What if there was a way to cool your home, car, or workplace without the need for a big, loud, and energy-hungry machine? What if this device also was entirely solar powered with no moving parts? Sound to good to be true?
This Instructable will cover the method I used to build a prototype Solar Air Conditioning Unit. This unit is a prototype, and was only ever meant as a proof of concept that my idea could work. There is a lot of testing that needs to be done to see how this idea can be used in more practical applications.
Index:
- Introduction
- "Why?"
- Theory of Operation
- Gather Materials
- The Build Pt. 1 - Cutting Wood
- The Build Pt. 2 - Gluing
- The Build Pt. 3 - Metalwork
- The Build Pt. 4 - PVC
- The Build Pt. 5 - Miscellaneous
- Using the Unit
- Going Further and Conclusion
- Videos!
.:| This Instructable was intended to be entered into the Green Technology Contest. However, because this project uses no electronics, it was not accepted. I entered this into the Hurricane Laser Contest instead, and if you like this Instructable, it would be awesome if you would vote for it in the contest! Having a laser cutter would be awesome because it would allow me to build things better and more quickly to be able to share them with the community! |:.
7/17/2012: Thanks so much for the feature!!
Remove these ads by
Signing UpStep 1: "Why?"
-I'll take this point to say that if you don't care about specifically why I built this, then move on to the next step, no hard feelings : )
My car sits in the sun all day, and has a black interior. I'm sure you already know that dark colored things tend to get hotter when they sit in the sun than lightly colored things. Additionally, windows do a funny thing when light hit them, and serve as a sort of insulation, so that the air in my car actually gets hotter than the outside air temperature. Both of these factors cause me to start sweating almost immediately upon entering my car, which isn't very attractive when going to work, nor very comfortable.
Therefore, I was thinking of different ways I could cool down my car while it sits in the driveway. Leaving all my windows down isn't very practical for safety reasons and letting bugs in. A foil sun shade that would sit on my windshield would be annoying to put up and take down. I also had a vague idea of how a Solar Air Conditioning Unit could work, and decided that a car would be the perfect test medium for my concept! The car would allow me to attempt to cool a small amount of space, in a fairly controlled setting, and potentially save me from a very uncomfortable commute.
Visit Our Store »
Go Pro Today »
Also expecting your updates about any improvement or addition..
I was thinking Get some kind of air scoop so when you drive it directs the wind inside the car. Then have a wet medium infront of it . And mybe a bottle of water and a pump which sits under the seat and pumps new water to the unit.
The car would cool down pretty fast after a few mins of driving .
IF you have any questions im an air conditioning mechanic .
I would recommend cooking thermometers like the kind they sell to make candy. They have a wider upper range than weather thermometers, they are more durable and, most importantly, you can calibrate them using boiling water (corrected for barometric pressure of course.)
I considered using candy thermometers, however they can be $10 or more, and so I didn't want to buy them when I'd only really be using them for these measurements.. I also wasn't sure how accurate/reliable they would be hanging in air, as opposed to being submerged in a syrup.
Thanks for the read and the comment!! : )
All science begins with measurement. If you can't produce repeatable measurements, whatever you're doing isn't science and probably not even useful inventing/engineering. You can easily end up pursuing dead end design paths because you had to guess whether any particular design or change was really producing the results you thought they did.
I always recommend to people building anything whether woodworking, electronics, software, cooking etc to spend money first on measuring tools. It's the traditional, "measure twice, cut once" wisdom.
Check around. You can get relatively descent infrared thermometers for $20 bucks or so. Also, remember you can borrow tools. Make friends, schmooze and help other out and they will return the favor. When you're working on a shoestring friends are more important than cache.
Thanks for your input and comments!! Your help and interest is appreciated : )
Candy thermometers are quite reactive because candy making requires precision as some task like chocolate making will fail if the temperature goes outside a 4F/2C range. On the other hand the thermal mass of water, solids and sugar is enormous so they might be slow measuring just air. I have used them for a surprisingly wide variety of task e.g. checking engine temps (but please don't tell my significant other) and they seem very reactive.
Their major advantage vs weather thermometers is their upper range. Most weather thermometer peg out at around 120F/49C making them useless for measuring any temp you couldn't touch with bare hands anyway. The second advantage is that you can calibrate them with boiling water.
Thanks again!
It's not hard at all to put on, however I can't really say whether or not it's "easier" since I haven't tried a foil shade. It's certainly more fun and fulfilling to put on to say the least : )
Compared with a "compressor-type" air-con, they cost pennies to run, and made he place more comfortable with the humidification or the air indoors.
I like the idea too of making it "dual purpose" to heat the car in the Winter before driving off - I'm currently doing something a bit similar to stop my workshop in the garden getting too cold and damp at night in the Winter by fitting a "Solar Collector" on the South end, blowing air heated by the sun in the day through a THICK insulated concrete base, which should radiate into the workshop at night and keep the conditions in there a lot nicer.
Your garden heating project sounds awesome! A great idea for passive solar heat.
