loading
Step 1: Design in English, Italian and French
To make this spectroscope you need to download this pdf file.  If you wish you may also download the Italian or French version.
Print this sheet on a A4 paper.
You will need
1) Pair of scissors
2) A sharp knife
3) Some glue (a glue stick will do)
4) A black card sheet
5) A DVD or CD
Step 2: Glue the printout
The first step is to glue the printout on a sheet of black card sheet.  And press the sheet so that it becomes flat.
After the sheet is properly glued
Write your name on the card sheet.
This is particularly helpful if you as a science teacher would like to get lots of children make their spectroscope.
Step 3: Cut the sheet
Now using a pair of scissors cut the sheet along the external lines.
And the using a sharp knife - cut away the window at  "Eye" and "towards the light"
Use a ruler to make a straight cuts
With this step - all the cuts are over -
we start gluing the spectroscope
Step 4: Gluing the Spectroscope
We now glue the four past of the spectroscope
First apply glue on the side marked A' and B'
This should be done on the 'white' side.
The glue the base - it is to be done on the 'black side'
Step 5: Fixing CD/DVD
We are almost there now -
make two folds at 'eye' and insert a CD or DVD.
You may insert a small piece of the DVD/CD
Step 6: Use it now
Your spectroscope is ready
Now what remains is to use it -  it will not take too much of time for you get used to see spectra.
Hold the spectroscope horizontally in the direction of the source in such a way that 'towards the light' window is towards the source of light.  Please eye at the eye window and now slowly lift the spectroscope with eye fixed to the eye window.
Soon you will see the spectrum.
Step 7: Spectra of Cfl source
Step 8: solar spectra
It is possible to see the absorption lines, called Fraunhofer Lines in the solar spectrum.
By making the entrance slit narrow and then pointing the spectroscope you can observe the fraunhofer lines.
Step 9: Sodium spectra
Watch this movie  - first it shows the general setup for taking a movie of sodium spectrum.
The source was common table salt stuck to a wire mesh with some drop of water and now burning in the flame of a candle.
First you will see a normal continuous spectrum of the candle flame and then in between you will see sharp sodium lines. I have placed the spectroscope on a stand and replaced eye with a simple digital camera.
I build it and got great images (spectrum's) .<br>Love the instructable!<br>Thanks!<br>
Thanks Alpha - this is one Instructable I will definitly make!
Thanks very much (sorry for the delayed reply - I have been traveling and busy with other work) - could you send me a picture of your spectroscope.
Sure .. I will even do better ...<br>Here are some pictures I took with it as well .<br>Feel free to post on page .<br>
Very Cool!
nice instructable...
jajajja, awesome, you use it for identify chemical elements?
you could identify some elements in the solar spectra - but I have not tried other elements - if you do, do let me know too
About This Instructable
17,551views
53favorites
License:
Bio: I had been interested in DIY activities since my childhood. One of my DIY activity - astronomy and telescope making took me on a path to ... More »
More by AlphaRomeo:Smart Phone Finderscope Make a Rain Gauge Discovery of an Amazing Object in the Sky
Add instructable to:
