Creating a solar panel out of broken re-used solar cell pieces. I ordered a pack of these from
http://siliconsolar.com (3$ for a bagful of them - you can order
here). In addition, you will need some conductive copper mesh (available at most art stores), glue gun + sticks, a multimeter and a conductive pen (or any sort of conductive brush-on - I got my conductive silver pen
here). In this tutorial I will try to explain the best technique I found to connect these broken cells, in order to create your own CHEAP solar panel.
It is a fascinating project I would like to try. But I would need a whole lot more detail and pictures. Not skipping any steps.
Step 2 Connect the pos. and neg. multi meter clips to where/what on the cell?
Step 5 is really confusing. Needs more detail. It looks like you took tabbing wire and soldered it in one long strip across the negative face of the bits. Then placed the whole string of bits on a large piece of copper mesh. So that only accounts for the positive to pos. and neg. to neg. Is there some other wire that goes over and under the bits? Could you please add pictures of attaching the where the positive and neg. parts are also?
Step 6 & 7 it looks like the wire mesh has been cut into strips maybe a few inches long goes over and under--connecting pos. to neg. That makes it a little more clear. But Now it no longer looks like the tabbing wire is connecting pos to pos and neg. to neg.
Step 9 looks really pretty. But wouldn’t the bits on the back side never get sun?
Step 10 . It looks like we are back to a large piece of wire mesh.
I'll check out some other DIY solar panel articles and add that info to your idea of using broken bits. As an artist I think I can make a really unusual and attractive solar collector. Thanks for the idea!
Diy Solar Panels
Diy Solar Panels
http://build-home-solar-panel.com/
I saw this site and I need your inputs. I want to have at least one guide for now. Thanks in advance!
Good job! Solar+recycling=WIN!
Check out my solar panel blog!
mysolaradventures.blogspot.com
Thanks
John
Mike Mikula,
InfluenSol LLC
diy solar panels