Thanks for the read and comment!! : )
The thermal mass of this base is intended to store that heat and to radiate it from the floor into the building once the temperature inside starts to drop at night. Yes - I've been taking pictures as I've been going, and it will be submitted as an instructible when it's finished . . . . But that won't be for several months as I won't need the heating until later in the year when it starts to get colder at night. I've been neglecting a lot of other chores since I started which I'll have to catch up on!
I've built the workshop with stud wall, OSB skin inside, which will have the space between the studs insulated with glass wool insulation and twin-wall plastic cladding outside, while the roof is OSB, covered with glass wool and another layer of OSB over that. Should be nice and cozy!
Stu
I agree it would work - to a degree, but I'm putting in a "muffin" fan to be able to get the airr to circulate better.
Of course, I MAY find that it circulates enough without the fan, and that will save me having to provide a small power source (probably solar PV) to run the fan during the day.
In fact, I have the air planned to go to the bottom layer of the slab first, as this way the heat should take longer to transfer to the top of the slab (and hence into the structure above, in order to achieve my aim of keeping the building warmer during the late part of the night (electronic equipment does not like cold, damp atmosphere), but it still may work . . . . (?)
Stu
Gordie
An awesome project nonetheless! Can't wait to see it!
Thanks! : )
(My good friend, the "vote" button, gets forgotten and feels unloved)
The idea of using your apparatus dry creating heat might be useful in the winter.
*casually points to the "vote" button in the upper right* : )
http://www.lifestylestore.com/details/ls_detail_6058.html
This is about Trombe walls: Same effect as using your device dry:
http://en.wikipedia.org/wiki/Trombe_wall
-very susceptible to moisture, and it will swell up to maybe 3 times its size. Not desireable.
-the strength on the face of it is very good, i.e. you want to walk on it or rest things on it. I built a medium duty workbench with it, works wonderful, nice flat surface. I built utility shelves with it, very nice. I did all the wood work in my house with it... OUTSTANDING.
-but it is not structural in that it has very little span, not good on its edge, won't hold a screw (or nail) very well in the edge or even on the face to well, suggest glueing along with screwing/nailing.
-absent of moisture it is extremely stable.
-MDF is VERY heavy
For this project I would almost suggest some type of foam board with hot glue gun. Easier to work with, more resistant to moisture and very economical
This stuff doesn't have a rigid outlayer but has a somewhat rigid inner core between some silver reflective paper. It has a less than 2% water absorbtion. It is just $9.48 at Lowes. I put this on my basement ceiling and had a ton of big scraps leftover, some of which spent a couple of weeks out in the weather and it came in still in good shape. I read they do a lot of modeling with that gatorboard and perhaps it is a tad more permanent but this R-Max 1/2" would be great for proof of concept projects and I even believe it would hang in there for a good deal of years outdoors, but I can't be certain.
It is NON-structural. but for small boxes etc I would try it. I'm thinking of trying a dual chamber swamp cooler using this material.
I can't wait to see your cooler!
Thanks! : )
The price is rather high, but here are some sources for single sheets.
Paint edges with latex or acrylic! Maybe 3/16" would be sturdy enough for your use...
GatorBoard
http://www.foamboardsource.com/
http://www.artsuppliesonline.com/catalog.cfm?cata_id=6044
UltraBoard is similar but with plastic surfaces (I haven't tried it):
http://www.tri-dee.com/Ultra%20Board%20Panels.htm
Thanks! : )
I don't know if foam board would be quite sturdy enough for this project though, but it wouldn't hurt to give it a shot.
Thanks! : )
Great idea and instructable though!
Thanks for reading and commenting!! : )
Thanks for reading and commenting! : )
Also, I voted for your 'ible.
Thanks! I'm really glad you did, I would be ecstatic if I were to win a laser cutter!! Thanks for reading and commenting : )
Thanks for the read and the comment! : )
My family had a swamp cooler in California that worked this way. The evaporation cooled a heat exchanger - the moistened air did not flow into the building, as it does on many swamp coolers.
Thanks for sharing, reading and commenting!! : )
I had considered using a heat exchanger, but decided not to due to the scale of the unit. : )
For example, I live in an three floor, old Victorian, house that is split into three apartments. How many windows would I put this unit in? Could I use it in conjunction with my dehumidifier, fans, or air conditioner for a better effect?.
This project would be easy to adapt to a home window! The base board would need to be cut to fit your window instead, and the size of the window box and convection shaft would need to change, but other than that, it's basically the same!
You could definitely use this with your other appliances, and the dehumidifier could help cancel the humidity gained from the Unit.
We have an old house and the air conditioning works for the whole house, and is quite inefficient. I wonder if there is a way I could use this to save money or if would just end up a hassle?
Thanks! : )
I am an electronic hobbyist and thats why I subscribe to this site. I used to try and enjoy different projects from instructables, but this is the first time i see a project WITHOUT any electronic part, and still interesting to me....!
I will definitely do this to cool my bedroom. It will be helpful, if you can give more elaborate instructions on how to do it.
