3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Solar Powered radio for $5
Step 3Connecting up the radio.
Some radios have a power input socket for mains adapters, mine did but it was an odd size (Sony).
This option makes connecting the panel more easy, just connect a suitable jack plug to the solar panel (using a blocking diode) and that's it, check polarity is correct!
I decided to hard wire my solar panel, here is how I approached it.
1. Remove the rear panel of radio, and with the battery's in situ, using a multimeter identify the positive and negative connections (where the battery's would connect to). Make sure the multimeter doesn't indicate a negative value, you have the positive and negative probes the wrong way around if so.
2. Solder the 6" lengths of red (to positive) and black (to neutral).
3. drill a small hole in the plastic to allow the two wires to exit the back of the radios panel when reassembled.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:gotwind
