loading
Step 2: Saw open the mic, get that spring!
First you'll need to cut open the echo mic.
I used a saw for this and just sawed along the side until I could get to the insides.
The spring might be stuck inside, but with some force on the outsides of the mic, you should be able to get one side to detach.
The other side however, is a bit tricker.
I used a pen and a paperclip to kind of "fish" the other end out.
FInally, you'll have a detached spring! :)
<p>Is the piezzo mic plugged? I'm so confused.</p><p>What is plugged to what?</p>
<p>I don't get the slide about the amplifier bit and the battery compartment. I have all the other parts.</p><p>Is the piezzo mic going on the speaker? And connected to the Mono Jack? Can I make it so I can connect the jack to a female receptor and connect the speaker to that?</p><p>Is the speaker plugged to anything?</p>
great project, how come the speaker being used as the transducer doesnt make sound though?
<p>Beause it is so quiet. That is why you attach it to the amp before the output</p>
I have nearly aquired all the parts to make this, how would you go about wiring a blend pot QuinnH, also markijzerman mentioned about putting an amp after the spring any ideas how to do this also? Im hoping to use it on stage with my guitar :-) Any help appreciated cheers :-)
<p>Hi, just saw your comment. 6 months ago I know, but here, I'm guessing something along the lines of this:</p><p>Leftmost side of pot: input one.</p><p>Rightmost side of pot: input two.</p><p>Middle pot: Output</p><p>As the pot moves closer to one side, there is less resistance between in and out, thus making that side louder and the other quieter.</p>
<p>This is great! I have a question, does the knob for tone on the Marshall ms2 still function in this reverb unit? That would be the best. </p>
<p>ps: why did you use a battery instead of the power supply of the marshall?</p>
<p>so, essentially, you are just hooking a spring to the cone of a speaker, to a piezo, to an output/input.</p>
<p>Awesome project, I would suggest wiring in a blend pot so you can control the amount of reverb!</p>
How would you do that mate I'm in the process of making one with two piezos and springs any help on a blend pot would be appreciated :-)
A basic blend pot has two inputs and one output. It allows you to mix (blend) those two inputs together. You would want to put a clean, unaffected signal in one input and the output in the other. You could then control how much reverb/clean signal you get. You might need to do some research to find out how specifically to wire it and which resistance will be best for your piezos. I hope this helps, tell me how it works out!
Wicked dude i will try and work soemthing out :-) I will keep you updated :-)
<p>Hi, great instructible! :)</p><p>I really want to make this, could you give me the exact name of the piezio element, or even better a link to where I could buy one? I don't really know what it is. Thanks :)</p>
Really nice!
great projects, i still have some of the reverb assembly i salvaged from old guitar amps, they have been lyin on the parts rack for a long time, maybe i could re-use them using your amp circuit!
I love it! I knew how a reverb tank works, but I never really imagined it would be so easy to build one... or that a homemade one would sound so good! This goes on my project list!
My dad had a Chevy convertible from the 1960s back in 1975 with a spring reverb unit in the trunk. It made some funky sounds when we went over rough roads.
I'm old enough to remember those things in cars. Very subject to noise and would let out an awful racket if you drove over a rough railroad crossing. The better ones put the signal into the spring in torsion rather than push-pull. That had less noise pickup.
Nice. My dad has an old tube amp (probably from the 60s or 70s) with a spring reverb in it. I &quot;borrowed&quot; it in college to jam with my friends; it was always fun to kick the cabinet, which would shake the spring and do crazy things with the reverb.
Awesome. I want to build a HUGE one some other time though, to use as an instrument! :)
Garage up-and-over door springs. You know you want to.
Yes, awesome idea! are those &quot;springy&quot; enough though? Something as flexible as a slinky works best.
I've just gone and &quot;pinged&quot; the one on my door, a good 5 second reverb tail there ... No they're not very flexible, but they are springy, not something to mess with under tension :) <br> <br>Can you ever get any tension into a slinky? They're probably too far the other way (floppy). <br>
Slinky/floppyness indeed depends on size and of course how far you stretch it.<br><br>Sounds awesome. would be cool to be able to bow a spring like that! :)
great work! a nice extension would be to add a wet/dry mix knob to control the level of reverb. I think it could be as simple as a pot with the ends connected to amp (dry) and piezo (wet) outputs (with series resistors to balance signals) and the center connected to the main output. it could require a 2nd amp for the piezo to get the signals to balance the way you want them.
yes, that would be my next addition, but for now I tried to keep it simple! <br>And it works quite well as an external effect. I can send the amount of signal I want to the reverb :) But for standalone-purposes (or if you want to make a guitar fx-pedal), then YES, this is needed :) <br>Thanks for the clear explanation!
cool
Thanks!
Cool! It creates nice sound effects!
Thanks!
About This Instructable
195,065views
302favorites
License:
Bio: Mark IJzerman is active as a sound designer, music composer and educator with a great interest in interactive and procedural sound. Besides being an artist ... More »
More by markijzerman:DIY Spring Reverb
Add instructable to:
