3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Solar Powered radio for $5
This is another good use for the solar panel used on the huge amounts of garden LED lights around, coupled to a portable radio that runs off 2 or 3 AA cells.
Most of us have an old radio lying around, so I based the $5 price on the cost of purchasing/ acquiring a solar powered garden L.E.D light.
I suspect there are plenty of scrap ones lying around, not working because of slightly corroded battery terminals in damp environments - the solar panel will probably be perfect....
With this Instructable I have left my radio on now for 4 weeks, (12 hours a day) while I work and it has never let me down, even at a reasonable high volume level.
You could either leave the solar radio out on a sunny wind sill as I do or leave it in the sun outdoors - every so often to recharge the battery's.
Step 1Step 1
Step 1
What you will require:
1. A portable radio, AM/FM or DAB, (2AA or 3AA battery type).
2. One 4 or 4.5v 80 mA solar panel, prised off from a Solar Light.
3. ideally a BAT43 Schottky diode or Silicone IN4001 (more voltage loss)
4. soldering iron, solder and red and black cable 6" lengths.
5. 2 or 3 NiMh rechargeable batteries (NiCd are ok but not as good) minimum capacity 800 mAh per battery.
Optional - heat shrink sleeving, Adhesive foam strip
This is a very quick project, that can be made in about 2 hours, and helps save the planet :)
37 comments
Jan 20, 2012. 9:04 AMtrickster7 says:
where i can get the garden light?
Nov 30, 2011. 11:50 AMalights says:
so with this project do we have to buy a solar panel?? or just the LED lights??
Sep 6, 2011. 8:33 AMlbruce lee says:
mmmm. must little current ,,....
May 30, 2011. 7:19 PMnoapparentfunction says:
i plan on trying this for some beach visits this summer. is there a way to effectively patch in an auxiliary cord for ipod use?
May 17, 2011. 3:49 PMBillBiker says:
Hi,
This is really a sweet project! I am setting up a workshop in my garage and need to provide some sort of lighting to it. I have a couple options but honestly want to do it as cheap as possible. This idea occurred to me and I am like a very beginner in solar power. What I was wandering if I could take a few of these solar power squares as shown above and tie them together into one big solar panel?
Sep 4, 2009. 7:37 AMPaleoDan says:
Thank you for posting this. This was my first attempt to work with Solar Panels. I did not follow exactly as the materials I had at hand were a bit different. I had an old Panasonic radio that took 4 AA batteries. I took it apart and connected it to a scrap solar panel I had from an outdoor spotlight. I do not have batteries involved so my radio will only function in the sun but was still fun to start with.
Mar 24, 2011. 8:10 PMmitchiko says:
Hi,
How would it be possible to charge the battery? Can the circuitry work on that? I have placed a diode already on my radio but Im not sure that the current being supplied to my radio would be stored in the battery. Though it's still working on now because my battery is still new, but are we really sure that the battery is are being recharged by the solar?? How did you connect the solar to your battery series or parallel?
Thanks
Dec 29, 2010. 4:51 PMmitchiko says:
Hi,
I'm wondering if the watt requirement of the radio is a function here? I mean is there any limitation in terms of what wattage should the radio has in order to be run by the solar panel model? Reply anyone please.
Dec 30, 2010. 5:27 AMPaleoDan says:
I do not know the answer to this in general but the radio I used is "AC 120V 60Hz 3 watts and uses 4 "AA" Batteries for 6V when run on battery. I had lost the AC plug long ago so was limited to the batteries when I made the modification. With the solar I have no limits (except the sun).
Jan 4, 2011. 4:57 PMmitchiko says:
Ah okay thanks for giving me the idea cause I want to do the same also.
Thanks for your prompt answer.
Aug 30, 2007. 1:07 AMYerboogieman says:
my small transistor radio is 9volts can i just add a larger battery pack from radio shack, i wasn't trying to rhyme...
Jan 2, 2011. 6:01 PMroland985 says:
1 volt will have a very small difference, but it will work. 9v batteries actually output 10v for a little while, then settle down to 9, and drops to 7 before it dies. In short. It works...
Jul 16, 2009. 12:39 PMpagray says:
8v will work fine on a 9v radio
Jan 24, 2011. 5:39 AMFashim says:
Yep I've powered a Car Radio with a 9V Battery and they're 12 Volts
Oct 11, 2007. 11:47 AMPCvsMac says:
Hello! You mention that you use a blocking diode, well living in the UK could you please tell me where to get the blocker (or alternative) I checked in my they just power one battery for the LED liglocal Maplins, however I dont know which one to get :S OK fair enough, but could this solar panel (that powers, let's say only one 1.2V battery) be used to power two rechargable batteries? And if so, is it cool to use NiMH batteries? OR Could work directly with the produce rather that charging batteries (Does it still need a blocking diode?)
Oct 1, 2010. 10:59 PMVissy says:
The diode is just to prevent the panels from discharging the batteries when theres no sun. "Blocking" is just street slang for what the diode is used for. NiM batteries are about 1.2v and they charge at almost 3v, as compared to 1.5 volt alkaline.
Most small diodes that you can get at hobby shops/parts places are only 0.25 watts each. I also wouldnt go over 5v for a 3v system, and no more than 12 volts on a 9v system or it will get hot. Batteries will cook, too.
I got fifty 5W diodes from Digi-Key for five dollars, shipped an hour after I'd placed the order. I cant remember the name of the big elec online seller in the UK. You can make a voltage divider from those with some resistors (plans online)
Ignoring losses:
Watts = Volts * Amps
Amps =Watts/volts
Volts=Watts/amps
Oct 11, 2007. 1:00 PMPCvsMac says:
OK thanks dude. However, another question popped up. Oftenly a really cheap solar light powers a 1.2V battery, so would it be possible to power a 3V radio applience? If so please state. And if not also please state and it's back to the 'solar' drawing board. (hehe)
Aug 30, 2007. 1:31 AMYerboogieman says:
k thanks
Dec 4, 2010. 10:41 AMknektek says:
w00t! Same screwdriver and solar light!
Feb 11, 2010. 6:48 PMElectroBabe says:
hey im doing something similar!!!! Im attaching a 4.5 volt panel to a baby swing but not getting enough current . how can I get more amps? more panels wired in parallel and then attached to the panel i already have in series????????????????????????????????????????????????????????????????????
Oct 1, 2010. 10:50 PMVissy says:
oops, I meant most panels are far UNDERsized in IS projects.
Oct 1, 2010. 10:49 PMVissy says:
Whats the voltage & rating on the baby swing? Is it battery operated?
You need to use a rechargeable battery to charge when you arent using it, because people forget about voltage drop, and important things like no shadows on the panel at ALL.
You also need to use diodes (check watt rating too) to prevent the battery from discharging when theres low/no light or a shadow on the panel; its STILL a complete circuit and the battery will drain.
People overestimate solar. The dashboard chargers you plug in your cigarette lighter barely do anything (150mA in full sun).
You may want to experiment with rechargeable batteries, use them as you have this hooked up. You will NOT be able to move something like that with a tiny panel like in this IS. Get a panel from Northern, Newegg, other places. The 36" panels I have are 12v and 5watts each. (5w divided by 12volts = 410 milliamps, almost a half amp at 12 volts.
You could build a voltage divider to get the voltage down to what you need, but I cant remember how to calculate the loss in power from the resistors in a VD circuit. I think you can use Kirchhoff's law to calculate it and still have enough to run it without the batteries (but why?)
Most solar projects I see on here SHOULD have batteries in them, but dont. Most panels are FAR oversized, too. The current needed to start a motor can be 6 to 10 times the current needed to run. This could be overcome with a capacitor
Everyone should use batteries in anything solar they have.
