Step 5Linking the cells
I found that the best way to connect between two cells was to use hot glue and some conductive mesh. The mesh is good since it allows light to come through it, and we all love glue guns. So all you need to do is glue the mesh onto the solar cell surface. Its always better to have a longer strip of mesh on the surface, with a big enough shared surface space between the two. Always check with a multimeter that there is connectivity, and that there is voltage coming through. Its a bummer later to try and figure out where the problem is.
7
comments
Add Comment
HRobinson
says:
thearchitect
says:
Add Comment