I was planning to install a hot air exhaust at the top and an inlet at floor level to get some cool effect. But, your idea will be a better one to try...
I appreciate a video of your current project also.
Thanks so much for the interest! I hope your project goes well, and be sure to post some pictures here when you get it done!!
I may try making a video soon since I've been getting more comments.
(The "vote" button in the upper right gets lonely)
Dougbyte
aka Redneck Doug
(That "vote" button on the upper right looks so nice! Whoever made the image should be rewarded..)
Everytime I read article's from this web site I get the urge to try and find my workshop and start making things that are usefull.
I know my work shop used to be in the basement but I forgot where!
Thank you so much, my wife would love me to do a little cleaning up the junk.
It's not junk as I see from this website it's very usefull treasures.
*Shifts eyes to "vote" button on the top right, smiles and looks away* : )
I used to drive a hatchback and I had to open the hatchback since there was no sun roof.
You couldn't drive with this thing on right? But you made a good effort.
We bought a 2000 Neon in 2000, owned it for 7 years, loved the sun roof, rarely used the AC because driving with the sunroof open allowed for awesome airflow inside the car. Use the AC so much that we never got it recharged and it still blew cold when we did use it.
My big question is usability with this design. How easy/reasonable is it to remove and setup? How secure is the car? Too many loose ends to be overly feasible I think. Great idea, loved this stuff, always looking for alternative uses for such things, still needs work I believe.
Thanks for the read and comment! : )
"I had to open the hatchback since there was no sun roof"
I was not referencing the sun roof.
"Use the AC so much that we never got it recharged and it still blew cold when we did use it. "
Should have said
"Used the AC so little..."
I wouldn't drive with this on because it would make it hard to see, and could fall off : )
Are there easier ways? I'm sure!! But for example, it wouldn't be practical to throw wet towels all over the roof of your home to try to cool it, but this concept could be scaled to help!
My diagrams looked way better in my head!
However, I noticed the Jack Daniel's Independence Contest and have been strongly considering getting a patent, making a video, and praying I would win to get some funding to put some units into production!
Firstly, the movement of water up the fabric is caused by capillary action. While technically the sum of cohesive and adhesive forces in most liquids, that is not the way it is measured, calculated and termed. People looking to learn more should search on "capillary action" instead of adhesion and cohesion because the latter terms are seldom used in reference to water.
Secondly, a surprising amount of the cooling done by this system will actually be performed by compression and then decompression of the air as it is drawn through a narrow opening into the bottom chamber and then allowed to expand.
This latter effect can be employed alone to produce surprising levels of cooling. Buckminster Fuller discovered that geodesic domes would auto cool from this effect if he put small opening in the very top and allow the heated air on the surface of the dome to pull air inside the dome out through open door ways. Later it was discovered that the traditional domed architecture of many desert dwelling peoples also employed this effect.
If you intentionally draw the air down a small tube configured like a radiator, you may find that you don't need any water at all to produce useful levels of cooling. The compressed air will be warmer than the ambient so it will cool as it passes down the tube. When it reaches the end of the tube, it will decompress and cool even further.
I'm aware of Charles's Law, however it would only play a miniscule part in this particular setup. This is because the outer window-box is not completely air-tight. Therefore, when air is drawn into the system it is not at a significantly smaller volume than it will be as it moves through the convection shaft.
-Unless you are referring to the air as it expands moving from the unit into the car, in which case you'd be correct!
Geodesic domes are awesome!
But I'm not sure a big box full of water is less annoying to put up and take down than a foil sun shade :P Mine takes about 15 seconds if I REALLY have to wrangle with it. And it keeps my car about 15 deg F cooler.
Folks, I just wanted to make a general comment here about the other comments I've read. I want to applaud all of you for the high quality of your input. I have been reading comments in Instructables for a few years now and I have never been so impressed by them as I have been with the ones here. They are positive and constructive (as stated below) and well worth reading. Bravo to each and all of you!
I've also pondered an AC that has no moving parts and isn't too big. My idea's have been based on thermo-acoustic coolers. They use sound to part hot and cool air. They aren't effected by humidity plus relatively simple construction, but efficiency needs work... Oh and there is a magnet based refrigeration cycle (need superconductors though...). Keep it up man! Maybe you can make something and be a gajillionaire.
Thermo-acoustics is awesome, though I'm only lightly familiar with it, but as far as I know, there are very few moving parts. I remember seeing a refrigerator that used it in a video at some point. And I'd love to get my hands on superconductors if it were possible cheaply!
Don't worry about bringing up humidity, it may be the one negative of this project.
This unit is a great start it would work really well on a house if you added in an automatic float valve and a fan to speed up the cooling(assuming you live where adding some humidity is ok).
Maybe someone could do a small scheme showing the flow of the wather?
However, I'm sure there are other videos online explaining the core principles of the Unit.
Thanks so much for the read, the interest, and comment!!
Incorporating this system into the studs on a shop would be awesome, however I think that it would be most effective if the water trough were situated as high as possible. That way the upward-moving air could become cool as close to the downward-moving phase of the convection cycle as possible.
