a 1/2" end cap, not glued in place, to top off the 1/2" pipe.
I cut a small piece of sheet metal, again from the microwave housings, and bent it into a bracket to hold the pipe in place with rivets on one end. On the other end the pipe simply sticks through the hole in the metal box, however glue or caulk could be used to permanently affix it.
Step 8: Build Pt. 5 - Miscellaneous
1. A small piece of fabric must be cut and fit into the cut made in the 1" PVC pipe. Mine was from an old t-shirt.
2. A hole must be cut in the base board for the air to be able to move into the car. This was done with the oscillating tool, and was about the same width as the fabric piece.
3. A hole was cut into the bottom of the outer box, and a piece of mesh glued in place to allow air to be drawn in from the bottom.
4. Everything must be assembled. The piece of fabric was put into position, from the pipe to the edge of the metal box. Holes were drilled, and small wood screws were used to hold the metal box to the base board. The bottom of the metal box, as well as the wooden outer box were box painted black.
Step 9: Using the Unit
To use the unit. I simply place it in my car window, add water to the spout above the metal housing, and put the window-box in place over it.
This project could definitely use some in-depth testing, which I haven't had too much time for. However, the first time I used this unit, my car's internal temperature dropped 10°F within only 40 minutes! This was without any noticeable change in outside temperature, shading, or other factors.
Update 7/31/12: On most occasions, the Unit drops the car's internal temperature by 2-4°F. Not nearly as awesome as the first test, however considering Ohio is not the ideal location where evaporative cooling would be most efficient, and the Unit is very small, the drop in temperature is still a success.
However, the thermometers I bought at the Dollar Store can hardly be called high-precision instruments, and one actually broke when trying to measure the initial temperature of the car one day because it was so hot. When I can find affordable precise temperature monitoring equipment I'll do more testing.
Step 10: Going Further and Conclusion
I'd like to point out also, that if water were not added to the Unit, it could act as a heater, using sunlight to heat the air in the shaft, and simply funneling it into the home/car. Definitely an awesome feature if this were to be considered as a device to be incorporated into homes.
At this point I'd like to sincerely thank you for reading my Instructable. I'd like to encourage you to leave a comment, because I like reading them and it motivates me to actually document my projects as opposed to silently enjoying them. If you wanted to rate this Instructable and Follow/Subscribe that would be awesome as well!
Good luck with your build!
Visit Our Store »
Go Pro Today »
Also expecting your updates about any improvement or addition..
I was thinking Get some kind of air scoop so when you drive it directs the wind inside the car. Then have a wet medium infront of it . And mybe a bottle of water and a pump which sits under the seat and pumps new water to the unit.
The car would cool down pretty fast after a few mins of driving .
IF you have any questions im an air conditioning mechanic .
I would recommend cooking thermometers like the kind they sell to make candy. They have a wider upper range than weather thermometers, they are more durable and, most importantly, you can calibrate them using boiling water (corrected for barometric pressure of course.)
I considered using candy thermometers, however they can be $10 or more, and so I didn't want to buy them when I'd only really be using them for these measurements.. I also wasn't sure how accurate/reliable they would be hanging in air, as opposed to being submerged in a syrup.
Thanks for the read and the comment!! : )
All science begins with measurement. If you can't produce repeatable measurements, whatever you're doing isn't science and probably not even useful inventing/engineering. You can easily end up pursuing dead end design paths because you had to guess whether any particular design or change was really producing the results you thought they did.
I always recommend to people building anything whether woodworking, electronics, software, cooking etc to spend money first on measuring tools. It's the traditional, "measure twice, cut once" wisdom.
Check around. You can get relatively descent infrared thermometers for $20 bucks or so. Also, remember you can borrow tools. Make friends, schmooze and help other out and they will return the favor. When you're working on a shoestring friends are more important than cache.
Thanks for your input and comments!! Your help and interest is appreciated : )
Candy thermometers are quite reactive because candy making requires precision as some task like chocolate making will fail if the temperature goes outside a 4F/2C range. On the other hand the thermal mass of water, solids and sugar is enormous so they might be slow measuring just air. I have used them for a surprisingly wide variety of task e.g. checking engine temps (but please don't tell my significant other) and they seem very reactive.
Their major advantage vs weather thermometers is their upper range. Most weather thermometer peg out at around 120F/49C making them useless for measuring any temp you couldn't touch with bare hands anyway. The second advantage is that you can calibrate them with boiling water.
