Step 3: Gather Materials
Materials:
- MDF Sheet. | 1/4" thick. 2'x4'. $7 or so.
- Glass sheet. | 11.5"x20.5". $5 At local hardware store
- Sheet Metal. | Recovered from old microwaves.
- 1" PVC Pipe. | A small section. I had this already.
- 1/2" PVC Pipe | A small section. I had this already.
- 1" PVC-1/2" Elbow. | The 1" side was a slip coupling, and the 1/2" side was threaded. $0.80 or so.
- 1/2" PVC Male-thread Coupler. $0.80 or so.
- 1" PVC End Cap. $0.50 or so.
- PVC Primer and Cement. | I had these already.
- Wood Glue. | $3-4.
- Caulk. | This was left over from another project. Outdoor Acrylic-Silicone I believe.
- Matte Black Paint | $6 at craft store.
- Mesh. | A splatter protector from the Dollar Store. $1
- Small wood screws. | $2 at local hardware store.
- Fabric. | From an old t-shirt.
Tools:
- Dremel Rotary Tool.
- Oscillating Cutting Tool.
- Jigsaw.
- Drill.
- Various hand tools: knives, scissors, screwdrivers, etc.
Remove these ads by
Signing Up
Visit Our Store »
Go Pro Today »
-very susceptible to moisture, and it will swell up to maybe 3 times its size. Not desireable.
-the strength on the face of it is very good, i.e. you want to walk on it or rest things on it. I built a medium duty workbench with it, works wonderful, nice flat surface. I built utility shelves with it, very nice. I did all the wood work in my house with it... OUTSTANDING.
-but it is not structural in that it has very little span, not good on its edge, won't hold a screw (or nail) very well in the edge or even on the face to well, suggest glueing along with screwing/nailing.
-absent of moisture it is extremely stable.
-MDF is VERY heavy
For this project I would almost suggest some type of foam board with hot glue gun. Easier to work with, more resistant to moisture and very economical
Thanks for the read and comment!! : )
This stuff doesn't have a rigid outlayer but has a somewhat rigid inner core between some silver reflective paper. It has a less than 2% water absorbtion. It is just $9.48 at Lowes. I put this on my basement ceiling and had a ton of big scraps leftover, some of which spent a couple of weeks out in the weather and it came in still in good shape. I read they do a lot of modeling with that gatorboard and perhaps it is a tad more permanent but this R-Max 1/2" would be great for proof of concept projects and I even believe it would hang in there for a good deal of years outdoors, but I can't be certain.
It is NON-structural. but for small boxes etc I would try it. I'm thinking of trying a dual chamber swamp cooler using this material.
I can't wait to see your cooler!
Thanks! : )
The price is rather high, but here are some sources for single sheets.
Paint edges with latex or acrylic! Maybe 3/16" would be sturdy enough for your use...
GatorBoard
http://www.foamboardsource.com/
http://www.artsuppliesonline.com/catalog.cfm?cata_id=6044
UltraBoard is similar but with plastic surfaces (I haven't tried it):
http://www.tri-dee.com/Ultra%20Board%20Panels.htm
Thanks! : )
I don't know if foam board would be quite sturdy enough for this project though, but it wouldn't hurt to give it a shot.
Thanks! : )
Great idea and instructable though!
Thanks for reading and commenting!! : )
Thanks for the read and the comment! : )
