In this first Ecowanderer DIY instructable you will learn, step-by-step, how to make a simple solar water heater from simple household items.
Be sure to check Ecowanderer for the latest news on eco-technology, energy, diy projects and general scientific breakthroughs that can all potentially change the way we live in the future.
Additionally, check the youtube video or the ecowanderer post
Now, on with the instructable.
Here’s the list of the materials you’ll need:
- - Round-shaped plastic bucket
- - Aluminum foil
- - Water barrel (or another round-shaped bucket)
- - 1 metre long pvc pipe, with 5cm of diameter.
- - 2 pvc adaptors: one to join two pvc pipes, and one with a 90 degree angle (both to fit a 50cm diameter pvc pipe)
- - Black spray paint
- - Strong glue/plastic weld
- - Saw
- - Kitchen knife and a lighter
- - Duct tape
- - Black&decker with a small drill piece and an abrasive piece for polishing
- - Protective mask and eyewear
Remove these ads by
Signing UpStep 1Building the Parabola
Let’s start with the round-shaped bucket. Start by cutting the bottom with the saw or a heated kitchen knife so as to end up with a plastic cylinder (the cover of the bucket is not needed). Now the purpose will be to cut this cylinder in half. Start by marking or finding a straight line that is parallel to the height of the bucket (place the bottom-cut part facing your workbench and use your saw to cut through it.
Although not harmful to the project, try to cut in a straight line the best you can. Repeat the process in the exact opposite line of that which you just cut. You should not have 2 small parabolas! To take the best advantage of the power of the sun, glue them together with strong glue or a plastic weld.
Now, to achieve the mirroring effect, grab some aluminum foil. In order to glue/fix it to the plastic without wrapping the foil or creating any crumbs, cut small pieces (in length) but that are large enough in width to cover the width of the parabola. Use simple glue or duct tape to fix it in place.
easy enough to modify to be more effective
but does the heated water in the pipe heat the rest of the barrel's water?
http://josealcinoalano.vilabol.uol.com.br/manual.htm - recyclabe materials version
http://www.sociedadedosol.org.br/ - another version.
These heaters are good to be used in certain conditions. Like regions where should not be snow build up on it, altough the second one can sustain some amount of low temp weather; they will not heat more than 50 to 60 deg Celsius, so PVC and thermoplastic containers can handle the hot water. They all use PVC and tests habe been made with certified institutes that states that after some weeks the water will not show chemicals traces, this means after some time running the system the water will become potable. Also, the PVC exposed to the sun is to be coated with good quality black Ink to protect PVC pipes from UV radiation. All this is a cost X benefit and of course, having fun building it and getting results. As an example, here one can build a "ASBC" system (second link) spending like 10 to 20% of the cost of a professional system. This is getting such importance that professional companies are beginning to offer similar "low cost" systems that are around 3 to 4 times the cost of the DIY version but will use similar concepts and materials. The ASBC version is mature and is being developed, tested and in use since several years ago.
You wouldn't want to translate that 2nd PDF file into English would you.
About 300 million of us might appreciate it.
this was one of the two the link given. Clicking on it gets you a pdf document.
If that's english, I am immediately checking into the Betty Ford Clinic.
First of, the fact that you are only heating water in the small pipe and leaving the water in the tank to stay cool cant be the best way to do this..
Then again it might work like air for all I know, circulating the warm water upwards and allowing the cold to fall intot he pipe to be heated in return... anyone got a clue if this is the way it works?
Secondly I am sure you should use a metal pipe as I know for sure it's a better heat conductor then plastic and would allow for a much more efficient system.
The pipe/reservoir setup was set in such a way that will allow the warm water to go upwards. But that was not the main reason. The initial intention was to have the pipe so hot (hence the black paint) that when the water flows by the pipe it will instantly heat itself to comfortable shower levels.
I indeed pondered about a metal pipe, but I wanted to keep the overall cost small and I couldn't use brass or aluminium or copper due to potential toxicity issues.
But I'm still currious about the efficiency of the immediate heating system you have in mind, have you tried it yet?
I just cant imagine it working for more then the first "load" of water in the pipe, unless hot/cold water behaves like hot/cold air does, and even then I wonder how long it would use to heat the entire tank with such a small area being heated by simply a reflectic parbola as I really dont think you can get it hot enough without a metal pipe and some lenses to focus more extreme heat onto the pipe...
Copper would definitely be the best choice, but I didn't have the tools or the money for it, as do most people.
P.S. I wouldn't say MOST could afford the other materials, a better word may be "some"
Yea a tarp or solar cover would probably help but would also be aggravating for daily use. Especially with an above ground pool and my physical limitations. Previous atempts included the hose laid out on the south facing roof of the house but a pump large enough to lift the water also flowed to much water so there wasn't much heating. A smaller pump with the hose on the ground worked but was a pain to use. The latest seems to work well but looks like (insert profanity of choice) I'll probably do an "ible" when I reconstruct it