Thanks again!
It's not hard at all to put on, however I can't really say whether or not it's "easier" since I haven't tried a foil shade. It's certainly more fun and fulfilling to put on to say the least : )
Compared with a "compressor-type" air-con, they cost pennies to run, and made he place more comfortable with the humidification or the air indoors.
I like the idea too of making it "dual purpose" to heat the car in the Winter before driving off - I'm currently doing something a bit similar to stop my workshop in the garden getting too cold and damp at night in the Winter by fitting a "Solar Collector" on the South end, blowing air heated by the sun in the day through a THICK insulated concrete base, which should radiate into the workshop at night and keep the conditions in there a lot nicer.
Your garden heating project sounds awesome! A great idea for passive solar heat.
Thanks for the read and comment!! : )
The thermal mass of this base is intended to store that heat and to radiate it from the floor into the building once the temperature inside starts to drop at night. Yes - I've been taking pictures as I've been going, and it will be submitted as an instructible when it's finished . . . . But that won't be for several months as I won't need the heating until later in the year when it starts to get colder at night. I've been neglecting a lot of other chores since I started which I'll have to catch up on!
I've built the workshop with stud wall, OSB skin inside, which will have the space between the studs insulated with glass wool insulation and twin-wall plastic cladding outside, while the roof is OSB, covered with glass wool and another layer of OSB over that. Should be nice and cozy!
Stu
I agree it would work - to a degree, but I'm putting in a "muffin" fan to be able to get the airr to circulate better.
Of course, I MAY find that it circulates enough without the fan, and that will save me having to provide a small power source (probably solar PV) to run the fan during the day.
In fact, I have the air planned to go to the bottom layer of the slab first, as this way the heat should take longer to transfer to the top of the slab (and hence into the structure above, in order to achieve my aim of keeping the building warmer during the late part of the night (electronic equipment does not like cold, damp atmosphere), but it still may work . . . . (?)
Stu
Gordie
An awesome project nonetheless! Can't wait to see it!
Thanks! : )
(My good friend, the "vote" button, gets forgotten and feels unloved)
The idea of using your apparatus dry creating heat might be useful in the winter.
*casually points to the "vote" button in the upper right* : )
http://www.lifestylestore.com/details/ls_detail_6058.html
This is about Trombe walls: Same effect as using your device dry:
http://en.wikipedia.org/wiki/Trombe_wall
-very susceptible to moisture, and it will swell up to maybe 3 times its size. Not desireable.
-the strength on the face of it is very good, i.e. you want to walk on it or rest things on it. I built a medium duty workbench with it, works wonderful, nice flat surface. I built utility shelves with it, very nice. I did all the wood work in my house with it... OUTSTANDING.
-but it is not structural in that it has very little span, not good on its edge, won't hold a screw (or nail) very well in the edge or even on the face to well, suggest glueing along with screwing/nailing.
-absent of moisture it is extremely stable.
-MDF is VERY heavy
For this project I would almost suggest some type of foam board with hot glue gun. Easier to work with, more resistant to moisture and very economical
This stuff doesn't have a rigid outlayer but has a somewhat rigid inner core between some silver reflective paper. It has a less than 2% water absorbtion. It is just $9.48 at Lowes. I put this on my basement ceiling and had a ton of big scraps leftover, some of which spent a couple of weeks out in the weather and it came in still in good shape. I read they do a lot of modeling with that gatorboard and perhaps it is a tad more permanent but this R-Max 1/2" would be great for proof of concept projects and I even believe it would hang in there for a good deal of years outdoors, but I can't be certain.
It is NON-structural. but for small boxes etc I would try it. I'm thinking of trying a dual chamber swamp cooler using this material.
I can't wait to see your cooler!
Thanks! : )
The price is rather high, but here are some sources for single sheets.
Paint edges with latex or acrylic! Maybe 3/16" would be sturdy enough for your use...
GatorBoard
http://www.foamboardsource.com/
http://www.artsuppliesonline.com/catalog.cfm?cata_id=6044
UltraBoard is similar but with plastic surfaces (I haven't tried it):
http://www.tri-dee.com/Ultra%20Board%20Panels.htm
Thanks! : )
I don't know if foam board would be quite sturdy enough for this project though, but it wouldn't hurt to give it a shot.
Thanks! : )
Great idea and instructable though!
Thanks for reading and commenting!! : )