Feb 10, 2009. 9:40 PMnekoheehee says:
Great little mod :D I have a question I was hoping you or anyone who reads this comment could answer. I have a portable cell phone charger that take 2 AA batteries. do you think this mod would work for something like that?
Jun 12, 2010. 2:50 PMBeergnome says:
I know.. its been over a year. but yes, this should work in much the same way for your portable cell phone charger. I have harvested the guts from a couple of two battery garden lights just for that purpose. Its pretty much just a battery charging circuit. and you really only need a reversing diode wired into the panel for the purpose
Aug 13, 2009. 3:54 AMexplosivetron says:
Just wondering if It will be possible to get two 4.5 volt 40ma panels and wire them in parallel to acheive the same affect? They have half of the strips.
Dec 4, 2009. 1:42 PMJodex says:
It will be possible.
Oct 14, 2008. 12:03 PMgomiboy says:
OK, stupid noob question - does the solar garden light already have a blocking diode? My understanding is that's to protect the panel from getting zapped by the battery when the light is low (current out from the battery exceeds current in from the solar panel). Wouldn't a solar garden light have the same problem and thus the same solution already built in?
May 30, 2008. 2:52 PMdxguy77 says:
Just built a solar panel that is 15.7 volts at peak and close to 200 ma of current. I did this by reclaiming the PV modules from 18 garden solar lights that had seen long service but Colorado winters are hard on these lights. Instead of tossing them out, I pulled the PV panels. Each PV panel puts out 2.2 volts, at peak. I supplemented the overall panel using 3 PV modules from LED lights that run at 4 volts. I glued them with silicone chaulk to a piece of particle board. I figured out the center of each panel, drilled holes for the wires and put them into 3 rows of 6. The very first row is wired in series for the voltage, and the next two rows were wired in parallel for current. I mounted a Radioshack 12V DC accessory outlet (270-1556) to the end of the board for quick access to 12V Cigarette Lighter Adapter (CLA) so I can power multiple items. Using a IGO CLA (it can go as low as 8 volts and high as 15) plugged into the outlet, I can charge my cell phone, iPod or any other small device. The voltage is regulated in the IGO unit to the appropriate voltage for the device (ie, 3.6 volts for most cell phones and 5 volts for the iPod). I have ran a HUGE GE Superradio AM/FM radio directly off this panel for hours. I have put this panel on my car's dash at lunch time to charge up my cell phone and it works great. Don't forget the one step about the switching diode! That's important if you don't want backflow and lose voltage if some devices are hooked up and the sun goes down.
May 11, 2008. 1:36 PMtwinklystar says:
I've just done this with a sony minidisc player and a mp4 player a no name one from hong kong and its working great! I'm chuffed to bits.
Aug 29, 2007. 7:12 PMGrady says:
I bet even a dumb bunny like myself could do this one; it sounds great. Now, I wish someone could invent how to get good t.v. reception without the cable or satellite or high, lightning antennas.
Aug 26, 2007. 2:28 AMPCvsMac says:
A excellent project, I really wish I had thought it :)I have two questions, though. 1. How do I know what voltage it is for a solar light? 2. Where the evil batteries usually go, surely it must be easier to wire the postive side of the panel to the positive prong on the radio and (vice-versa for the negative sides)? Let me know, because I think that will work
Jul 23, 2007. 1:26 PMi.am.mozman says:
I was actually thinking about harvesting the panels to charge AAs while backpacking next week. I figured a couple of panels in series attached to a battery holder should be sufficient. This does reassure me that I wasn't completely off my trolley considering it.
Jul 22, 2007. 2:37 PMfabiusX says:
It happens to have 3 of those garden lamp idling witout a garden to be stick into and this project is so simple to do that it will worth a try.
Jul 21, 2007. 8:40 PMBrennn10 says:
Nice! I made this today! It works great! +1
Jul 21, 2007. 6:35 PMTool Using Animal says:
Nice project, and really great website.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:gotwind
