DIY Solar Water Heater! - Deluxe "Aluminum Backed" COPPER COIL Solar Water Heater! 175F Full Instr.
3,124
71
10
Posted in WorkshopSolar
Introduction: DIY Solar Water Heater! - Deluxe "Aluminum Backed" COPPER COIL Solar Water Heater! 175F Full Instr.
About: hi there. on this instructable channel i'll be covering all types of DIY solar power projects (as well as off-grid/survival/green living projects) that are easy to make out of readily available products and ...
DIY Solar Water Heater! - Deluxe "Aluminum backed" COPPER COIL Solar Water Heater! 175F Full Instr.
Step 1: Watch the Instructional Video...
Step 2: Read the Description...
Deluxe DIY Solar Water Heater! Solar Thermal "Aluminum backed" COPPER COIL Water Heater! Easy DIY w/Full Instructions. Super Hot water, super fast. reached 125F in 5 minutes ...and near 175F after about 15. no soldering required! uses just one coil of 3/8" copper tubing (amazon $23) and push-to-fit connectors. only tools used were screwdriver, hammer, tin snips (or scissors), hack saw and a drill. great for use as a stand alone unit or can be hooked into home's plumbing as supplemental heating for water heater. notes: using the aluminum backing adds roughly 10F to the water (but is optional). system is relatively lightweight and is easy to move and store *and the design allows for multiple units to be easy connected together (if a larger system is desired). details: outer board 1/2" plywood 23.7" x 23.7" (sold that way - no cutting required). inner board 1/4" plywood 19 3/4" x 19 3/4". glass 20"x20" (or use Plexi-Glas).4 3/8" Square wooden dowels. 2x2 lumber 2 pieces cut to 20 1/4" and 2 pieces cut to 23 1/4". Hardware: Four (#10) 2 1/2" wood screws. Eight (#10) 1" wood screws. Fourteen 3/8" screws (to hold down the aluminum). 12 1.5" (#16) wire nails. heavy duty heat resistant zip ties (or use wire). 5 3/4" satin brass finish door pull (the handle).
Step 3: Have Fun Building and Using It!
for any clarification or questions just drop a note in the comments section. i'll check often and answer
Step 4: Here's Some Extra Pics...
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    10 Comments
    Umm, I'm new here and just a bit confused. Is there any more details on the build and is there a picture of the finished product and how it functions?
    hi there. at the moment all the details on the build (including the finished product and how it functions) are in the video. i experimented with Video-only instructables, but i've decided to make all of my instructables with both video and all the steps. this is the only one that i haven't added steps too. i'll be adding all the steps shortly.
    Use black plastic agricultural pipe for more heat absobtion and a long life in the sun . Much cheaper and it lasts.
    Those white plastic fittings won't last long in the sun where the black ones will. Take it from someone who has done it .
    hi there. i've made these type of heaters out of the black poly pipe in the past but they only last about 3 years in the 'desertsun' (where i live). also you have the issue of leeching with plastic. but it is cheaper ($) for sure (and works well in the short run). they do sell both of the fittings in metal/brass as well. *just not at the 2 home stores i go to. *technically they are *permanently "out of stock" lol
    Ok . I'm in Australia top end and we get
    40C + often. I use black ag pipe all over the farm for water to stock
    ,lots of it just laid on top of the ground for convenience . Pipe I put
    down 20 years ago is still good and working even with cattle standing on
    it from time to time .
    An alternative then is to get the better
    quality blue or green lined pipe which has a thicker wall but the
    fittings are slightly more expensive too..
    I notice i have some
    laid in the ground feeding the house that is about a foot down in the
    ground . During the day the water gets very hot so the heat is getting
    down to the pipe somehow even at that depth.
    I wonder if covering your device with sand would increase the heat absorbtion
    What was the outside temperature when you heated the water to 175deg?
    A more expensive but better transfer of heat to the coils would have been to use Liver of Sulfur on the copper tubing. It would have applied a patina to the copper that would have a better heat transfer since it is part of the copper than the paint (which is slightly insulative).
    hi again, quick update to my last post... i just re-spoke with an instructables manager and they changed their minds. they now say that my current instructables meet their new guidelines... so i'm not shutting down the account after all :)
